Old 07-29-2008, 05:06 PM   #3016
JayL's Avatar
There is a post around here somewhere by Mr. Ron Atomic stating how he runs tight mesh...
JayL is offline   Reply With Quote
Old 07-29-2008, 06:18 PM   #3017
GSPOT's Avatar
Trader Rating: 62 (100%+)
Send a message via AIM to GSPOT
Exclamation
anybody know how to safely seperate a 1st speed pinion off of a sirio clutch bell....i cant seem to get it off with the kyosho tool(it wont line up) and i dont want to use the plier method that can hurt it!
help
VTA member #126
GSPOT is offline   Reply With Quote
Old 07-29-2008, 07:12 PM   #3018
Team Kamikaze's Avatar
help
It should line up, with the Sirio bell you have to use Kyosho pinions correct? then Kyosho tool on a kyosho pinion should line up perfectly.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 07-29-2008, 07:19 PM   #3019
GSPOT's Avatar
the pinion part works fine, its the other part that helps you lock the clutch from spinning in your hand. there are 2 ends to it but the one with the bump out still does not line up! any ideas?
VTA member #126
Old 07-29-2008, 07:29 PM   #3020
GSPOT's Avatar
i got it!, i used that small piece of "piano wire???" that came with it and a pair of pliers to get in there to lock the clutch so i could spin the pinion gear off!
VTA member #126
Old 07-29-2008, 07:32 PM   #3021
There you go!
Old 07-29-2008, 08:18 PM   #3022
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
A friend of mine grinded the clutch bell holder (Kyosho Pinion Remover tool) so it would fit the sirio clutch bell.. Hope this helps...
JayL, gonna try and search this thread backwards to see if I can find it... Thanks.
Do you guys have any play in the main shaft? Is this good or bad?
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 07-29-2008, 08:35 PM   #3023
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
As stated earlier, I also had to grind the Kyosho tool a small amount to make it fit the Sirio clutch bell. Fits just fine now.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 07-30-2008, 02:42 AM   #3024
barg's Avatar
Send a message via Yahoo to barg
Originally Posted by Deebs View Post
I was plagued with stripped gears during last years FORGASS season. I would go thru anywhere from 3 to 6 gears in a 2 day race week-end. Very Fustrating - especially when you have tried everything!
The lasted thing I tried was meshing the gears very tight. As soon as it loosen up a bit, I remeshed them tight again. It is a bit noisy but it seems to work . . . for now
The mesh has to be tight. No play at all. Loose enough to allow the gears to spin though. If they are a little noisy it doesnt matter as long as they spin freely.
I had the issue of stripping gears a few months ago. Was happening on both my cars and I changed everything. Chassis, Brace, Gearbox, shaft, clutch, engine. You name it.
As soon as I started meshing the gears with no play at all it stopped my stripping straight away.
It cost me about 10 gears to figure this out and a few hundred in other parts......
Hope this saves you a few bucks.
XRAY NT1-2015 Spec | Max Power Engines | KO KIY EX10 | Protoform | Matrix Tires | XRAY X12-16
HEI International | www.hobbyexpress.com.au
www.nswrcrcc.com
barg is offline   Reply With Quote
Old 07-30-2008, 04:10 AM   #3025
ianhobbies's Avatar
Location: Costa Del Sol, Marbella, Spain www.bradir.net
Send a message via ICQ to ianhobbies
Default mesh
a good mesh and loctite is the only solution! i had 5 consecutive races with 1 hour mains with no issues! but if you often crash hard on the race that's a diff. story..
WWW.BRADIR.NET - The Radio Control Motorsport Blog! / twitter @ianhobbies
ianhobbies is offline   Reply With Quote
Old 07-30-2008, 05:51 AM   #3026
GEO
GEO's Avatar
Send a message via MSN to GEO
Originally Posted by GEO View Post
Could someone help me.. Where can we find kawahara parts..??
Just give me a link
‘hanks..
Nick
GEO is offline   Reply With Quote
Old 07-30-2008, 08:17 AM   #3027
Riketsu's Avatar
Thanks barg... I'll be doing this in the next race... I already checked the 2 speed shoes and made them have minimum play within the 2nd gear housing. I added a shim on the transmission shaft to minimize the play because it was alot, it still has some, but i would say it has the same play as the mid-shaft has. I changed the bottom screws to the screws I was talking about earlier of the antiroll bar but they are dremelled so its pretty easy to take em off and torque them into place with a flat head screw driver... I'll let you guys know how it went on the next race.
Thanks for all the help and support, keep it up guys...
Old 07-30-2008, 08:19 AM   #3028
Riketsu's Avatar
Anything in particular your looking for??? Kawahara parts are very hard to come by... Have you tried googling what you want?
Old 07-30-2008, 09:20 AM   #3029
Perez's Avatar
in 1/8th it was really important to have a little back and forth play on the main shaft to save the second gear. Rich Brown told me that and since then I have been wearing gears normally. Also replace all the bearings. Once, the crank shaft on my motor was bent and well there's nothing you can do!...
Perez is offline   Reply With Quote
Old 07-30-2008, 09:27 AM   #3030
http://www.msrproduct.com/vonerrr.htm
thats about the most complete kawahara list i can think of, not that you can get most of them though.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
