Old 07-08-2008, 11:13 PM   #2956
Originally Posted by Brian Bosley View Post
The deal with that and I saw this on Jerry Lin's (JLR himself) car, you can grind the round portion of the flange flat which gives you an extra few mm, but yeah you just have to deal with it because of the IDM/Picco header. I usually put replacable stickers on the outside of the car and some of the losi heat tape on the inside.
The stinger should be easy to keep inside of the wheels though by using the mount, keep it 1mm inside the front wheels to protect it from impacts.
His name is Jeffrey not "Jerry"
Jose Luis
JL RACING is offline   Reply With Quote
Old 07-09-2008, 01:59 AM   #2957
kewdawg's Avatar
I believe Ron Atomic told me that specific car was too fragile because it wasn't built to run, it was just quickly machined for pictures.
I was at the kyosho us sedan championships in florida the week before, and Joel Johnson didn't even have the evo2 but they had it at the booth at RCX. Clearly he would have been testing it at such a large event if it was possible.
This was two months ago though, the car is probably completely different than the one I saw.
So, it was a prototype. There's a big difference there. You could have run a lot of racers away with that previous statement. Please be more specific next time.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 07-09-2008, 10:49 AM   #2958
Good catch on Jeffrey Lin's name I was thinking about talking to a Jerry while I was typing that, I wouldn't want to disrespect a man that has been bringing fast, affordable motors back into the hands of the general public. Before the red dot, it was basically the TZ for 150, or the 12-3ct for over 300..
kewdawg: I believe I said that specific car was too fragile because it was quickly machined for pictures.. I thought people would understand that meant pre-prototype, sorry about that as well.
Clearly the new car is being tested by Shimo at various tracks with success so it should be as strong as the new car. They're really only changing the chassis and top deck, and I've only seen those break under extreme circumstances so I doubt the overall durability of the car will change. The additional thickness in the rear shock tower is a bit of a bonus though I will admit because I ran two for a year or so and just recently went back to running one.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 07-09-2008, 11:39 AM   #2959
TheeMikeCee's Avatar
I understood what you said Brian.
TheeMikeCee is offline   Reply With Quote
Old 07-09-2008, 02:55 PM   #2960
What Happen Jerrffy..HAHA
rangulo is offline   Reply With Quote
Old 07-09-2008, 10:20 PM   #2961
kewdawg's Avatar
You didn't run the 3MM rear shock tower with 4 mounting holes Part no. #VZW207-1? I found it to be a lot more durable than the stock rear shock tower.
Quinn Moon
Old 07-09-2008, 10:28 PM   #2962
Team Kamikaze's Avatar
JERKY LIN?
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 07-09-2008, 11:50 PM   #2963
My Case My Case... Look it not straight.... Pick a color Honey
Old 07-10-2008, 06:33 PM   #2964
Has anyone here run the Sirio Power Clutch? If so what are your thoughts, thinking of getting one.
bradley70 is offline   Reply With Quote
Old 07-10-2008, 09:13 PM   #2965
It hits like a hammer, if you don't like that or you run on a slippery track just skip it and go with the 2d because you would have to change the spring anyway. If you have traction, nothing else accelerates quite like it.
I run it everywhere with a 0.5 gap, and on a slippery track I go down to 0.3 which helps a little but the spring is just a beast.
IDM is coming out with a clutch based on the Sirio, but the story is that you get various clutch shoes and some springs for tuning but for $$$. I don't feel that the sirio clutch has enough time to slip because it hits so hard that the clutch shoe doesn't matter to me.
Old 07-10-2008, 09:26 PM   #2966
GMartinez's Avatar
Trader Rating: 85 (100%+)
The IDM clutch is made by Capricorn Myself & another team mate tested the Capricorn clutch & we both had issues there nothing out there that performs like the Sirio power clutch the @d is as close to it & settings are Identical gap,spring tension,endplay
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 07-10-2008, 09:36 PM   #2967
Thanks for the info guys, what spring do you run on it? I have a brand new Orion spring would that work?
Old 07-10-2008, 09:45 PM   #2968
GMartinez's Avatar
Orion spring yes it will you just have to learn to adjust the tension based on your needs it gives you a wider variance that you can't do with the stock spring
Siro spring .05 if you push it harder it has a tendency to collapse
Orion Spring I am currently running between .05 to 1 depending on the track conditions
Old 07-10-2008, 10:25 PM   #2969
Sirio power clutch and IDM Clutch are both made by Capricorn so how would a SIRIO clutch be better?
Old 07-11-2008, 01:42 AM   #2970
mtbkym01's Avatar
Trader Rating: 26 (100%+)
I'm going tp try a front diff in my Evo WC Team (Most guys at my track run diffs in their Mugen's, TM's, AE's). I'm just not sure what weight oil to run. Can anyone recommend an oil, I'm currently running the standard oil (30000) in the rear diff.
~Kym Nuske~
RCHobbyzone.com.au / Model Motorsports International
Mugen Seiki 1/8, Reds, Neo+ Fuels
AE 1/10, Reds
"If it's old skool, it's kool"
mtbkym01 is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
