Old 01-21-2008, 01:23 PM   #2566
Default set up for med bump track
Originally Posted by dowhile View Post
Hi, can u suggest me some good link which explain the various and many settings for kyosho (camber.. degree..angles ecc)
and... what do you use in order to prevent the pipe-break from crashes? (i mean the end-tube)?
Thanks.. sorry for my english thanks!
Hola,
Front
oil shock 5oo, 2 hole
down stop 0
caster 1
toe out 2 'total'
camber 2, more stering 2.5
roll bar 35 degree
shocks spring blue
chasis height 6 with hudy sistem
Rear
oil shock 500,2 hole
down stop 4
toe in 2L, 2R
camber 3.5
roll bar 45 degree ,adj,
shocks spring blue
Geovannie Gonzalez
Puerto Rico
Serpent America
Geovannie is offline   Reply With Quote
Old 01-24-2008, 05:44 PM   #2567
Trader Rating: 21 (100%+)
Default RRR Evo WC Manual
Last time I checked on the Kyosho website, there was still no RRR Evo WC manual for download!
Se here is a link to a scanned copy (~25MB):
http://rapidshare.com/files/86376514...RRR_Evo_WC.zip
Mugen MBX7R - Werks B2
Losi 8ight 3.0 - LRP ZZ21
Mugen MBX7T - Werks B5
Mugen MBX7 ECO - Tekin RX8gen2
Sedanfahrer is offline   Reply With Quote
Old 01-24-2008, 09:42 PM   #2568
shesha's Avatar
Send a message via MSN to shesha
Okay problem resolved, after numerous problems.
For V-One RRR owners you need the front universal drive shafts from the V-One RRR EVO WC, so they dont fall out from the cup joints. you also need the cup joints I mentioned earlier plus the internal gears.
You will need to replace the standard open end tie rods with ball cups and half ball cups plastic, then you also need to put some shims on either side of the fron diff casing to avoid lateral play.
For those upgrading from V-one RRR to evo wc that is.
Talk about a work out .... , wish kyosho would just put the part numbers required for diff setup.... For 3R Evo WC owners you only need the internal gears and cup joints....just dont forget to take out the plastic on the front pulley gear that was ca'ed in the beginning for both cars or you are going to get rubbing and miss alignment of the front diff.
shesha is offline   Reply With Quote
Old 01-25-2008, 04:29 PM   #2569
shesha's Avatar
Dowhile read the Hudy manual which you can pickup from the following website http://www.teamxray.com/teamxray/pro...49be8d668c8eef 3rd one down or 4th one down.
For your pipe you can use some tig weld behind the stinger as extra support or put some jb weld or epoxy metal, something that can with stand high temperatures and stop the stinger from bending back.
Old 01-26-2008, 03:45 PM   #2570
iiistyler's Avatar
Send a message via MSN to iiistyler
Originally Posted by doc56 View Post
TQ bro..where or which website can i get this?
Doc56 I just baught the sirio clutch from pro-shop futaba in japan about 2 weeks ago I waited a couple of days for him to get stock of it. he might still have some
V-ONE-RRR EVO 2
MURNAN MODIFIED 353 09 TUNED FULL CERAMIC STOCK 353 09 TUNED
FUTABA BRUSHLESS BLS551 3PKS + FASST
PROUD MEMBER OF THE MOOREBANK REBEL ALLIANCE
YOU ARE NOW ENTERING KYOSHO COUNTRY BEWARE
iiistyler is offline   Reply With Quote
Old 01-27-2008, 12:31 PM   #2571
bugnet's Avatar
Hi,
as mentioned before, about RRR vs EVO, someone know why rear bulkhead changes too ?
Ir ur coming bring me some
bugnet is offline   Reply With Quote
Old 01-27-2008, 05:27 PM   #2572
robert maestrey's Avatar
Originally Posted by bugnet View Post
Hi,
With the new evo Bulkheads you get wider range of adjustments for camber gain and roll center fine tuning...hope this helps
Sippin Coladas and Chillin
robert maestrey is offline   Reply With Quote
Old 01-28-2008, 03:13 PM   #2573
evo1's Avatar
Default Red box tyres
Where is the best place to buy Red Box Tyres , online
evo1 is offline   Reply With Quote
Old 01-28-2008, 06:52 PM   #2574
nitrodude's Avatar
Try kamikazetoysandhobbies.com, If they're not listed on the website, give him a call, he caan get them pretty quick.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 01-28-2008, 07:11 PM   #2575
doc56's Avatar
where is the best place to get the Sirio Power Clutch?
No Race No Life
Horsepower is how hard you hit the wall
Torque is how far you take the wall with you
doc56 is offline   Reply With Quote
Old 01-31-2008, 11:35 PM   #2576
bugnet's Avatar
really helped, I've saw on manual of both too, thats it,
the WC uses an 2mm offset wheel as standard, and evo is ready for jaco 0 offset rims, swingshafts changes and comes with spacers ouside of rear hubs to do it, or it's done by the new rear bulkhead ?
Old 02-01-2008, 04:48 AM   #2577
bugnet's Avatar
I saw at capricorn from EU, and one in F/S here in forum.
Old 02-01-2008, 01:49 PM   #2578
The bulkheads have nothing to do with the offset......EVO wc comes with the required cvds to run 2mm offset in the rear...front always uses 0 offfset...Kyosho also makes red box tires 0 offset just incase you want to use them instead off Jaco . if you would like to run 2mm offset pick vsw015 they will work on any rrr, rrr wc, evo and evo wc I like the 2mm offset for me it makes the car rotate and feel much more stable in the rear of the car
hope this helps
Robert Maestrey
Old 02-01-2008, 01:53 PM   #2579
Ive seen this clutch and it looks real nice but I dont think it is a sirio power clutch you might want to verify this before you order if you are specifically looking for Sirio.... hope this helps
P.S im in the process of finding them ill keep you posted.
hope this helps
Robert Maestrey
Old 02-02-2008, 06:27 AM   #2580
GMartinez's Avatar
Trader Rating: 85 (100%+)
It's not the same as the Sirio clutch the capricorn bell is different the shoe/clutch disk is smaller than the Sirio you can't even combine them together.
myself & another teammate tried the capricorn & we both had the same issue it exploded on us we then put on the sirio power clutch & were still running it
the Sirio power clutch is available from kyosho but has to be ordered by the piece since Sirio has not sent them the full system I will try to post all the #
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
