Old 01-12-2007, 02:49 PM   #976
rmdhawaii's Avatar
Originally Posted by gunna do
Alright all you gooroos out there have a bit of confusion here.Can someone please explain to me a little about roll centers,so i achieve satisfactory results on high &low traction tracks,aswell as large,medium & tight tracks.
P.S. can anyone tell me where to find setups for the RRR EVO that the top Kyosho drivers were using at the worlds in Brisbane.
This won't answer all your questions regarding roll centers, but it gets pretty close:
http://www.nitrokb.com/phpBB2/viewtopic.php?t=15
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 01-12-2007, 10:17 PM   #977
LazyRacr's Avatar
Just finished putting together my NEW!!! Kyosho V-One RRR EVO..... looks fabulous......
LazyRacr is offline   Reply With Quote
Old 01-13-2007, 02:50 AM   #978
fritzD's Avatar
Send a message via Yahoo to fritzD
New Cars look so damn sweet. I miss the time when my my car looked the same.
fritzD is offline   Reply With Quote
Old 01-13-2007, 03:50 AM   #979
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
nice kit you got there are you using the mtx-4 receiver cover? just curious, what is that connector at the side of the receiver cover for? thanks
doki_doki is offline   Reply With Quote
Old 01-13-2007, 08:23 AM   #980
GMartinez's Avatar
Trader Rating: 85 (100%+)
That is to turn on the car since he is not using a on&off switch
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 01-13-2007, 08:31 AM   #981
GMartinez's Avatar
Originally Posted by Sp Racer
Front -
Dark blue spring - kit piston - 550 oil - 11 ackerman - spool - roll center "B" up - carbon shock tower mounting 1st hole in from outside - caster in the middle - 1.5 deg neg camber, 2 deg toe out - swaybar full flat ( softest)
Rear -
Dark blue spring - kit piston - 500 oil - camber link mounted lower inner hole - 2mm spacer outer - roll center "B" up - shock mounting 2 holes in from full vertical - either blade sway bar full flat or black wire sway bar - rear diff 30k filled to the spider gears - 4 deg neg camber, 3 deg toe in -longer rear universal joints were used without the 2mm axle spacer (allows the use of 2mm offset wheels) - 23 t side pulley & 2mm split - 58/56mm tyre diameter
Sirio STI gearing - 17/61 ~ 22/55 - 0.9mm spring pre load, 0.6mm clutch end play
hope this helps!
How did you like the feel of the clutch engagement moct of the time I am using a.4 or.5 depending on the track with a 1.2 pre load
tip also low traction track 10,000 diff
Old 01-13-2007, 09:12 AM   #982
picco007's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
George,
Thanks for the stuff!
Ronnie
EA Motorsports
picco007 is offline   Reply With Quote
Old 01-13-2007, 12:03 PM   #983
GMartinez's Avatar
Originally Posted by picco007
George,
Ronnie
Anytime
Old 01-13-2007, 06:55 PM   #984
doki_doki's Avatar
I see. I was planning to install that thing in my kit I need to find a receiver cover first
Old 01-13-2007, 09:30 PM   #985
LazyRacr's Avatar
I really dont like using a switch, so that is my connection for the battery. Its just my preference, thats all.....And yes that is the MTX4 receiver cover. It does look sweet, but cant wait to get some track gunk all of over it.....
Old 01-16-2007, 05:54 AM   #986
doki_doki's Avatar
These parts just arrived today Can't wait to install them when I have the chance
KAWAHARA K-464 FRONT SHOCK TOWER MOUNT
KAWAHARA K-471 BUMPER
KAWAHARA K-473 REAR SHOCK MOUNT
KAWAHARA K-478 FRONT BODY MOUNT PLATE
KAWAHARA K-479 REAR BODY MOUNT PLATE
KAWAHARA K-489K KEVLAR LF-K REAR BELT
KAWAHARA K-488K KEVLAR LF-K FRONT BELT
KAWAHARA K-490K KEVLAR LF-K CENTER BELT
Old 01-16-2007, 06:34 AM   #987
doki_doki's Avatar
Speaking of new parts from Kyosho, the company has released a new clutch system. I read this article from http://www.rc411.com/pages/newsarchi...e=012007#29726. Anyways, I copied the article to save you time
Kyosho 2D Racing Clutch
Posted on Monday, January 15, 2007 at 9:41 AM by DerekB
Friday, Jan. 12th, 2007 - The Kyosho 2D Racing Clutch is specially developed for IFMAR World Championship competition and modern, high revving racing engines. This clutch has a special combination of features that produce very strong acceleration and consistent performance desired by the top racers in the world.
A new nickel-plated lightweight flywheel has a smooth, polished surface that allows the clutch flyweights to move smoothly and consistently. The red clutch shoe is the same high-grip material used in the 1:8 Evolva, which provides strong engagement with less slip, which reduces heat to provide consistent performance from start to finish. The clutch kit includes everything you need for installation - simply swap the pinion gears from your standard clutch and you're ready to race!
Kyosho V-ONE RRR Evo-kyosho-2d-clutch-system.jpg   Kyosho V-ONE RRR Evo-kyosho-2d-clutch-system-2.jpg
Old 01-16-2007, 07:58 AM   #988
ziggy12345's Avatar
[QUOTE=doki_doki]These parts just arrived today Can't wait to install them when I have the chance
QUOTE]
Where can you get the Kawahara belts online??
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 01-16-2007, 09:20 AM   #989
rmdhawaii's Avatar
The body mount plates are really great. I would recommend them to anyone.
Old 01-16-2007, 09:32 AM   #990
Send a message via Yahoo to speedy100
Default EVO-WCE rear blade sway bar issue
hi all, I just finished building my Evo-WCE kits. The only issue that I have not been able to reslove is the rear adjustable blade bar touching the rear belt. Does anyone encounter the same issue and how to overcome the problem ? I was thinking to shave off some metal part but not sure if that work. Any insight you have will be much appreciated. thanks............
speedy100 is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
