Old 08-24-2006, 05:09 PM   #226
occ
Trader Rating: 15 (100%+)
Does anyone use the Kyosho Drive Washer set? See attached picture.
Do you use the pins that come with the washer set? They seem to short to use. Or do you just use the pins that come with the drive axles?
I'm confused
occ is offline   Reply With Quote
Old 08-24-2006, 07:41 PM   #227
BerNardLee's Avatar
Originally Posted by fritzD
here's my Evo... finally done.... just rolling chassis yet though.. hehehe!!! the Spur gear looks pretty tough...
You are having one piece engine mount in your photo.
Is it come with your evo kits?
BerNardLee is offline   Reply With Quote
Old 08-24-2006, 09:41 PM   #228
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
i think the one piece engine mount is already an upgrade or hop-up with the RRR-evo, you have to buy it seperately only the RRR WCE comes standard with the one piece engine mount
buboy28 is offline   Reply With Quote
Old 08-24-2006, 09:59 PM   #229
BerNardLee's Avatar
Because my kit didn't come with the one piece engine mount......
Is anyone know the main purpose of having one piece engine mount?
Old 08-25-2006, 04:47 AM   #230
fritzD's Avatar
Send a message via Yahoo to fritzD
Yes, the kit comes with a two piece engine mount. I bought the one piece engine mount separately. It's a 3racing one piece engine mount. It's much cheaper than the original kyosho. From one pice engine mount can make your engine to chassis support more sturdy since more area of the engine mount is in contact with the chassis.
fritzD is offline   Reply With Quote
Old 08-25-2006, 05:31 AM   #231
I'm confused
yes i use the kyosho drive washer set partno. vzw010. i use the pins that come with it (short ones) and havnt had a problem!!!
ae_ntc3 is offline   Reply With Quote
Old 08-26-2006, 01:11 AM   #232
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
I'm confused
the pins that come with the kyosho aluminum hex hubs are shorter compared to the pins that come with the stock plactic hex hubs
doki_doki is offline   Reply With Quote
Old 08-26-2006, 01:12 AM   #233
doki_doki's Avatar
i agree with you. with a one piece engine mount, the chassis is much stiffer since there is added material connecting the 2 engine mounts below
Old 08-26-2006, 04:12 AM   #234
buboy28's Avatar
3racing one piece engine mount is about 2g lighter than the kyosho one piece engine mount but you are right the one piece engine mount makes your chassis stiffer and they say that engine heat dissipation is much better with the one piece engine mount
Old 08-27-2006, 07:02 AM   #235
doki_doki's Avatar
really? would you happen to know if the 3racing one piece engine mount is the same material as the kyosho one piece engine mount
Old 08-27-2006, 07:03 AM   #236
doki_doki's Avatar
Default v1rrr evo
here is a picture of the sticker that's on the kyosho v1rrr evo box. hop it is clear enough for you to read
anyways: here's is what is written on the sticker...
*front and rear shocks for 13mm diameter (internal) shocks springs and painted shock springs.
*new designed carbon upper plate to be mounted throttle servo at upright position.
*machined aluminum 21T drive pulley with new brake hub (3mm pin type).
*new main shaft and high durability 1st and 2nd spur gears against impacts.
*double polished brake rotor with soft brake pads (red).
Old 08-27-2006, 07:05 AM   #237
doki_doki's Avatar
Default v1rrr evo
here are pictures of the front end of the kit. the servo saver does no come with bearings as with the wce kit. instead bushing were placed kit also came with dogbones instead of universal swingshafts found in the wce
Old 08-27-2006, 07:23 AM   #238
doki_doki's Avatar
Default v1rrr evo
here's a picture of the new soft brake pads included in the kit (it's colored red). i hope i will not experience brake fade much often compared to the wce
Old 08-27-2006, 07:29 AM   #239
doki_doki's Avatar
Default v1rrr evo
here are pictures of the new front and rear shocks for 13mm internal diameter shocks springs and painted blue shock springs. what i noticed is that the upper part of the shock are bigger compared to the wce. only the rear shock tower is carbon fiber with 6 shock positions to choose from. the front is made of hard plastic with only 2 shock positions to choose from.
Old 08-27-2006, 07:30 AM   #240
rmdhawaii's Avatar
Go with the KFactory disc and pads. No brake fade. You pay the price, but it's well worth it.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
