Old 04-08-2008, 02:44 AM   #2746
Anybody selling a Kyosho RRR WCE or does anybody know anyone wanting to sell ? Thanks.
Nothing available on the classifieds when I did a search.
Paul D. is offline   Reply With Quote
Old 04-08-2008, 03:00 AM   #2747
LOSI123's Avatar
Trader Rating: 63 (100%+)
anyone know if the 3racing 1st spur gear will fit the standard kit one way spur holder??
LOSI123 is offline   Reply With Quote
Old 04-08-2008, 03:09 AM   #2748
Default shock oil
so what would the normal starting(lightest) and finishing(heaviest) weight of shock oil for the tourers in the Kyosho range
Thank you
elche_83 is offline   Reply With Quote
Old 04-08-2008, 05:59 AM   #2749
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Sent you pm
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 04-08-2008, 03:59 PM   #2750
moy
moy's Avatar
Originally Posted by GMartinez View Post
Most likely after the worlds Aug/Sept
tnx.is it the same as the rrr or its a totally new kit.
moy is offline   Reply With Quote
Old 04-08-2008, 07:47 PM   #2751
GSPOT's Avatar
Trader Rating: 62 (100%+)
Send a message via AIM to GSPOT
my 2 speed is binding up on the 2nd spur because of something in my 2 speed changer..its something in those little set screws i guess....?...??
i set them to just clear the outside whick allows my 2 speed changer to freely spin..but then i will shift almost instantly..if i adjust the shift point from there then it seems to just make it worse.....
ADVICE?
what are those rollers for?
VTA member #126
GSPOT is offline   Reply With Quote
Old 04-08-2008, 10:49 PM   #2752
Xray prince's Avatar
Default 2speed
No worries if its a new 2nd spur gear........they all seem to hang up at first.....they have excess material from what looks like a molding process!!!!after a few laps the gears free up!!
pilot for Kyosho's RRR Evo WC
Ko 2413's....DX3R...JPfx3
Subaru IGT,C5 rody mod onroad,M8
Xray prince is offline   Reply With Quote
Old 04-09-2008, 05:05 AM   #2753
GSPOT's Avatar
its an older 2nd spur gear...i can get it to free spin.....but when i adjust my shift point it seems to tighten up how the whole changer spins within the 2nd spur........???...
VTA member #126
Old 04-10-2008, 06:33 AM   #2754
GSPOT's Avatar
anybody else wear away the 2 speed changer adapter? fw360? i think is the part number.... its the actual clutch that engages the 2nd spur.... i had a friend look at it and he decided the same thing....it aint right!
let me know!
VTA member #126
Old 04-10-2008, 07:58 AM   #2755
jeff1's Avatar
I use a sand paper and wear until it spin free, I set the gap screw "flush" with shoe
jeff1 is offline   Reply With Quote
Old 04-10-2008, 08:09 AM   #2756
GSPOT's Avatar
thats the issue, if i set my second gear change to shift later, it then causes that adapter not to spin inside the 2nd spur..i have tightened the shift points so far the screw actually will hit the metal inside the spur..... i will take pics tonight
VTA member #126
Old 04-10-2008, 12:15 PM   #2757
Riketsu's Avatar
The correct way to setup your clutch shoe is (well, how I was taught to set em)... First place the setscrews flush with the housing. Then, the 2nd speed screws (the ones with the springs), tighten them down until you cant any further (dont apply an excessive amount of force or you will cause permanent damage to the springs). Then unscrew them by 3 full turns. After you do this, check to see if the adapter (center steel piece) has any rotational play. If it does, keep screwing the setscrews until there is no play. I usually go 1/4 turn in each setscrew to achieve this, if I find screw in one of the setscrews and eliminate all the play, I unscrew it 1/4 a turn so I can find the same point for the other screw (achieve no play). When I get it, I unscrew 1/4 turn that setscrew, then screw in both 1/8 turn. Now, I place the clutch shoe in the car, and check my shift point. And if I want to delay it, I screw in the spring screws by increments of 1/4-1/2 turn. If I want to make the shift point faster, I unscrew them by 1/4-1/2 turn.
Hope this helps.
If the clutch shoes are new, there should be some drag when you rotate the 2nd gear on the 2nd clutch shoe. This will free up once you hit a couple of laps. This is done, so we can assure ourselves that the gap between the shoes and the adapter is close to minimum, thus the force it impacts on the adapter reduces and prevents 2nd gear stripping.
Old 04-10-2008, 12:35 PM   #2758
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Thumbs up
Hope this helps.
Good info. that is the same way I adjust my 2 speed.
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 04-10-2008, 02:09 PM   #2759
RIKETSU,
I can't help it by noticing your signature, it says " KYOSHO RRR EVO World Champion" did you know that the RRR EVO was never a Champion? it is the original RRR WC TEAM EDITION that is a World Champion in 2004.
hello is offline   Reply With Quote
Old 04-10-2008, 05:28 PM   #2760
Trader Rating: 13 (93%+)
..and this years world champion will be the Xray NT1
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
