Old 02-02-2008, 09:09 AM   #2581
Can someone recommend a good aluminum servo horn for my throttle/brake linkage? I just don't trust a trimmed plastic one to be durable enough.
92mnstanger is offline   Reply With Quote
Old 02-03-2008, 04:29 PM   #2582
robert maestrey's Avatar
I use a dynamite one and it seems to be holding up just fine ...hope this helps
Robert Maestrey
Sippin Coladas and Chillin
robert maestrey is offline   Reply With Quote
Old 02-03-2008, 04:33 PM   #2583
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Thumbs up
Robert Maestrey
Yes that the one I use works great.
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 02-03-2008, 05:44 PM   #2584
kewdawg's Avatar
Ofna makes good one, that has plastic inserts for different servo brands. They come in different colors. Check it out:
http://www3.towerhobbies.com/cgi-bin...fna+servo+horn
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 02-03-2008, 06:26 PM   #2585
I ended up buying a plastic OFNA horn. The dynamite aluminum part I looked at contacted the fuel tank just like everything else...I trimmed the OFNA part. It's thick enough it doesn't make me nervous. Now I just have to find a ball cup that fits my STS carb. The one I have is too big.
Old 02-04-2008, 01:03 AM   #2586
hi all,new to this i just bought vone rrr evo with x312t converted it to a wce and im looking for set ups to suit the lilydale track in Melbourne,Australia also what size pinion and spur gears will i need there so i can stock up and can anyone tell me what this engine is like tuning wise etc etc.thanks
elche_83 is offline   Reply With Quote
Old 02-04-2008, 06:45 PM   #2587
doc56's Avatar
Default Sirio Power Clutch
Originally Posted by iiistyler View Post
Doc56 I just baught the sirio clutch from pro-shop futaba in japan about 2 weeks ago I waited a couple of days for him to get stock of it. he might still have some
iiistyler bro, can u please pm me the website to this futaba pro-shop? TQ
No Race No Life
Horsepower is how hard you hit the wall
Torque is how far you take the wall with you
doc56 is offline   Reply With Quote
Old 02-04-2008, 06:52 PM   #2588
doc56's Avatar
Originally Posted by GMartinez View Post
It's not the same as the Sirio clutch the capricorn bell is different the shoe/clutch disk is smaller than the Sirio you can't even combine them together.
myself & another teammate tried the capricorn & we both had the same issue it exploded on us we then put on the sirio power clutch & were still running it
the Sirio power clutch is available from kyosho but has to be ordered by the piece since Sirio has not sent them the full system I will try to post all the #
What do you mean exploded? I had my clutch exploded before, whcih is the centrifugal pop out and some melted. From your opinion, which is better the capricorn clutch assembly or the sirio clutch assembly?
No Race No Life
Old 02-06-2008, 10:56 PM   #2589
Trader Rating: 13 (93%+)
Default front sway bar question
Hi
I set up my front swaybar / droop and now just have a small question..
I used robert maestrys droop setup as below:
"1. I set my eccentrics to parallel to the a-arms and tighten.
2. disconnect sway bar only removing the right sway leaving left one in place...
3.then ill use my down-stop gauge slide under left A-arm and set to desired point.
4.now ill move over to right side of car and will tighten or loosen the down-stop screw to the point that it allows the right sway bar to slide into the left sway without affecting the down-stop setting on the left side....I hope i haven't lost you guys....
5. OK the left has stayed at its setting lets say 0 down-stop setting now check what the right is at.....if the left is at 0 also then your set......if not use the right eccentric to raise or lower the arm to achieve the correct down-stop setting to match the opposite side....
Now once i have both arm heights the same i notice the right arm can be lifted more than the left before the sway bar engages. is this normal or does it affect the handling in anyway?? i spent a couple of hours trying to sort it out then just thought it was normal
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 02-06-2008, 11:12 PM   #2590
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Originally Posted by mrgsr View Post
Hi
Holy .... I am going to send my car to Robert just to have him set the front droop.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 02-06-2008, 11:14 PM   #2591
It does make it a lot easier to set the droop though, first inital setup anyway.
scot do u know the play im talking about?
also did u get the link for the titanium screw set i sent you?
Old 02-06-2008, 11:32 PM   #2592
I know what your talking about...and due to the fact that the the cup and ball are not exact size there will always be a little play if not it would bind....this should not affect handling.....Hey Scott anytime all kidding aside there are many ways to do your droop guys so if you found a way you like then stick to ithope this helps
Robert Maestrey
Old 02-07-2008, 12:36 AM   #2593
Sp Racer's Avatar
lay the shocks all the way down - kit springs and kit oil, that's about it; 40 or 42 shore tyre
X312T - 16/61 , 22/56.
start rich, bottom and top, lean off the top a notch at a time until you get the HP you want
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
Old 02-07-2008, 01:04 AM   #2594
thanks for the reply,ill give it a go and see if how it runs.
Old 02-07-2008, 02:01 AM   #2595
mrgsr: I do know the play you are talking about. Robert addressed that. Don't worry about it.
Robert: Good luck at the winternats.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
