Old 11-29-2006, 03:35 AM   #736
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
Originally Posted by boy2rc
About usd18.
thanks
doki_doki is offline   Reply With Quote
Old 11-29-2006, 08:50 AM   #737
bvoltz's Avatar
Trader Rating: 44 (100%+)
New stuff - SP Front Spoie Shaft
Any place to get them in the US?
bvoltz is offline   Reply With Quote
Old 11-29-2006, 09:20 AM   #738
robert maestrey's Avatar
Pnp Hobbies.....Palm bay, Florida....has full stock of Kyosho parts
www.pnphobbies.net check them out they carry everything youll need.. #PH: 321-723-7318
Sippin Coladas and Chillin
robert maestrey is offline   Reply With Quote
Old 12-04-2006, 05:43 AM   #739
doki_doki's Avatar
Default v1rrr evo
i finally installed the kfactory aluminum servo mounts i just got mad when the screws that came the the kfactory aluminum servo mounts were too short i had to look for the right length of screws so that i could install them oh well, what's done is done...
Old 12-04-2006, 06:31 AM   #740
doki_doki's Avatar
Default v1rrr evo
got these kyosho upgrade parts:
kyosho aluminum brake lever
kyosho SP belts (front, middle, rear)
kyosho lightened clutch bell
will install them when i find time
Old 12-04-2006, 06:39 AM   #741
doki_doki's Avatar
i also have the following kawahara and kyosho parts that are waiting to be installed:
kawahara aluminum wheel hubs (wide)
kawahara side brace
kawahara brake bracket
kawahara steel 2nd pinion gear (21T)
kyosho steel 1st pinion gear (16T)
Old 12-04-2006, 09:46 AM   #742
Grinder's Avatar
Default RRR EVO Track Test
I tested the RRR Evo WC with front solid yesterday. Compared to the RRR WC the EVO seemed to have more steering, yet it was planted very well still. Maybe the front shock pistons with 2 holes contributed to this. I had to take away some steering with kit tires. I made the front bar stiff, and the rear bar flat. This helped. I then put my rear shocks in the second to bottom hole. The car was money. I was able to take the sweeper full throttle, the car transitioned very well through the chicane. The Evo seems to me to be a little more nimble than the regular RRR.
On another note I tried the Kyosho Torsion Diff for the RRR. The diff works by locking up the wheel that is loaded. If you are turning right the left rear gets all the power so the right rear does not unload. I found the diff to be very unpredictable through the switchbacks. In the sweeping turns the car was extremely stable, and almost pushed, whereas with the standard diff the car would rotate on around under hard acceleration. I will have to play with it some more, but laptimes were definitely slower with the torsion diff.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 12-04-2006, 05:21 PM   #743
huskerfreak's Avatar
Do have an over all setup that you can post. That would be great if this is good setup than it might work for others to try. Also what are you track conditions like. high low bumpy smooth thanks for anymore info you can give.
huskerfreak is offline   Reply With Quote
Old 12-05-2006, 06:41 AM   #744
Grinder's Avatar
I just used my standard base setup.
Front Camber -2.5 R&L
Rear Camber -3.5 R&L
Ride Height F=4mm R=5mm
Track Width F=198 R= 199
Rear Toe in = -2.5
Front Toe Out +1.0
Front Shocks all the way down
Rear Shocks One hole from bottom
Stock Evo shock pistons and springs
Solid Axle in front
30.000 oil in rear diff
Ackerman = 11
Outside bottom rear camber link ( I want to play with this still)
Stock Gearing
Rear Roll Cernter One up from bottom
Front Roll Center One down from top
Front Swaybar verticle
Rear Swaybar Flat
Stock Castor
Stock Droop
Basically that is it. I would like to try the white springs. I always seem to like the stiffer springs. Seems to make the car more direct most tracks as long as there is decent traction. The Stock red brakepads felt very good. I have the APP, but I don't see the need as of now. I used the Modified LS3 engine. The power comes on very smooth. The car is easy to control out of the corners with the LS3. Works good with my trigger finger. I was using the 2630 with short header. The medium header will really make this engine pop of the line, but traction was meduim to low so no need.
Old 12-05-2006, 08:52 AM   #745
Big Jeff BBQ's Avatar
Why do you have to do so much to this car to make it fast.
its just me Jeff just stiring it up with you.
later
Jeff
Blowin' Smoke BBQ
Special Thanks To:
Steve Pitts
Kevin Hutchinson
Big Jeff BBQ is offline   Reply With Quote
Old 12-05-2006, 12:59 PM   #746
Sp Racer's Avatar
Hey Grinder, my setup is almost identical -I run the rear roll 1 down from top Give the top middle hole a try
You might like to try the Kyosho TCD diff with std silicone oil rather than that smelly black stuff they come with - start with 10k.
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
Old 12-05-2006, 01:31 PM   #747
VoneS3Kid's Avatar
Send a message via MSN to VoneS3Kid
Hey Lue and Guys, what effect does changing your steering ackerman on your servo have?
Team Xray/HUDY/Custom Model cars/HEI International/Fantom/Much-More/JACO/Kelletts Hobbies/Max Power/Ko Propo.
VoneS3Kid is offline   Reply With Quote
Old 12-05-2006, 01:35 PM   #748
VoneS3Kid's Avatar
on your servo saver, sorry..i currently run a 10, what will going higher do?
Old 12-05-2006, 02:00 PM   #749
Sp Racer's Avatar
Shouldn't you be at school? LOL!
I'll talk 2 you tonite on MSN
Old 12-05-2006, 02:07 PM   #750
Grinder's Avatar
I will definitely try the 10k. Thanks.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
