Old 09-27-2008, 05:10 PM   #3106
shesha's Avatar
Send a message via MSN to shesha
Just logically speaking, seems like everyone is mixed up about the offset terminology.
Offset of 2 means that your rear end is shorter, thus you need large wheels to be 200mm thus increasing the axles length.
Or something else???
R.C.C.C.K - Team Kuwait
shesha is offline   Reply With Quote
Old 09-27-2008, 11:28 PM   #3107
GMartinez's Avatar
Trader Rating: 85 (100%+)
Originally Posted by shesha View Post
Just curious as I have never swapped out the stock diaphragms, what is the difference between different coloured ones and how do they come into play for track setup....
the ivory color diaphrams is way to soft stick with the stock black which are softer than the WC nipple style.
majority of the time depending on softness the diaphrams change the rebound
Harder quicker rebound
softer slower rebound
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 09-29-2008, 07:22 AM   #3108
Sal Amato's Avatar
R/C Tech Charter Subscriber
Trader Rating: 26 (100%+)
does anybody know the part # for a complete front diff
360 RC SPEEDWAY 2.0
AWESOMATIX USA-SANWA--BSR--TEAM SCREAM --SWEEP RACING USA--TQ WIRE--ROCHE USA--LRP
Sal Amato is offline   Reply With Quote
Old 09-29-2008, 08:02 PM   #3109
GMartinez's Avatar
SAL HERE IS WHAT YOU NEED
VZ012 DIFF GEAR SET
BS107 BEVEL SHAFT
VZ203 PULLEY SET
VZ204 DIFF PULLEY SET
VZ218 DIFF JOINT
Old 09-30-2008, 02:58 AM   #3110
Sal Amato's Avatar
THank YOU
360 RC SPEEDWAY 2.0
Old 09-30-2008, 06:15 AM   #3111
MikaR's Avatar
What kind of oils you are using with front & rear diff on foams ? evo or evo 2
MikaR is offline   Reply With Quote
Old 09-30-2008, 04:08 PM   #3112
GMartinez's Avatar
50,000 front 20, or 30, rear depending on traction
& some also use 100,000 front to get the same feel of a spool
Old 10-01-2008, 12:23 AM   #3113
MikaR's Avatar
OK, thanks a lot. I put 60K front and 30K rear. May need to change the rear for lighter, but I'm going to first try my WCE with the front one-way (the kit setup that is).
http://modelcartuning.simplesite.com/
Old 10-01-2008, 12:54 AM   #3114
CraigM's Avatar
Trader Rating: 34 (100%+)
Has anyone had issues with their brake cam binding in the bulkhead? I took the cam out and sanded it lightly which helped but it still binds occasionally and I'm just wondering how to solve this permanently
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 10-05-2008, 02:19 PM   #3115
tanisg's Avatar
Send a message via MSN to tanisg
Hi I want your help for my carís set up..I would like to try softer springs than the blue ones thath are in the kit,can you suggest me which springs to try?Something else,in case I use lighter oils into the shocks what difference will I see and what if i use harder.Thanks a lot.
tanisg is offline   Reply With Quote
Old 10-05-2008, 06:36 PM   #3116
The older gold rears and black fronts are a good starting point for springs if you have exhausted the blue's. I basically always run 500wt in the shocks and only change it about yearly because the shock angle can more or less take care of this for you.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 10-31-2008, 05:34 AM   #3117
GSPOT's Avatar
Trader Rating: 62 (100%+)
Send a message via AIM to GSPOT
Exclamation
the plastic adjusters for the front belt that holds the bearings, what exactly holds thos in, i had one pop out last race and it seems that they sit in there. is that right? (diff area)
VTA member #126
GSPOT is offline   Reply With Quote
Old 10-31-2008, 06:43 PM   #3118
the circles with the triangle on them? they just sit in there locked in the same position left and right to set your belt tension. you must have hit something pretty hard :P
Old 10-31-2008, 08:36 PM   #3119
GSPOT's Avatar
i did!
thanks man
VTA member #126
Old 11-11-2008, 02:59 AM   #3120
Alex Siddique's Avatar
Trader Rating: 30 (97%+)
Send a message via MSN to Alex Siddique
hi ,
what the advantage of using a 2d clutch over a stock 3d.
any info would be a help .
cheers alex
No Fucker's Taking my money O/s OR local :) :)
Alex Siddique is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
