Old 02-21-2007, 05:30 PM   #1246
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Originally Posted by doki_doki
Thanks for the infomation.... Might purchase these items at my local hobby shop if they have them
Doki, the Square titanium screws are good but you have to purchase them online dont know any LHS that sell them here
buboy28 is offline   Reply With Quote
Old 02-21-2007, 06:41 PM   #1247
rmdhawaii's Avatar
Originally Posted by robert maestrey
...for qualifiers try 37 front and rear and cut tires to 60 rear 58 front and go out there and have fun
More questions...
In the past, people have stated that the ideal tire sizes for the RRR were 62 rear / 60 front. Are you saying that 60/58 is faster? Also, are you using a ride height of 6 rear / 5 front with the 60/58?
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 02-21-2007, 06:52 PM   #1248
esham's Avatar
W-nats set-up enjoy
Front
Solid front
rear
rear diff 50,000
spur gear 61/56
pinion gear 17/22
Robert Maestrey
Congatulation to you Robert M. even by reading those report from Mike and others the competition was tough, stress and yet fun. Thank you for the W/nats setup too. Did notice you used solid setup out front and i never try that yet but Robert, what should i consider if i should use oneway or solid for a track and if i use solid what are the significant setup changes that i should make compared to oneway setup? Probably i should try to feel the different..
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 02-21-2007, 10:59 PM   #1249
robert maestrey's Avatar
Originally Posted by rmdhawaii
More questions...
Thas not correct......... I ran some quals this week with 59/57 car felt pretty fast....that ride height sounds about right once you setup your car with some small tires you should not have to adjust your ride height for the main...just add your larger tires for the long main and the height of the tires will raise the ride height...always set the car up with qualifying tires...meaning small ones.....
Sippin Coladas and Chillin
robert maestrey is offline   Reply With Quote
Old 02-21-2007, 11:00 PM   #1250
None just try the solid with the same setup and see how it reacts you might be pleasantly surprised...if the car lacks something after the change just adjust car accordingly...
hope this helps....
Old 02-21-2007, 11:15 PM   #1251
rmdhawaii's Avatar
Sweet!
Old 02-21-2007, 11:16 PM   #1252
nitro_moe's Avatar
Thanks a lot you guys for your opinions. I really appreciate you taking the time to answer. I did sense a lot of honesty which will make it much easier for me to decide...
And Rainer,, thanks again for a great website!! I hope you got my thread in the engines forum . I'll defenitely do the manual comparison between the MTX-4 and RRR Evo WC.
nitro_moe is offline   Reply With Quote
Old 02-22-2007, 02:20 AM   #1253
esham's Avatar
hope this helps....
Thanks Robert i need to try this and if necessary set it accordingly from there. Other than this i still have issues with the stock break pad and wonder if anybody here tested the APP break pad, abit expensive but is it worth to try - durability wise.?
Old 02-22-2007, 05:37 AM   #1254
Yes I have tried them...But I prefer the Acre pads..composite bonded pad
part # Ifw324
Old 02-22-2007, 06:07 AM   #1255
ITO NIEVES's Avatar
W-nats set-up enjoy
rear
Shock oil 800
diaphragm stck
shock piston 2 hole
spring dark blue
shock position 3
wheel spacer 0mm
upper arm height b
camber angle L4 R3.5
toe angle +2
tire diameter 64.5
chassis height 8
lower arm position roll cnter stck
body stratus 3.1
brake normal
rear diff 50,000
spur gear 61/56
pinion gear 17/22
drive ratio 2mm split 23t pulley 384 belt
clutch shoe grey
clutch weight normal
clutch spring stck
clearance .4
adj nut 1.0
end play minimal
Hope this helps
Robert Maestrey
Hi mi pana, what shore you use in rear?
CAPRICORN_ Lab C01---- Sirio XXXV.
ITO NIEVES is offline   Reply With Quote
Old 02-22-2007, 06:15 AM   #1256
Hey Pana Whats up.....I used 45....Pana call me we need to talk....
Old 02-22-2007, 08:26 AM   #1257
ITO NIEVES's Avatar
OK. I call you 7:00 p.m.
Old 02-22-2007, 08:35 AM   #1258
jag
jag's Avatar
I am using the APP break pads and disk and you are right, they are expensive but they work very well. They take a few laps to warm-up but after that they are very consistant.
jag is offline   Reply With Quote
Old 02-22-2007, 08:47 AM   #1259
sneezer714's Avatar
Hey what are you guy's up to!!!!
Congratulations Robert you did good!!! at the Winternats!!
There's something missing in that Set-Up Sheet, you forgot to mention the Paint Job wich made your car a lot faster!!!!!!
Javier.
JAVIER PAINT WORK'S
TEAM CFX PAINT WORK'S
sneezer714 is offline   Reply With Quote
Old 02-22-2007, 10:51 AM   #1260
ITO NIEVES's Avatar
Javier.
Eaaaa Rayoooo Robert, Javier is
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
