Old 04-18-2008, 10:02 PM   #2791
shesha's Avatar
Send a message via MSN to shesha
Originally Posted by evo1 View Post
G'day Paul
Caster as you describe is 10.5 deg
24t pulley is for zero split between front & rear tyre diameter & uses the 387mm belt.
23t pulley is for 2mm split between front & rear tyre diameter for overdrive & uses the 384 mm belt. Hope this helps
Regards Paul
Hi there, any one would be kind enough to point me to a link that would summarise of the purpose of using split and how to determine it's usage / calculations based on track conditions ?
shesha is offline   Reply With Quote
Old 04-18-2008, 10:04 PM   #2792
shesha's Avatar
Default Sirio Power Clutch manual
Oh i forgot also, am trying to locate the sirio .12 power clutch manual, anyone would be kind enough to point out a link to it or can pdf the file to me ?
Old 04-21-2008, 12:43 PM   #2793
If you have decent bite, 0.6mm on the spring nut, 0.5mm on the gap and 0.1mm on the end play.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 04-21-2008, 08:37 PM   #2794
shesha's Avatar
Thanks brian, actually I needed one for the shop, have a set of them shipped out without manuals for some reason.
Old 04-22-2008, 12:54 AM   #2795
jeff1's Avatar
hey guys I've lost my 2D Clutch manual
I need to buy these
if you guys can help me out it will be great
Clutch Bell
Bell Guide Washer
Clutch Spring
jeff1 is offline   Reply With Quote
Old 04-22-2008, 07:19 PM   #2796
shesha's Avatar
Okay, tried out different settings today on the local rc track, and man can the RRR WC rip, the sirio clutch is lethal, am going to have to go down on the rear diff oil, even though the track is washed down and sugar watered down as well, the rear is breaking loose when hitting the throttle hard out of 90 bends.
Old 04-22-2008, 07:35 PM   #2797
shesha's Avatar
Also forgot to mention the engine, any of you guys on in the state side should try the SIIM PGR S.12 engine, it's a sirio engine on nitrous.
Old 04-22-2008, 07:37 PM   #2798
jeff1's Avatar
Originally Posted by jeff1 View Post
hey guys I lost my 2D Clutch manual
I need to buy these
Clutch Bell
Bell Guide Washer
Clutch Spring
anyone?
I need part numbers of these parts
all of them of 2D Clutch
Clutch Bell
Bell Guide Washer
Clutch Spring
Old 04-23-2008, 01:18 AM   #2799
el salvador's Avatar
Default 2D Clutch Parts
Hi Jeff,
Clutch Bell VZ215
Bell Guide Washer VZ245
Clutch Spring FM432
el salvador is offline   Reply With Quote
Old 04-23-2008, 07:51 PM   #2800
shesha's Avatar
G'day Paul
Regards Paul
Just a reminder on this, anyone can define if a split would be better on low traction or high traction and it's applicability based on having a lock setup in the front diff.
Old 04-23-2008, 11:41 PM   #2801
H4gI's Avatar
We using the CRF clutch. This clutch its mutch better then the kyoshos. There comes a new one with a small flywheel, with the new crf you can use Serpent Clutch shoes as well.
In Switzerland we havent a lot of high grip tracks, we need this clutch for all lowgrip and small tracks.
greetz
Team NFC
LRP
CAP
Nitro-mechanic-bitch of E.D. and R.V.
H4gI is offline   Reply With Quote
Old 04-25-2008, 03:41 PM   #2802
GREGORY!'s Avatar
H4gI can you tell us the weight of the crf flywheel?how much different is it from the stock and the light version of the rrr?
GREGORY! is offline   Reply With Quote
Old 04-27-2008, 09:46 PM   #2803
Can anyone tell me the differences between the 31259K-B V-one-RRR EVO(foam tire car) and the 31260 V-one-RRR EVO WC team edition car?
All the pics I found are all of the same car.
Thanks for the help,
Joe Maxey
Joe Maxey is offline   Reply With Quote
Old 04-28-2008, 07:25 PM   #2804
Talk to kyosho america about that, their is no way someone could have missed the instructions with a clear bag like that.
Here is the scan though
Old 04-28-2008, 07:49 PM   #2805
Joe Maxey
Usually there is nitrokb.com for this but it appears to need domain renewal.
Basically the WC (31260) has hopups that the 59 car doesn't have, titanium shock shafts, hollow center shaft, blade rear sway bar, cvd's that I don't think are in the other car.. I believe at one point Kyosho advertised it was $300 worth of hopups.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
