Old 11-13-2007, 11:56 AM   #2386
Originally Posted by jeff1 View Post
When using 2607 the header will touch the body as its very big.. my body has marks .. please see if you have this problem
You can cut the flange flat on the pipe + header where it touches the body to get a few extra mm of clearance. but the 2607 pipe will still rub.
brianhatesnitro is offline   Reply With Quote
Old 11-13-2007, 12:10 PM   #2387
Team Kamikaze's Avatar
I would just ignore it, a few marks on the body won't hurt the performance anyway.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 11-13-2007, 12:15 PM   #2388
vulso's Avatar
Does anyone know the part# or who makes the laydown front body mount for the RRR? Where I could get one?
vulso is offline   Reply With Quote
Old 11-13-2007, 12:29 PM   #2389
N.O
VZ244
N.O is offline   Reply With Quote
Old 11-14-2007, 10:37 AM   #2390
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Hey guys... Im thinking of switching to Kyosho RRR Evo from my Mugen MTX-4... has anyone done this change??? What the difference between them? Do I need any additional hop-ups to make the car lighter or stronger??? What is a good list of spare parts I should have with me??? Thanks guys.
Riketsu is offline   Reply With Quote
Old 11-14-2007, 11:23 AM   #2391
I believe that for a RRR Evo WC the only thing that you REALLY needs to change are the brake disc (original is ridiculous) and the brake pads to the k-factory ones. Also I recommend that you buy a allen screws set cuz the philiphs screws that come with the kit suck!
There are other upgrades but they are not essential, like the aluminum or carbon fiber side stiffener, aluminum brake bar, steal pinion gears and so on.
Other than that, WC version comes with everything you need: one piece engine mount, sp belts, aluminum washer set, carbon front shock tower and a lot of other stuff.
You can take a look at nitro kb for a list of upgrades, there is a Ultimate and Ultimate X editions:
http://www.nitrokb.com/vonerrr/UltimateEdition.html
Spare parts should be the same as you are used to with MTX4, the cars are very similar.
V1RRR Evo WCTE - Sirio STI/NR 353 MM - Futaba 3PM FASST
FW05TRR - GXR15 Tunned - Futaba 3PM FS Pro
Ramiel is offline   Reply With Quote
Old 11-14-2007, 11:59 AM   #2392
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
I ran a Mugen the MTX4 from pretty much day one of its USA availability and switched to the RRR EVO WC at the beginning of 2007.
I pretty much agree with Ramiel. I run the hopup Kyosho APP brakes and they work well. I would not get the hopup side stiffener. The brake bar is more bling, but if you use a spool it isn't a bad thing to have, but not necessary. I would consider getting the steel pinions if you are more concerned about longevity vs. weight. The car is pretty darn good right out of the box. Definitely get an allen head screw kit. I got mine from Tony's screws.
Use the stock chassis.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 11-14-2007, 01:11 PM   #2393
trickd122's Avatar
Ditto get the RRR EVO WC call it a day
The car is pretty much bullet proof except for the gears, again get the steel ones for longevity, personally I have no problems with the screws. Now dor spares:
Gears.....and the normal lower arms, front knuckles etc.
trickd122 is offline   Reply With Quote
Old 11-14-2007, 05:52 PM   #2394
GMartinez's Avatar
Trader Rating: 85 (100%+)
What's up Scott it was nice meeting you @ the Nat's
regarding the Tony screws they are good but way to heavy
standard kit with kyosho screws my car weighed in @ 1740
with the tony screws 1794
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 11-14-2007, 05:58 PM   #2395
Riketsu's Avatar
Thanks guys for the quick replies... I just purchased a RRR evo team kit... Cant wait for it to get here. I will definitely get allen screws since I dont like the standard kyosho ones. I usually use RCScrews's titanium ones... They bend on a very hard impact, but they shave a few grams off the total car weight.
I was wondering... which of the brake pads do you guys use??? I have seen on a few online shops two different types:
-Kyosho V1RRR EVO Acre Brake Pad [KY-IFW324]
-Kyosho V1RRR EVO APP Brake Pad [KY-APP02-2]
Also... someone mentioned that the brake disk is not so good... What brand do you guys recommend???
Old 11-14-2007, 06:49 PM   #2396
I use the APP brake pads. I run tonys screws in the bottom of the car and titanium screws on the top of the car. There is an APP brake disc as well.
Old 11-14-2007, 07:29 PM   #2397
tony montana's Avatar
Trader Rating: 66 (100%+)
does the regular rrr wce have the same brake setup as the evo? Can I buy just the evo top deck to run the stand up throttle servo instead of the laydown
K.C. Guy- TLR- Horrizon Hobby- Team Trinity- 92 zero designs- AKA
tony montana is offline   Reply With Quote
Old 11-14-2007, 07:54 PM   #2398
I believe that the older car uses a plastic brake pulley that is driven with a pin. The Evo WCE uses an aluminum brake pulley with a set screw. Many of the team drivers use the plastic pulley setup to save rotating weight so you can retrofit your car.
George: Nice meeting you too... finally.
Being too heavy is not an issue with my car. I had to add over 70 grams of brass as well as using a 59 gram battery tray to get my car to make weight.
I still use the titanium top screws though.
Old 11-14-2007, 08:02 PM   #2399
scott, where can I find more rrr setups besides the kyosho website
Old 11-14-2007, 08:32 PM   #2400
I wouldn't know, but myself and guys like George, Robert, Michael, Walter etc, are on this forum with some frequency. Just ask as most of the team is quite willing to help. This car is in its 4th version and I started with Kyosho during this version so I am somewhat ignorant about the older versions.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
