Old 03-16-2008, 07:56 AM   #2671
Screwing in lowers the shift point? Wow, I would have thought less pre-load would lower it...
92mnstanger is offline   Reply With Quote
Old 03-16-2008, 06:36 PM   #2672
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
No, screwing in the screws makes the car shift later. Looser screws will have the car shift at lower RPM.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 03-16-2008, 09:27 PM   #2673
Korey Harbke's Avatar
Alright guys...
I'm a long time Electric touring car racer and I've been thinking about getting into nitro touring cars. A few of my good racing buddies run the Kyosho car, and I figured it would be a good starting point to get into nitro touring car racing.
But, I just wanted to know if there are any must have hop ups for the evo WCE. We'll be running on a medium bite parking lot track Thanks for the help guys!
-Korey
P.S. If Mike Ellis is reading... I'm TOTALLY serious about getting a nitro touring car! hahaha
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 03-16-2008, 11:26 PM   #2674
robert maestrey's Avatar
Originally Posted by Korey Harbke View Post
Alright guys...
-Korey
The car works right out of the box....If you would like to lighten the drivetrain this might be a good idea..www.ybslowinc.com sells ome trick stuff. make sure to install a solid car works great with it.. also might want ot try the Sirio power clutch much lighter then the stock Kyosho clutch..you can order them from www.kyoshoamerica.com hope this helps
Sippin Coladas and Chillin
robert maestrey is offline   Reply With Quote
Old 03-17-2008, 03:26 PM   #2675
Cool, I'll probably just grab the basic spring sets and stuff to get some tunign options. Other than that, it sounds like it's got all the goodies I need!
-Korey
Old 03-17-2008, 06:04 PM   #2676
Thanks, I have a hard time with Internet sarcasm. I am that thick headed. I am trying out 3.5 turns. Unfortunately it is snowing six inches of snow right now so my outdoor testing is going to be delayed.
Old 03-18-2008, 09:48 AM   #2677
YANMAN's Avatar
Trader Rating: 39 (100%+)
Default 0,1 AND 2 DEGREE FRONT HUBS
I just picked up a new RRR WC EVO and wanted to stock up on spare parts. I looked at the front hubs and they have 0,1 and 2 degree hubs. What is the advantage to the degreed hubs?
Thanks,
Tim
YANMAN is offline   Reply With Quote
Old 03-19-2008, 12:20 AM   #2678
LOSI123's Avatar
Trader Rating: 63 (100%+)
also just following on from that, anyone know what the exact caster is for standard out of box setup (standard front knuckles and one spacer in front & 1 behind upper arm)
just looking at it it looks like its heaps compared to my ep tourer...
On another topic, what does the 23t or 24t middle belt pulley do?
which one is over drive/under drive and which one is standard?
LOSI123 is offline   Reply With Quote
Old 03-19-2008, 04:52 AM   #2679
evo1's Avatar
G'day Paul
Caster as you describe is 10.5 deg
24t pulley is for zero split between front & rear tyre diameter & uses the 387mm belt.
23t pulley is for 2mm split between front & rear tyre diameter for overdrive & uses the 384 mm belt. Hope this helps
Regards Paul
evo1 is offline   Reply With Quote
Old 03-19-2008, 05:28 AM   #2680
LOSI123's Avatar
if using the front locked up as a spool, what is best to run? which pulley & belt?
(i want to run foams and just keep tyres same dia front & back)
Old 03-19-2008, 07:03 AM   #2681
carkillaii's Avatar
For same dia foams use the "24t pulley is for zero split between front & rear tyre diameter & uses the 387mm belt."
If you are going to use the spool just use the stock pulleys.
carkillaii is offline   Reply With Quote
Old 03-19-2008, 10:52 AM   #2682
Vaughn:
I haven't seen anything come in the mail from you. Time to take care of your business.
Old 03-20-2008, 11:48 PM   #2683
LOSI123's Avatar
whats the best shock oil and piston combo for front & back end, with spool and with foams???
Old 03-21-2008, 01:14 AM   #2684
I have run the stock pistons since I got the car over a year ago. I do change the shock oil, but there is not "best" combo. It depends on the track and your driving style.
Old 03-21-2008, 04:28 AM   #2685
LOSI123's Avatar
i noticed the stock ones for the evo wc are 2 hole in the back & front
and some of the other versions of the rrr are 2 hole in the back & 1 hole pistons in the front?
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
