Old 03-19-2007, 07:50 PM   #1351
rmdhawaii's Avatar
Originally Posted by tenderfoot57
I am running a rrr with titanium 2spd shaft. How do I keep the shaft from fusing together with the collar at the end of the shaft. The collar on the 2spd side of the shaft where the tightner screw is located. This happend with the 3racing and also with the Kyosho shaft.
Muchas gracias.
You want to use anti-seize grease, which neutralizes the natural chemical reacton between titanium and other metals. I use the Finish Line brand. You might be able to find it in a bike shop.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 03-19-2007, 08:23 PM   #1352
Trader Rating: 13 (93%+)
he means its get stuck on
kept happening to me so i ended up going back to stock shaft
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 03-19-2007, 08:24 PM   #1353
tenderfoot57's Avatar
Send a message via AIM to tenderfoot57 Send a message via Yahoo to tenderfoot57
Hey thanks for the quick replies. I have been using the anti-seize on my gears I will try on shaft. Hey Dred it does not look to be welded just feels like it. When this happened with the piece of 3racing shaft I would have to use a lighter to heat up the collar and then it could be removed, PITA (pain in the ...) and very hot.
tenderfoot57 is offline   Reply With Quote
Old 03-19-2007, 08:31 PM   #1354
oh, oh yeah I know what you mean. Yeah that happens to me too...you said fused and I thought like the metal melted together
Anyway yeah try some of that grease used on bicycle parts. Any quality bike shop that carrys repair products should have it. I used to use it when I raced BMX on any part you want to be able to remove easily. Mostly on the threads of bolts and nuts. I thought of it like the opposite of loc-tite.
Kyosho V-One RRR - JP Modified Mugen X12 - GQ Racing Tires - Futaba servos - KO Helios w/Spektrum Pro - Maxy's Fuel
Losi 8ight 2.0 RTR for fun times
Dredd is offline   Reply With Quote
Old 03-19-2007, 09:29 PM   #1355
robert maestrey's Avatar
Thanks guys
Sippin Coladas and Chillin
robert maestrey is offline   Reply With Quote
Old 03-19-2007, 09:32 PM   #1356
What is happening is your one-way is freezing up and damaging the shaft because the collar will spin on the shaft in turn fusing them together...when running this shaft pay special attention to your one-way and make sure it is constantly clean and lubed periodically......actually you should do this with the original shaft as well...
hope this helps
Old 03-19-2007, 11:10 PM   #1357
jeff1's Avatar
talking about one-way
what lube do you use? and for thrust bearing?
jeff1 is offline   Reply With Quote
Old 03-19-2007, 11:20 PM   #1358
mugen super grease works best
Old 03-20-2007, 12:43 AM   #1359
Chemical X's Avatar
Trader Rating: 16 (100%+)
Is there an online version of the V-One RRR Evo WC manual available (31260)? The latest one I could find is 31259.
Thanks.
Chemical X is offline   Reply With Quote
Old 03-20-2007, 07:57 AM   #1360
jeff1's Avatar
Grease.. it can be used in one-way? maybe it will slip or not?
Thanks dude
Old 03-20-2007, 08:01 AM   #1361
rmdhawaii's Avatar
Thanks.
I have not seen it posted at Kyosho America or Kyosho Japan.
Old 03-20-2007, 08:48 AM   #1362
maskedrider's Avatar
congrat Rob
Kyosho- Sirio/ OS engine- AVID bearing- Blue thunder fuel- Proline- RC dynamite- Sanwa- RC Art
maskedrider is offline   Reply With Quote
Old 03-20-2007, 09:25 AM   #1363
etgdpu's Avatar
Thanks dude
You are right.
Only the special purpose "one way bearing oil" must be used. The reason is that static electricity may appear by any other type of lubricants. Static electricity will cause the metal cylinders to go away from each other, meaning that they will all move to the outer ring of the bearing body, due to the electric forces and the one way bearing will not work.
Since I have not yet found such an oil from Kyosho, I use the Serpent one, which I recommend. Only 1 or 2 drops are enough, because more will have the same bad results like any other lubricant. I clean the 1st gear one way every 15 - 20 minutes of play and the front one way at the end of each racing day. I did not have any failure of those bearings for more than a whole racing season.
The intelligent can become anyone, anyone can not become intelligent.
etgdpu is offline   Reply With Quote
Old 03-20-2007, 09:32 AM   #1364
racers edge makes great oneway lube
DaNNy250RRR is offline   Reply With Quote
Old 03-20-2007, 09:56 AM   #1365
bvoltz's Avatar
Trader Rating: 44 (100%+)
I have a question and I have spent the past 2 weeks trying to figure this one out and not look like a dumb butt for asking....
How do you measure the UpStop and DownStop on the RRR EVO?
Droop for the front, how do you change it? I understand how to change it on rear of the car, but I can not figure out the front.
I know these are pretty dumb questions, but I can not figure it out....
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
