Old 05-29-2008, 08:36 PM   #2866
huskerfreak's Avatar
Originally Posted by meon99 View Post
where can i get the rear belt for my v1rrrwcTE? i mean online store besides kyoshoamerica.com .... thanks.
The #1 site online for Kyosho parts would be ashfordhobby.com Robert Poage that runs it is the best guy there is to work with when it comes to online websites. He has a great selection of Kyosho parts.
Jamee
huskerfreak is offline   Reply With Quote
Old 05-29-2008, 08:57 PM   #2867
Perez's Avatar
hey guys, just building my evo wc and wanted to say hello! However, im stuck. I cant seem to get the spacing right on the two speed shaft. Instructions call for spacer #38 on the pulley but that leaves for tons of free play on the two speed side. SHould i be using the longer of the two plastic spacers?
thanks guys!
steve
Perez is offline   Reply With Quote
Old 05-29-2008, 09:51 PM   #2868
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
thanks guys!
steve
Try using the longer one. It should do the trick. I assume you are talking about the spacer that goes on the 2 speed shaft between the bulkhead and the side pulley.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 05-29-2008, 10:21 PM   #2869
Perez's Avatar
yup your right scott, thanks!
Old 05-29-2008, 11:08 PM   #2870
Team Kamikaze's Avatar
Don't say that Steve, you are spoiling Scott j/k
You are the best Scott!
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 06-03-2008, 09:25 PM   #2871
Perez's Avatar
just ran my car for the first time last weekend at RCCAR in san jose and it was awesome! I finished in second behind teammate Jimmy Deprez, but got fastest lap!!!
anyways, I had a couple of questions for you guys..
where can i buy a good titanium screw set for this car?
And do they have a titanium or hollowed steel drive shafts for the car?
any help would be greatly appreciated!
steve
Old 06-03-2008, 10:40 PM   #2872
steve
I don't know of anybody that sells a complete titanium screw kit for the K-car. There was a company that did but they don't anymore. There probably is, I am just unaware of whomever that might be. You have a few choices. Buy the Mugen screw kit and have a good start, or just look around and you can find bags of 5 and 10 screws. Buy what you want. I bought some from overseas.
Ybslowinc.com sells an aluminum light weight front shaft for the car. I believe Jimmy even has one on his car (as well as the light spool and maybe even a few other parts). 3 racing makes a titanium 2-speed shaft. I know a lot of people don't trust their stuff. I am one of those people and some of their stuff I would never put onto my car, but the 2 speed shaft has been on my car for a year with no issues. If you get that shaft be prepared to do one of two things. You will either have to use the older RRR plastic brake pulley and brake disc, or you will have to grind a flat spot onto the shaft.
For the first 6 months, I used the aluminum pulley and I just ground a flat spot onto the shaft. I decided to put my car on a diet and switched over to the plastic pulley about 6 months ago. Either way works.
FYI when switching to the plastic brake pulley, you will lighten the drivetrain, you will make changing the rear belt more time consuming, and you will get longer life out of the rear belt..... At least that is what I have found.
Old 06-04-2008, 09:43 AM   #2873
Xray prince's Avatar
Default screw kit
perez.....glad to see more A-class drivers runnin the RRR....more help for me!....I got my titanium screw kit from Atomic....took a while to come...think from overseas.....but well worth the weight......im not goin to say how much im under weight.....thts another forum!
pilot for Kyosho's RRR Evo WC
Ko 2413's....DX3R...JPfx3
Subaru IGT,C5 rody mod onroad,M8
Xray prince is offline   Reply With Quote
Old 06-04-2008, 10:15 AM   #2874
GSPOT's Avatar
Trader Rating: 62 (100%+)
Send a message via AIM to GSPOT
how do you adjust front droop?
VTA member #126
GSPOT is offline   Reply With Quote
Old 06-04-2008, 10:30 AM   #2875
In the front, there are screws that go down through the sway bar mounts and push on the front sway bar.
In the rear there are screws in the rear a-arms that go through the a-arm and push on the chassis.
Old 06-05-2008, 09:28 PM   #2876
fire929's Avatar
Default WCE help
Are th Evo parts upgrade better than the parts offered with the standard v-one rrr WCE
Trex 450
Trex 600
EFL Heli's
Futaba 8fg
Align 3gx
fire929 is offline   Reply With Quote
Old 06-06-2008, 09:12 AM   #2877
mcsquish's Avatar
Scott, you haven't had an issue with blowing out 2nd gear? Or are you setting your gear mesh on the tight side? I tried the K TI 2 speed shaft and kept blowing 2nd gear. Also, I did some searching for a plastic brake pulley, I don't mean to sound like a rocket surgeon, but are you talking about the side belt pulley that is on the 2 speed shaft?
mcsquish is offline   Reply With Quote
Old 06-06-2008, 10:38 AM   #2878
nitrodude's Avatar
I had an issue with blowing second gear, I was lucky if I got 2 runs out of one. I figured out it was the inner clutchbell bearing, the stock one has too much play. Toss it out and get some better quality bearings, I runed the sam gear for 6 months this way.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 06-06-2008, 10:29 PM   #2879
I think I have blown 2 second gears in 17 months. One of them stripped because the engine screws came out (forgot the loctitie) and the other stripped because I forgot to put the bearings into it.... Another brain fart.
The plastic pulley I am talking about is the brake pulley. It is the pulley that goes between the two rear bulkheads. The rear belt rides on this pulley (as well as the rear diff).
Old 06-09-2008, 10:50 AM   #2880
JayL's Avatar
Are you guys running steel pinions?
My driver only got 3 race days out the the alum and they are super sharp, not good for mesh anymore.
JayL is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
