Old 01-10-2007, 06:25 PM   #961
carkillaii's Avatar
Originally Posted by ianhobbies
NEW VONE RRR EVO PART RELEASED
VZW223
THIS WAS USED BY THE FACTORY DRIVERS IN THE RECENT WORLDS
looking for this part anyone know where i could find it, its not listed with kyosho usa , lil help please
carkillaii is offline   Reply With Quote
Old 01-10-2007, 06:29 PM   #962
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default hmm
Originally Posted by litespeed-dom
Ah Ha! I was wondering how come no one asked..... Yet another speed secret... well not really speed secret really, more like Bling secret.
I use it to clean the outside of the body for scuff marks! Try it, it's an amazing body cleaner and also it leaves a nice rain-x compound on it it so it doesn't attract dirt as easily!!!!
Dom
good lookin out thanks for the info
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 01-10-2007, 07:12 PM   #963
rmdhawaii's Avatar
VZW223 SP Side Pulley Set: Enables 18T pulley for the EVOLVA to be used on the V-ONE RRR Evo. Set screw used to fix shaft. Fast disassembly and re-assembly for improved maintenance.
Maybe it's just not posted in the online store yet. You could always call Kyosho USA and ask them if they carry it. If so, your LHS could always special order it for you.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 01-10-2007, 08:05 PM   #964
C_O_jones's Avatar
Damnit Fred! You made it sounds like it's a grandpa wagon!
You know everything I own is usually pimped!
Dom
Thats because it IS a gramdpa's ride. The mini van is next!!!!!!!!!
Tura gets the wagon and I see you in an early 80's minvan, I bet Ellis can find you one.
Fred
Bacon is Meat Candy
C_O_jones is offline   Reply With Quote
Old 01-10-2007, 08:22 PM   #965
litespeed-dom's Avatar
Fred
If anything, I need the all white Dodge "Serial Killer Edition" van!
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 01-10-2007, 09:23 PM   #966
picco007's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
I am trying to get all necessary parts to make the conversion from the wc to the evo. Is there a plastic part that I need to attach my receiver too since it will be on the side of the throttle servo? If so can someone tell me what I need to order? I have everything else....I think.
Thanks in advance.
EA Motorsports
picco007 is offline   Reply With Quote
Old 01-10-2007, 09:28 PM   #967
Thanks in advance.
Ask, and you shall receive!
http://www.shopkyosho.com/product/pr...YOFM509B/410.0
Dom
Old 01-10-2007, 09:32 PM   #968
Here's a checklist for you to do the top deck.
VZ241 - new upper deck
VZ246 - Grommets
FM509B - Small parts set (rx mount)
optional VZ102C - improved steering servo mount, easier to route wires and access to the steering servo horn ball stud.
Dom
Old 01-10-2007, 09:58 PM   #969
picco007's Avatar
VZ246 - Grommets
Dom
Thanks, your the man! I'm getting the upper deck already, so I will need to get the Grommets, small parts set and the improved steering servo mount.
Thanks again.
Ronnie
EA Motorsports
Old 01-11-2007, 04:27 AM   #970
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
Originally Posted by occ
Do Kyosho make a thicker Rear Shock Tower than the standard VZ231B?
Or do you guys use another brand?
I just placed my order for the Kawahara 4mm rear shock tower
doki_doki is offline   Reply With Quote
Old 01-11-2007, 07:42 AM   #971
jeff1's Avatar
Hey dom
there is any improvement in performance with this new upper deck? Mine (older version) is broke after a crash, and I have to replace it. Just wondering if compensates to upgrade
thanks
jeff1 is offline   Reply With Quote
Old 01-11-2007, 09:08 AM   #972
jag
jag's Avatar
Originally Posted by rmdhawaii
That's exactly what I was thinking, but I let it go.
Me too...
jag is offline   Reply With Quote
Old 01-11-2007, 07:18 PM   #973
Originally Posted by jeff1
Hey dom
thanks
Jeff,
I felt I have a better modulation on the brakes. Guys were complaining the brakes were like on/off switch with the WCE. That's the "performance" benefit that I had. Other than that, it's just so much easy to work and clean the car.
Dom
Old 01-12-2007, 01:56 PM   #974
gunna do's Avatar
Default roll centers
Alright all you gooroos out there have a bit of confusion here.Can someone please explain to me a little about roll centers,so i achieve satisfactory results on high &low traction tracks,aswell as large,medium & tight tracks.
P.S. can anyone tell me where to find setups for the RRR EVO that the top Kyosho drivers were using at the worlds in Brisbane.
BLITZ BODIES,FUTABA 4PK,CAPRICORN LAB C02,ATS TYRES,CAPRICORN SQR ENGINES,PROTOFORM SRS N BODIES.
gunna do is offline   Reply With Quote
Old 01-12-2007, 02:45 PM   #975
Sp Racer's Avatar
Front -
Dark blue spring - kit piston - 550 oil - 11 ackerman - spool - roll center "B" up - carbon shock tower mounting 1st hole in from outside - caster in the middle - 1.5 deg neg camber, 2 deg toe out - swaybar full flat ( softest)
Rear -
Dark blue spring - kit piston - 500 oil - camber link mounted lower inner hole - 2mm spacer outer - roll center "B" up - shock mounting 2 holes in from full vertical - either blade sway bar full flat or black wire sway bar - rear diff 30k filled to the spider gears - 4 deg neg camber, 3 deg toe in -longer rear universal joints were used without the 2mm axle spacer (allows the use of 2mm offset wheels) - 23 t side pulley & 2mm split - 58/56mm tyre diameter
Sirio STI gearing - 17/61 ~ 22/55 - 0.9mm spring pre load, 0.6mm clutch end play
hope this helps!
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
