Old 08-29-2006, 10:10 PM   #286
litespeed-dom's Avatar
oh man, last time I ran a Serpent Impulse with rubber tires, that was like 5 years ago!
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 08-30-2006, 02:25 AM   #287
BerNardLee's Avatar
Default Softer spring compare to RRR
Noticed that the spring is much softer than the RRR...
My understanding is softer spring is good for bumpy or small track, not sure is it suitable for high speed track like the coming host track for IFMAR world race at Brisbane?
BerNardLee is offline   Reply With Quote
Old 08-30-2006, 03:17 AM   #288
maskedrider's Avatar
Hey Dom.... any advantage and disadvantage of using the Alum 18t Pulley ? thinking of changing to that as plastic pulley indeed worn out pretty fast...
Any things that i need to take care of if using the alum 18t pulley
Kyosho- Sirio/ OS engine- AVID bearing- Blue thunder fuel- Proline- RC dynamite- Sanwa- RC Art
maskedrider is offline   Reply With Quote
Old 08-30-2006, 04:15 AM   #289
ianhobbies's Avatar
Location: Costa Del Sol, Marbella, Spain www.bradir.net
Send a message via ICQ to ianhobbies
Default rubber
Dom
when i had my first experience on foams 5 yrs ago, i haven't used rubber tires since then.. and i will never go back to rubber again
doki: is there any plans ur local track will be switching to asphalt? it's been a while..
WWW.BRADIR.NET - The Radio Control Motorsport Blog! / twitter @ianhobbies
ianhobbies is offline   Reply With Quote
Old 08-30-2006, 04:26 AM   #290
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
ianhobbies: not sure if there are any plans. hopefully the members are taking this into consideration i'm leaving for florida in a while so i'll be excited to run asphalt then. will it be possible to run foams on cement?
doki_doki is offline   Reply With Quote
Old 08-30-2006, 04:32 AM   #291
doki_doki's Avatar
korevo: bradir, can you post close-up pics of the hobao receiver protector you installed on you v1rrr evo? is there any modifications needed to install it? thanks
Old 08-30-2006, 05:33 AM   #292
fritzD's Avatar
Send a message via Yahoo to fritzD
Originally Posted by etgdpu
Hello all,
I would appreciate if you helped me with a small problem I am having with my RRR to EVO conversion. The main shaft "seems" like it is a little longer, because there is a gap a bout 1.5mm. If I move the 2 speed all the way towards the right block then the gap it is eliminated and the whole shaft does not move left and right but then the gap appears between the 2 spur gears. The first gear can move left and right. If I move the 2 speed away from the right block to eliminate the gap between the spurs then the gap appears in the whole shaft, which moves left and right.
What am I doing wrong?
i also notice this on my RRR wce before. What i did was that i shimmed the gap off just enough that there will be no play with the spur gears. I did the same to my RRR evo.
fritzD is offline   Reply With Quote
Old 08-30-2006, 06:28 AM   #293
doki_doki's Avatar
hmmm didn't notice that while i was working with my wce back then as well as with the evo. all seems to be in place
Old 08-30-2006, 08:23 AM   #294
korevo's Avatar
Bradir,
It's a direct fit no modification needed like plug n play!!! fits my WCE also
korevo is offline   Reply With Quote
Old 08-30-2006, 05:42 PM   #295
doki_doki's Avatar
Originally Posted by korevo
Bradir,
that's great no more hassles then. just bolt it right in by the way, do i have to take out the receiver holder that came with the kit or just add the hobao receiver cover thanks
Old 08-31-2006, 02:49 AM   #296
etgdpu's Avatar
Finally, I shimmed it too.
Thanks everybody
The intelligent can become anyone, anyone can not become intelligent.
etgdpu is offline   Reply With Quote
Old 08-31-2006, 06:03 AM   #297
ianhobbies's Avatar
Default foams
it is possible but brace yourself for the wear... hehehe
Old 08-31-2006, 09:23 AM   #298
The advantage is that the inside of the plastic pulley won't explode and the pin just keep spinning inside of it. I have had that happened in a Main before and I was with front wheel drive only with 4 mins to go.
The disadvantage... not much actually. I remember when Team Magic first hit the US with aluminum pulley and a friend of mine was the importer at the time and gave me a set for my 1/8th scale, it was cool at that time since no one made alu pulleys, but the downfall is that the teeth becomes way sharp after a couple hours of running and actually cutting your belts in 1/2. Now with the Kyosho aluminum 18T pulley, I have logged about 6 hours of racing and the teeth is not getting sharp at all, which is a pretty amazing thing!
As for weight... you can't tell a difference.
I would recommend the Kyosho aluminum pulleys.
Dom
Old 09-01-2006, 02:26 AM   #299
doki_doki's Avatar
hehe...i'll keep that in mind
Old 09-01-2006, 02:33 AM   #300
Thanks Dom.....will give a shot for that...
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
