Old 09-03-2006, 08:44 PM   #316
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
Originally Posted by fritzD
The 387 drive belt along with the 24t pulley has a very loose tension for the belt, no matter how you adjust the belt tensioner. This is what I observed from two RRR users in our track. I use the stock set-up.
i see thanks i know oca is running the 24T 387 belt combo. who else is running it?
doki_doki is offline   Reply With Quote
Old 09-03-2006, 08:50 PM   #317
doki_doki's Avatar
Originally Posted by jeff1
Sorry guys, I explained wrong
My RRR is a Rubber Version, and came with 387 belt and 24t pulley. I placed the tensioner all down, and it's still loose. When I hit the brake the belt jump from the pulley, and make a sound like tic tic tic.
A friend solve this problem using the 384 belt, and now it's okay
I'm using the tensioner from WCE
will try this one out if it works
Old 09-04-2006, 04:00 AM   #318
fritzD's Avatar
Send a message via Yahoo to fritzD
bons "xbeta"..
fritzD is offline   Reply With Quote
Old 09-05-2006, 05:23 PM   #319
doki_doki's Avatar
bons "xbeta"..
thanks
Old 09-08-2006, 09:05 PM   #320
kewdawg's Avatar
Originally Posted by rmdhawaii
VZ113-59B 1St Spur gear 59T
VZ113-60B 1St Spur gear 60T
VZ113-61B 1St Spur gear 61T
VZ114-55B 2nd Spur gear 55T
VZ114-56B 2nd Spur gear 56T
Thanks.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 09-09-2006, 05:32 AM   #321
maskedrider's Avatar
here's a picture of the new machined aluminum 21T drive pulley with new brake hub (3mm pin type) similar to the design of the v1r, v1rr, v1rr evo models. also noticed the the brake disc is smaller compared to the older v1r series. i placed a small spring in between the 2 brake pads to help the pads disengage faster after using them
are you using the option parts soft Brake pad?? better ?
Kyosho- Sirio/ OS engine- AVID bearing- Blue thunder fuel- Proline- RC dynamite- Sanwa- RC Art
maskedrider is offline   Reply With Quote
Old 09-09-2006, 07:25 AM   #322
ianhobbies's Avatar
Location: Costa Del Sol, Marbella, Spain www.bradir.net
Send a message via ICQ to ianhobbies
Default doki
doki : have u tried our old v1 RR disk brakes on the evo? how about you fritz? coz i have an old kfactory brakes for the RR which uses 2 pins like the one in the evo
WWW.BRADIR.NET - The Radio Control Motorsport Blog! / twitter @ianhobbies
ianhobbies is offline   Reply With Quote
Old 09-09-2006, 07:29 PM   #323
fritzD's Avatar
haven't tried but i think it'll fit.
Old 09-09-2006, 07:33 PM   #324
fritzD's Avatar
IFMAR qualifying standings
http://www.200mmifmarworlds.com/Default.aspx?tabid=329
Tossilini is in 1st and Cyrul in 4th. Defending champion, Bertin hasn't run a qualifying heat yet. Shimo and Spashet are not in the race.
Old 09-09-2006, 07:46 PM   #325
Trader Rating: 13 (93%+)
qualifying doesnt start till tuesday.. those time are just practise runs..
most drivers use their own transponder/timing equipement till then thats why u havent seen any otehr times yet
we gotta wait till tues
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 09-09-2006, 07:50 PM   #326
fritzD's Avatar
ohhh... sori for the misunderstanding.. hehehehe
Old 09-10-2006, 07:43 AM   #327
here's a picture of the new soft brake pads included in the kit (it's colored red). i hope i will not experience brake fade much often compared to the wce
hows the brake pads going so far ??? Any brake fade... ?
Old 09-10-2006, 07:47 AM   #328
doki_doki's Avatar
the brake pads are way much better compared to the older one. much consistent braking with this one
Old 09-10-2006, 07:50 AM   #329
doki_doki's Avatar
was about to use the team kyosho shimo brake disc for the v1r/v1rr/v1rr evo on the v1rrr evo while i was assembling it and found out the that brake disc was bigger in diameter compared to the one that came along with the kit. you might have some clearance problem with carb if you use that..
Old 09-10-2006, 07:54 AM   #330
fritzD's Avatar
none so far.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
