Old 12-07-2006, 07:01 AM   #766
GMartinez's Avatar
Trader Rating: 85 (100%+)
Originally Posted by ianhobbies
NEW VONE RRR EVO PART RELEASED
VZW223
THIS WAS USED BY THE FACTORY DRIVERS IN THE RECENT WORLDS
Checked the kyosho site the part # is not listed yet
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 12-07-2006, 08:06 AM   #767
fritzD's Avatar
Send a message via Yahoo to fritzD
Originally Posted by dameetz
I rebuilt my shocks twice already using vacuum pump (I do take time on this because I want it to be perfect) I even swap left to right shocks just to see if that make the problem. I will check the linkages again today. I wonder if the linkage length from the servo to the steering bellcrank does make any difference? At the moment my servo arm is set 90deg vertical and the rod is set so that the you can see the screw under the hole when you look at from the top of upper deck.
i only had that problem when i was running front tires with both of them having different diameters. hmmm. how about try checking your front width and make sure that each side is of equal length with the other side with respect to the center.
fritzD is offline   Reply With Quote
Old 12-07-2006, 08:59 AM   #768
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
VZW223
hmm...what's the advantage or benefit that one gets using this part?
doki_doki is offline   Reply With Quote
Old 12-07-2006, 03:20 PM   #769
robert maestrey's Avatar
Also make sure your epa is correct on your radio....maybe the throw on your servo is more to one side then the other..hope this helps
Sippin Coladas and Chillin
robert maestrey is offline   Reply With Quote
Old 12-07-2006, 03:24 PM   #770
looks like the advantage is maintenance....you will be going from a plastic pulley sitting on a pin that will wear to a pulley attached to a pulley adapter then fastened onto the shaft via a set screw..
Old 12-07-2006, 03:29 PM   #771
Originally Posted by Mcfly
Grinder or anyone else im just still a little confused on where to make the changes for roll center on the front and rear of car, attached is couple of pics, on front where do you normally change rc A or B (or some where else if im wrong).
and rear C,D or E. and same as above please let me know if im way off the mark. thanks marty
Front you have A to adjust roll center.....
Rear C D E all have certain affect on your roll centers when adjusted....
hope this helps.....
Old 12-07-2006, 07:50 PM   #772
dameetz's Avatar
[QUOTE=ianhobbies]NEW VONE RRR EVO PART RELEASED
VZW223
THIS WAS USED BY THE FACTORY DRIVERS IN THE RECENT WORLDS[/QUOTE
Looks like pulley from my Evolva.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 12-07-2006, 07:52 PM   #773
dameetz's Avatar
Actually my EPA is more to the right about 96% than left 82%.
Old 12-08-2006, 05:50 AM   #774
etgdpu's Avatar
Hi,
Try to achieve almost 0 subtrim by adjusting the length of the bar (which connects the servo arm with the servo saver) and try the servo arm to be located vertically when the wheels are centered. If not, dettach it and attach it to another position. Then verify that the arm and the bar do not touch anything when they move.
After you achieve the correct center position you can set the EPA correctly.
The intelligent can become anyone, anyone can not become intelligent.
etgdpu is offline   Reply With Quote
Old 12-08-2006, 09:26 AM   #775
doki_doki's Avatar
thanks the evo kit came with a 21T aluminum pulley where the brake pins are also attached to it and is held in place to the main shaft with a set screw. i can't really picture out how this new part is gonna be used
Old 12-08-2006, 04:18 PM   #776
GMartinez's Avatar
if you look on the main shaft there is a extra slot set for the new pulley
Old 12-08-2006, 04:51 PM   #777
bvoltz's Avatar
Trader Rating: 44 (100%+)
Default Rear offset for tires...
I have purchased 0 offset tires... Jaco... I know this was the wrong tires for this car, but has anyone ran these? What can I expect? I see I need to trim off 1mm to 2mm on the inside in order for it to clear the links... Anything else I need to be aware of? Of should I just toss them and get 2mm offset?
bvoltz is offline   Reply With Quote
Old 12-08-2006, 06:56 PM   #778
Gambelli's Avatar
Hi There,
I have run 0 offset tyres without problem, they dont seem to rub!
For the record, I bought the longer rear unis, the VSW007 (or something like that) and they are really good as the dogbone is the same length but the axle is longer and it comes with a 2mm spacer for each side, so you dont have to change the geometry to go between the standard and wide uni's.
I bought them for about $20us from RC Champ in Japan, well worth doing if you want to run 0 offset tyres...
Steve
V1RRR Evo WC w/ TZ
V1SIII Kyosho Cup Edition 2 w/ GXR 15
Gambelli is offline   Reply With Quote
Old 12-09-2006, 06:20 AM   #779
doki_doki's Avatar
i could see the slot. is the pulley aluminum? from the looks of it, it looks like it is made of plastic material. i might be wrong
Old 12-09-2006, 06:23 AM   #780
doki_doki's Avatar
i have also tried using the jaco 0mm offset tires for the rear. the problem now is that you will have difficulty running the car with the 200mm trackwidth. if you get the 2mm offset, it is much easier. no more trackwidth to adjust. another thing that you can do is to put 2mm spacers between the rear hub and the 0mm offset wheels. this gives you an additional 2mm width on each side so as to meet the 200mm trackwidth hope this helps
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
