Old 01-22-2007, 11:11 AM   #1021
rmdhawaii's Avatar
Originally Posted by etgdpu
Hello all,
I would appreciate if you helped with the following problem:
My car started as RRR and then was upgraded with some of the WC hopups. Later was converted to EVO with the conversion kit and upgraded with some more parts of the EVO WC edition. So now it is an EVO almost WC. In the rear I have upgraded the dogbones with the VSW007 CVDs, in order to be able to use 0 offset tires.
However, with the new bulkheads of the EVO, we have more options where to mount the rear camber link.
If I mount it to the upper and outer hole then the camber link seems to long to achieve camber more than 2 with maximum 200mm rear width.
I have thought 2 options, either I replace the VSW015 with the VSW015 and I still use 0mm offset wheels and I unscrew the pillow balls to achieve the width and the camber or I shorten the VZ077 and the ball cups.
If I use the first solution and we suppose that I want to use 2mm offset whells then I come back to the initial problem. Correct?
What do you suggest?
Thanks in advance
2mm offset wheels are pretty hard to come by. Another option might be longer turnbuckles:
https://www.lunsfordracing.com/mm5/m...gory_Code=TURN
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 01-22-2007, 11:18 AM   #1022
rmdhawaii's Avatar
Originally Posted by SOLOARTIST 702
info needed im looking to see if there is any lightened rear hinge pins for the rear if so part# please thanks
I haven't seen any. Only steel and hardened steel.
Old 01-22-2007, 11:25 AM   #1023
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default hmm
thanks buddy
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 01-22-2007, 11:26 AM   #1024
Eric Gebhard's Avatar
3 racing makes titanium hinge pins. http://www.rc-toro.com/product_info....roducts_id/100
Eric Gebhard is offline   Reply With Quote
Old 01-22-2007, 11:28 AM   #1025
Default hmm
thanks ERIC
WILLIAM PENDERGRASS
Old 01-22-2007, 05:30 PM   #1026
jag
jag's Avatar
Hello all,
Thanks in advance
I was told to never use the top row on the EVO rear bulkheads. If you want/need to use the outer/upper mounting location you will have to use a long grub screw or cut the stock link and trim the plastic ends. I typically run 3 degrees of camber in the rear and I can bearly get that on the lower/outer hole. I use the 007 universals and 0 offset wheels. If you try to use 0 offset wheels with the stock universals they will be short and very close the the edge of the outdrives on the diff and you will eventually have a problem with that.
I hope this helps.
jag is offline   Reply With Quote
Old 01-22-2007, 07:47 PM   #1027
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
I just wanted to "stop in" to this forum and say Hi. I will be driving this car for 2007. It will be some time while I learn this car and hopefully you guys will be able to help get me up to speed with the car. At some point soon I hope to be able to return the favor.
Thanks rmdhawaii. I have already gone through the knowledge base twice looking for info.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 01-22-2007, 08:41 PM   #1028
robert maestrey's Avatar
welcome to team Scott.....if you need any help whatsoever dont hesitate to ask..
Sippin Coladas and Chillin
robert maestrey is offline   Reply With Quote
Old 01-22-2007, 09:14 PM   #1029
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Thumbs up
Congrats on a great choice great to see another RRR owner welcome.
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 01-23-2007, 01:12 AM   #1030
carkillaii's Avatar
Fish you know i havent been doing much racing but I know a hell of a lot about the car you know ill help you, congrats man
carkillaii is offline   Reply With Quote
Old 01-23-2007, 03:33 AM   #1031
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
Originally Posted by Ivan Dickson
Hey Doki Doki , did the biltz body come with decals for the lights?
the blitz altis body came with decals for the front and rear lights i opted to do a custom mask for the lights to have a more aggresive look for the body
doki_doki is offline   Reply With Quote
Old 01-23-2007, 03:35 AM   #1032
etgdpu's Avatar
Hi,
You mean that I need shorter and not longer!!!!
I hope this helps.
Hi,
If the upper row is not to be used then why they upgraded the bulkhead and they included this upper row? However, I have not seen any setup from Kyosho drivers that use the number 3 (upper/outer) hole.
As for the issue with the stock universals I think you are right.
Thanks a lot
The intelligent can become anyone, anyone can not become intelligent.
etgdpu is offline   Reply With Quote
Old 01-23-2007, 06:30 AM   #1033
jag
jag's Avatar
Welcome Scott.
Old 01-23-2007, 10:18 AM   #1034
Thanks, I went to order one shipping is very expensive is there another site to order the blitz body besides canada?
Old 01-23-2007, 01:07 PM   #1035
doki_doki's Avatar
Not sure if there is any other site you can order that is nearest to you. You can try www.rc-mushroom.com if you want to order online hope this helps
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
