Old 03-02-2008, 02:52 AM   #2641
LOSI123's Avatar
Trader Rating: 63 (100%+)
thanx mate, yeah gas is hardcore, are they under kyosho parts or???
i cant find them,
LOSI123 is offline   Reply With Quote
Old 03-02-2008, 06:32 PM   #2642
Brazilct's Avatar
Originally Posted by LOSI123 View Post
Any one know where i can get a screw kit for this car?
preferably not rcscrews, as postage to Australia is threw the roof........
Brooklynhobbies.com talk to Richie 718-951-2500
BROOKLYN HOBBIES...
SERPENT AMERICA...
JP Racing...
MAXY's PRO RACING FUEL & MODIFIED MOTORS
Brazilct is offline   Reply With Quote
Old 03-05-2008, 05:40 PM   #2643
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Have you guys tried the 3racing 2nd spurs or the Atomic RC spurs? Price seems to be alot lower than Kyosho's spurs. Any comments on these two brands?
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 03-05-2008, 05:58 PM   #2644
jeff1's Avatar
Its not worth
take your time to adjust gear mesh and use steel pinion... spur gears should last forever. its all adjustment
jeff1 is offline   Reply With Quote
Old 03-05-2008, 08:40 PM   #2645
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Use the Kyosho gears. They don't strip unless there is another problem.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 03-05-2008, 09:31 PM   #2646
Trader Rating: 13 (93%+)
Default installing 2d clutch
hi guys
i just tried to install a 2d clutch to my picco red dot evo 3
when i tighten down the flywheel nut i cant get it tight enough and the crank shaft turns around in side the engine. should i have to shim the flywheel? this has never happened to me before.
thanks
John
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 03-05-2008, 09:57 PM   #2647
occ
Trader Rating: 15 (100%+)
Originally Posted by mrgsr View Post
hi guys
thanks
John
Did you use the correct size flywheel cone? The picco's cones are smaller than novarossi. The 2D clutch only comes with a cone suitable for the novarossi.
occ is offline   Reply With Quote
Old 03-05-2008, 09:59 PM   #2648
Yes im using the collet that came with the picco engine
i installed a 2d clutch on my other picco but that clutch was brand new new this one has been used.im guessing the flywheel could be worn a little?
Old 03-05-2008, 10:00 PM   #2649
Grassy's Avatar
Hi John,
Check that the flywheel collett isnt protrudeing through the flywheel. (collet could be too long)
You shouldnt have to put a washer behind the flywheel unless its touching the crankcase.
Cheers,
Chris
-ACE HOBBY DISTRIBUTORS AUSTRALIA-
Grassy is offline   Reply With Quote
Old 03-05-2008, 10:01 PM   #2650
Grassy come on msn
Old 03-05-2008, 10:12 PM   #2651
That guy is right. You do have to use the Picco collet, but it will stick through the flywheel. Use a dremel and grind it down so it doesn't protrude through the flywheel and you will be fine. I have had to do that with all mine.
Old 03-05-2008, 10:39 PM   #2652
Thanks Chris and Scott
I file down the collet and it all went together great!
Old 03-06-2008, 06:48 PM   #2653
fatboy's Avatar
Send a message via MSN to fatboy
Hi, Just wonder is it true that a new kit will be release for the up-coming WC?????
fatboy is offline   Reply With Quote
Old 03-06-2008, 06:55 PM   #2654
Does anybody have a spring chart rating for kyosho spring set?
laptraffic is offline   Reply With Quote
Old 03-06-2008, 09:00 PM   #2655
I do not believe so.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
