Old 09-07-2008, 10:59 PM   #3091
Yes I do have the original packaging which simply has the part numbers etc on it. I have an old copy of cluth set up from Josh Cyrul. I will check to make sure the shoe isn't sticking. What settings do you run your sirio clutch at? I'm spinning the bell and spacing up until it doesn't drag and then spacing up .40 for final gap and then adjusting enplay so there is only about
.10 at most? Any suggestions? Thanks for the reply.
bradley70 is offline   Reply With Quote
Old 09-07-2008, 11:07 PM   #3092
shesha's Avatar
Send a message via MSN to shesha
I'll check on it for you tonight, it ran real nice at the last race.
R.C.C.C.K - Team Kuwait
shesha is offline   Reply With Quote
Old 09-08-2008, 06:25 AM   #3093
shiston's Avatar
Hi,
Whats
's the difference between the acre and app brake pads?
shiston is offline   Reply With Quote
Old 09-23-2008, 07:51 PM   #3094
shesha's Avatar
I have 0.12, but that is the read after the race, so it should have been 0.10
Sorry took so long been so busy just got round to it today...
Old 09-23-2008, 07:54 PM   #3095
shesha's Avatar
Quick question RRR lovers.. on the old RRR the tire had to be offset, on the WC it's with 0 offset, I know there was an article previously on a website about this anyone recall the link....thx...
KB something.... tells you the major difference, i do know it plants it's rear much better having 2 offset on the back....
Old 09-23-2008, 08:07 PM   #3096
shesha's Avatar
Originally Posted by GMartinez View Post
the only difference I see for the exploded view is the siim engine is not sti modified black coating on the crank modified sleeve is the same other than that the new evo4 comes with ceramic bearrings
The major difference is the mod on the engine, SIIM repacks the SIRIOS and has the modded as per their performance standards, they are impressive.
After the final both cars were temped in at 231 and 228, and the pace was up with the the latest GRP .12 engine who was running at 250+, we personnaly preferred cooler running engines, and less nervous throttle responses where most guys were hitting above 270+.
I'll get a picture of the sleeve, for comparison to the stock sirios..
Old 09-23-2008, 08:37 PM   #3097
Default V ONE RRR WC
I posted in the wrong section, so I'm going with it here. I had the drive cup on the front one way pop out twice in my 1st racing day with this car (new). The book says I'm using the VZW054 universal swing shaft (black) It looks like the shaft is setting far enough into the drive cup 1/3 that it wouldn't be able to pop out. I did catch the pipes several times, but didn't break anything. I was told to try the longer shafts VZW219.
Any other opinions or ideas
Thanks Zurk20
zurk20 is offline   Reply With Quote
Old 09-23-2008, 08:51 PM   #3098
Thanks Zurk20
You wouldn't believe how much plastic and even hinge pins can flex without breaking when you hit a pipe/board at 20+mph or even faster.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 09-25-2008, 09:33 PM   #3099
shesha's Avatar
Zurk like the previous posts mentioned, o rings in the cups to keep things in place or have them swapped out with K factory adjustable shafts, that way you can vary the length....according to your needs....
Old 09-25-2008, 10:28 PM   #3100
shesha's Avatar
Didnt anyone post any of the Tq's setup sheet for the WC race... or the final ?
Would be interesting to see what the guys were running...
Old 09-26-2008, 07:55 PM   #3101
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Speedypeterb
can someone give me rear universal part # thanks
Speedypeterb is offline   Reply With Quote
Old 09-27-2008, 04:56 AM   #3102
shesha's Avatar
Just curious as I have never swapped out the stock diaphragms, what is the difference between different coloured ones and how do they come into play for track setup....
Old 09-27-2008, 05:54 AM   #3103
kewdawg's Avatar
#VZW054 Universal Swing Shaft
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 09-27-2008, 01:07 PM   #3104
thanks for part# what is the vzw007 universals for
Old 09-27-2008, 02:26 PM   #3105
kewdawg's Avatar
The axles are longer, which allow you to run zero offset wheels/rims (standard wheels). The others universals require the use of 2mm offset wheels/rims.
Quinn Moon
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
