Old 10-13-2006, 03:48 AM   #541
esham's Avatar
Originally Posted by Sp Racer
Nah, started off as a RRR "Evo" , then they swapped over the top deck and fitted the new spool...as soon as the grip came up and cars traction rolled, everyone swapped over to the laydown servo.
Yup that explained why the laydown servo was on. Any yes you bet i did have too much grip once i changed mine to EVO. I change rear tires from 38 shore to 43 ! and let front with 38 shore it still doesn't throw the rear. Seem like I have to work on other setup/tuning now.
esham is offline   Reply With Quote
Old 10-13-2006, 12:46 PM   #542
ITO NIEVES's Avatar
Originally Posted by ziggy12345
Front or rear??
Front, thanks for any information.
CAPRICORN_ Lab C01---- Sirio XXXV.
ITO NIEVES is offline   Reply With Quote
Old 10-13-2006, 08:23 PM   #543
rmdhawaii's Avatar
Originally Posted by dameetz
Has anyone of you tried the SP rear shock tower (VZW 207)? What is the diffence in handling did you notice? From what I can see it has got blue anodized rear bearing cover comes together with it, and the rear inner camber link pivot ball sits upwards instead of towards the front, and it has got 3 holes instead of 5 holes(EVO). Is this better? And what is the effect of having 2mm spacer under the pivot ball?
I would say, that you would probably be better off with the RRR EVO part or this one The VZW207 requires that you modify the camber link ends for proper suspension travel, which is a pain to get perfect. The 2mm spacer allows you to raise or lower the roll center. You can pretty much to the same adjustment with either parts, it's just a matter of how you do it.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 10-14-2006, 09:58 AM   #544
jag
jag's Avatar
Have you tried that KM part yet?
My car is setup similar to the pic from the previous page.
jag is offline   Reply With Quote
Old 10-16-2006, 08:52 AM   #545
rmdhawaii's Avatar
I haven't tried the KM part, but I know a few guys in the forum have purchased it.
The VZW207 offers a lot of flexibility - way more than the RRR Evo or KM part for very fine adjustments, but it just really depends on what a person's requirements are and how much time and effort they can put into making the adjustments. I still have a lot more testing to do with the VZW207 and it is a good part, but the hassle factor for filing that camber link is a big negative for me - especially if you have to do it between heats. It's definitely a custom fit and you actally need to prep a few camber links in advance in case it needs to be replaced. Kyosho really should have a special part for it.
Old 10-17-2006, 05:37 AM   #546
Ice_nl's Avatar
Send a message via MSN to Ice_nl
I also have VZW207 as i was told the shock-tower was stronger, but after a few races the carbon layers where getting loose I put some glue between the layers but after last race the layers at the rear are broken so its now a very flexible shock-tower. Is there something i can do to avoid this splitting of the carbon?
RC-Models.nl | Shepherd Velox V8 EC OM-Edition | Shepherd Velox F1 | Buri Racer E1.2 | Tamiya 419x
Ice_nl is offline   Reply With Quote
Old 10-17-2006, 10:59 AM   #547
rmdhawaii's Avatar
I've never heard of anyone having that problem before! I would consider it a factory defect. Contact the guys you got it from and see if they will replace it.
Old 10-19-2006, 06:24 PM   #548
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
what i usually do with all the carbon fiber parts in my evo kit is that i seal it with CA glue i haven't had any problems with the carbon layers splitting after doing this
doki_doki is offline   Reply With Quote
Old 10-19-2006, 07:18 PM   #549
esham's Avatar
Guys need help here. I do have problem with my V1RRR Evo, understeer on, off power. Seem too much grip at rear. My current setting is:-
Front/Rear
Dif - Oneway/ 10K - sometime 30K
Shock oil- 40/40
Shock Position - mid/mid
Spring- RRR Evo blue spring front/rear
Swaybar- 0/45
Tires - 38/43 - Did used 40 at rear it make more understeer
Downstop - 0/4mm
Tires Dia - 62/64
Trackwidth- 199/200
Ride Height- 6.5-7.5
Camber- 1.5/3
Toe- 1/-2.5
Body- Mazda 6
Track Traction - mid
Anything wrong here? I start thinking to change back to laydown servo where i got hang on it. Welcome and Thanks for your opinion
Old 10-19-2006, 07:45 PM   #550
rmdhawaii's Avatar
I would say... Try 40 shore in front. If that doesn't work, go 20K or 30K rear diff. Have you tried running 40s on all fours?
Old 10-19-2006, 07:53 PM   #551
esham's Avatar
Thank you rmdhawaii, Yes i tried 40s all around but still much u/steer. And yes i going to increase the rear diff back again.
Old 10-19-2006, 08:55 PM   #552
robert maestrey's Avatar
Front/Rear
Shock oil- 40/40
Swaybar- 0/45
Downstop - 0/4mm
Tires Dia - 62/64
Trackwidth- 199/200
Camber- 1.5/3
Toe- 1/-2.5
Body- Mazda 6
try less toe-in in the rear...also try little more front camber like 2.5...heavier diff oil.....also try 0/3 downstop.....lower your ride height 5-4 and use flat front sway bar....
Sippin Coladas and Chillin
robert maestrey is offline   Reply With Quote
Old 10-19-2006, 09:37 PM   #553
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default hmm
like mentioned i would flatten the sway bar first & try it out but try one step at a time like in ROBERTS Post see how it works out send back some results good luck
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 10-19-2006, 10:10 PM   #554
esham's Avatar
rmdhawaii,robert,soloartist...hei, thanks man. i will give a try and how it turn up.
Old 10-20-2006, 07:22 PM   #555
doki_doki's Avatar
Default v1rrr evo
finally the stuff that i ordered arrived. can't wait to install them
kfactory aluminum servo mounts and special rear mount
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
