Old 11-07-2007, 05:34 PM   #2371
Team Kamikaze's Avatar
Originally Posted by wanna-b-faster View Post
I need a chasis that is less flexable then the WC 3mm Both cars are almost the same few difference but the chasis looks the same. I have thought of making my own out of 4.5mm 7076 or even 5.5mm. but it might be easier to buy what the pro's use so I can be a better rc guy
Kyosho got an option chassis for the RRR which is stiffer than the stock one.
but remember, having a stiffer chassis does not necessarily going to make you a better driver.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 11-07-2007, 08:51 PM   #2372
wanna-b-faster's Avatar
thanks I saw that one. I just ordered the 3Racing 4mm chassis. I have too much flexing with the stock chassis. In my novice class I came in 2nd. I ran a short track with a high gear ratio I used at Kissimee race tack last year. Oh I use 40% barons fuel =). I just added some shims to the OS TZ 12 3port because I saw some pitting on the piston. I love this car!!!!!!
wanna-b-faster is offline   Reply With Quote
Old 11-07-2007, 09:06 PM   #2373
Trader Rating: 13 (93%+)
Hi wanna-b-faster
Try not to waste your money on hopups. The rrr is perfect out of the box and remember if the worlds top drivers dont use the hopup why should you ?
If see you look at the cars setups from the world you will see they are mostly using the stock setup.
Good luck !
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 11-07-2007, 09:09 PM   #2374
Default servo clearance on rrr evo
Hi Guys
Ive just put the evo top deck back on my evo rrr but the clearance between the servo plug on the throttle servo and the mount for the steering servo is very tight.
I use futaba 9451 servos. im thinking of grindingaway a bit of the plastic from the steering servo mount.
What have you people done to clear this?
Old 11-08-2007, 02:18 AM   #2375
Grassy's Avatar
Originally Posted by mrgsr View Post
Hi Guys
I had to dremel a fraction out of mine to clear the cable of fouling i use the ace digital servos.
PS. are you and ron going to the mingara cup this weekend?
cheers
Chris
-ACE HOBBY DISTRIBUTORS AUSTRALIA-
Grassy is offline   Reply With Quote
Old 11-08-2007, 03:31 AM   #2376
Thanks Chris
No, i have my neices christening sunday and rons 2nd baby is due this weekend.
sux to miss out
Old 11-08-2007, 07:48 AM   #2377
esham's Avatar
Guys need help here. Which one is for the rear ? UJ Rear?
Kyosho VSW007 Universal Swing Shaft
Kyosho VSW015 Universal Swing Shaft
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 11-08-2007, 08:38 AM   #2378
kewdawg's Avatar
Both. VSW007 allows you to use 0mm off-set tires. VSW015 allows for 2mm off-set tires.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 11-08-2007, 09:01 AM   #2379
esham's Avatar
Ohh..!! Thanks kewdwg.
Old 11-08-2007, 10:29 AM   #2380
Originally Posted by Team Kamikaze View Post
Yes, it fits.
thanks kami
nickiphorosn is offline   Reply With Quote
Old 11-09-2007, 08:22 PM   #2381
kreamUNO's Avatar
it's my dads car, waiting for his 2607 pipe.
Mugen MTX-4R-NINJA MR12TUNED-NINJA FLS || Kyosho v-one RRR evo.2-SirioXXX-Sirio 2611
Kyosho Inferno WC-JAMMIN' JP3 || Kyosho M3-Sirio CL7R-Novarossi
XRAY T3'-Novak 13.5/tekinR1 || Serpent S120-RP x11 3.5
Tamiya IFS-Novak17.5/SPX || Tamiya TT-01-LRP x11 17.5
kreamUNO is offline   Reply With Quote
Old 11-12-2007, 09:33 PM   #2382
Grassy's Avatar
Ok i need some help i am having trouble with the front droop screws on my car i adjust my droop with these screws but after about 3 or 4 race meets i need to replace the swarbar mounts because the droop screws chew them out. I heard from some one on the forrum somewhere that droop is supposed to be adjusted through the cams on the swaybar mounts and the droop screws are set and left but i cannot see how this is done. any help would be greatly appreciated.
cheers
Chris
Old 11-13-2007, 01:41 AM   #2383
kewdawg's Avatar
cheers
Chris
The set screws are in the very front of the left and right bulkheads. They screw down through the bulkheads and contact the swaybar mount. I'm curious as to how you're chewing out the mounts? I've haven't experienced that problem, at all. Are you using the correct set screws?
Quinn Moon
Old 11-13-2007, 08:52 AM   #2384
jeff1's Avatar
where did you get these carburator nipple cover?
Nice car. Mine is almost the same, but I use older upper deck and shocks. The JL with 2D clutch is the killer
When using 2607 the header will touch the body as its very big.. my body has marks .. please see if you have this problem
jeff1 is offline   Reply With Quote
Old 11-13-2007, 09:08 AM   #2385
That is the same as your antenna cap.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
