Old 01-29-2007, 09:21 PM   #1081
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default hmm
Originally Posted by doki_doki
I also changed my Kyosho aluminum wheel hubs to the Kawahara wide aluminum wheels hubs It is much easier to work with this wheel hubs since it has a set screw to clamp it down to the drive pin as compared to Kyosho ones that you have to work you way around the o-ring which holds the drive pin
you could call it the v 1-RRR evo wce kawahara edition you like sounds good
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 01-29-2007, 09:34 PM   #1082
GMartinez's Avatar
Trader Rating: 85 (100%+)
Doki if you can please answer the ? that I asked 3 or 4 pages ago what is the the weight on your car because after all hop ups you must be way over weight now. my take on a couple of hops ups for the rrr is not necessary I been running the rrr for 2 seasons & i did the same thing put this & that on & guess what I was way over weight now I am running the RRR EVO WCE bone stock & the only hop up is the 3 racing oneway/lock I have never broken a front or shock so I don't see a need for thicker one lucky i guess (knock on wood) the kyosho stock one is high quality
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 01-29-2007, 10:04 PM   #1083
robert maestrey's Avatar
Originally Posted by Sp Racer
I've tried it ( had it since Ifmar 200mm worlds) - it's very good, but the settings are very critical.
The 2d clutch makes the car both easier to drive due to the way it engages and quicker due to how hard it engages ( does that make sense?)
You can feel the point where the clutch engages a lot better with the 2d clutch, this allows you to be smoother and not have to blip the throttle out of every turn .
HTH!
very nice too know..Thx
Sippin Coladas and Chillin
robert maestrey is offline   Reply With Quote
Old 01-29-2007, 10:05 PM   #1084
Originally Posted by rmdhawaii
The 3D Clutch comes standard with the RRR.
This is what is being said about the new 2d Clutch (part # VZW222):
4D Clutch....1/8th scale?
Great info rainer...thx
Old 01-29-2007, 11:27 PM   #1085
twiggy's Avatar
it all really makes sense!
from memory the red clutch shoe is more aggressive than the stock shoe.
less slip = less friction therefore less heat and more consistent clutch engagement. the downside might be that the red shoe wears out faster because it is a softer material.
now, the more weights you have in your clutch the more pressure is applied to the clutch shoe when the clutch is engaged right? well because the 2d clutch system uses the agressive shoe, they took out one of the weights which helps the engine spool up quicker due to less rotating mass.
this could also be why the clutch is sensitive/critical to changes.
the lighter flywheel means engine can spool up quicker which also gives faster acceleration.
ok i never want to see the word clutch again!
www.Moorebankraceway.com
Hamilton 2008 F1 champion!
twiggy is offline   Reply With Quote
Old 01-30-2007, 01:06 AM   #1086
carkillaii's Avatar
Good Job Twiggy
carkillaii is offline   Reply With Quote
Old 01-30-2007, 02:57 AM   #1087
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
hehehe
doki_doki is offline   Reply With Quote
Old 01-30-2007, 02:58 AM   #1088
doki_doki's Avatar
actually, i haven't weighed the car after putting all the hop-ups don't have an accurate weighing scale just an analog one that is used to measure one's body weight. will this weighing scale be good enough? what's the weight of your car box stock? will base it from there is my kit is overweight
Old 01-30-2007, 03:06 AM   #1089
rmdhawaii's Avatar
No, that scale will not do. It is not very accurate.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 01-30-2007, 03:09 AM   #1090
doki_doki's Avatar
Hmm...What options do I have to get a closer weight of my kit? Thanks
Old 01-30-2007, 03:14 AM   #1091
rmdhawaii's Avatar
Well...
Is there a post office nearby? You could try a postal scale. Be sure to ask them how accurate it is.
Old 01-30-2007, 03:19 AM   #1092
doki_doki's Avatar
Well...
Hmm...I will try that. As of the moment, I'll try to use the smaller weighing scale that my neighbor has. She uses this scale to measure when baking or cooking. Would this be any good?
Old 01-30-2007, 03:35 AM   #1093
rmdhawaii's Avatar
Just try it and see what it says.
Old 01-30-2007, 03:50 AM   #1094
doki_doki's Avatar
Ok...Will be going there later. By the way, how much does your kit weigh?
Old 01-30-2007, 03:55 AM   #1095
rmdhawaii's Avatar
On a U.S. Postal Scale (yeah, I know), without the body or fuel...
WCE #1: 3lbs. 11.8oz = 1,695.52g
WCE #2: 3lbs. 11.5oz = 1,687.02g
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
