Old 04-14-2008, 02:33 AM   #2776
LOSI123's Avatar
Trader Rating: 63 (100%+)
Originally Posted by Scott Fisher View Post
It is OK to have the first gear spur and pinion teeth add to a different totals than second.
I raced this weekend using 17/23 pinions and always ran a 60 for 1st but went back and forth between a 55 and 56 second. I normally run the 56.
thanks mate
LOSI123 is offline   Reply With Quote
Old 04-14-2008, 04:24 AM   #2777
I'm having issues with the collet /flywheel / and the bolt that holds down the flywheel. All the time I try to tightned the bolt that holds down the flywheel, the crank moves along with the bolt ( im using a flywheel locking tool to keep the flywheel in place ). Should I put shims behind the collet so that it pushes out the flywheel ? I have the 3D clutch along with the sirio evo2 motor. Any help would be appreciated. Thanks.
Zac Project is offline   Reply With Quote
Old 04-14-2008, 07:17 AM   #2778
Send a message via MSN to ejcabal
Originally Posted by Zac Project View Post
I'm having issues with the collet /flywheel / and the bolt that holds down the flywheel. All the time I try to tightned the bolt that holds down the flywheel, the crank moves along with the bolt ( im using a flywheel locking tool keep the flywheel in place ). Should I put shims behind the collet so that it pushes out the flywheel ? I have the 3D clutch along with the sirio evo2 motor. Any help would be appreciated. Thanks.
This happens because the collet is too long. Take your dremmel and cut off 1mm (or less if you can) off the collet from the side that faces out. That way you will be able to tighten the nut by having it sit on the flywheel instead of on the collet.
ejcabal is offline   Reply With Quote
Old 04-14-2008, 08:06 PM   #2779
GMartinez's Avatar
Trader Rating: 85 (100%+)
Kyosho Item#UM213 will solve your issue & you don't have to dremmel anything & use the spacer that comes with it for clearance
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 04-14-2008, 08:08 PM   #2780
GMartinez's Avatar
Originally Posted by YANMAN View Post
I have an easy question for most of you. I put 30,000 in the rear dif like the kit said, but my rear tire wear is bad. What would happen if I went down in dif weight? What would it do to the car and would it help with tire wear. I really don't want to mess with it all that much because it handles so well, just looking to help tire wear.
Thanks,
Tim
Track condition & what tire shore you were using
Old 04-15-2008, 03:04 AM   #2781
Thanks for the help.
What are the difference between the standard RRR shocks compared to the evo shocks. I noticed that the evo conversion kit had shock bodies along with gold shock shafts and 2-hole pistons. Also, it came with universals that were silver. Are these for the front or rear of the car ?
Old 04-15-2008, 10:14 AM   #2782
YANMAN's Avatar
Trader Rating: 39 (100%+)
Fresh paved parking lot with suger water. I am running 40 shore rear tires. I was thinking of changing to 42 shore.
YANMAN is offline   Reply With Quote
Old 04-17-2008, 04:15 PM   #2783
GMartinez's Avatar
Zac the diaphram in the shocks are different shock bodies is longer in length & the shafts are titanium,the silver cvd's are for the front the old shocks came with 1 hole piston in the front 2 hole in the rear now it's 2 hole all around & the springs are different but you can still use the old springs as well
Old 04-17-2008, 04:21 PM   #2784
GMartinez's Avatar
Default Congradulations Bobby Watson
Just wanted to Welcome & Congradulate (AKA Impalabob)
Mr. Bobby Watson newest Team Driver for KyoshoAmerica
Well Deserved Keep it up Bobby it's going to be a great season
Old 04-17-2008, 05:18 PM   #2785
Yeah Bobby!
Welcome aboard.
Jamie Corrado is offline   Reply With Quote
Old 04-17-2008, 05:32 PM   #2786
carkillaii's Avatar
Originally Posted by Jamie Corrado View Post
Yeah Bobby!
Welcome aboard.
J might go out to FB on Fri to retune this motor you coming out?
carkillaii is offline   Reply With Quote
Old 04-17-2008, 09:23 PM   #2787
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Why don't you take car of your business with me Vaughn. Been waiting for months.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 04-17-2008, 09:41 PM   #2788
carkillaii's Avatar
Why don't you take care of your business with me Vaughn. Been waiting for months.
Fish sent it out a while ago next time just send me a pm
Old 04-17-2008, 10:16 PM   #2789
Have received nothing and most of the PM's I sent you went unanswered. Just use paypal.
Old 04-18-2008, 02:06 AM   #2790
Thanks GM
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
