Old 10-13-2007, 01:48 PM   #2296
Scott thanks . Does this mean that the higher the number the more alkerman effect you would have?? The one that is marked 12 would have the greatist effect and the one marked 10 would have the least??
nitrohead5300 is offline   Reply With Quote
Old 10-13-2007, 04:08 PM   #2297
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
Originally Posted by nitrohead5300 View Post
Hello guys I just purchased a WC Edition V-RRR while putting it togather I noticed on the servo saver I had three different bottom halfs that I could put on. One bottom had the number 12 the next one had the number 11 and the last one had the number 10 . What does this mean?? Will putting on a different bottom half affect the alkerman steering effect??
From what I know, the #10 gives you lots of steering and is recommended for use with small technical tracks. The #11 is neutral. The #12 has lesser steering and is recommended for big flowing tracks. Start using #11 since it's neutral and take if from there if you need more steering or less steering... Just my 2 cents...
doki_doki is offline   Reply With Quote
Old 10-13-2007, 04:58 PM   #2298
Thanks for your help Gentlemen!!
Old 10-14-2007, 04:41 AM   #2299
maskedrider's Avatar
hi guys,
if i using 50k rear diff on technical track, what are the main different compare by using 30k rear.
currently, i using kyosho solid axcle.
cheers
maskedrider is offline   Reply With Quote
Old 10-15-2007, 07:35 AM   #2300
Trader Rating: 13 (93%+)
Default rear wing position
Hi guys
what effect does the rear position make to the cars setup?
our rules say the wing most not overhang past the rear bootlid by more than 10mm.
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 10-15-2007, 11:30 AM   #2301
Serpentd's Avatar
Originally Posted by mrgsr View Post
Hi guys
The further back your wing is the more downforce. Think of it like a lever. you will have more leverage and force the further back and less force the closer to the rear window. Like if you use a hammer and choke up on the handle, you have less force. If you use the end of the handle, you have more force. I don't know if this was a very good example to use, but those are the basic physics of the rear wing placement. However it would be more of a medium to fine tuning aid.
If you have the extra holes drilled for it, try the wing full forward and drive a tank of fuel, then put the wing full rear and note the changes. This way you will know when you need to make changes at a race. Hope this helped and good luck!
Blessed are the SIC
Serpentd is offline   Reply With Quote
Old 10-15-2007, 04:25 PM   #2302
Was wondering why the RRR WC Evo has different offset tires and the normal RRR keeps it the same? Or am i mistakin?
grabs39 is offline   Reply With Quote
Old 10-15-2007, 04:32 PM   #2303
GMartinez's Avatar
Trader Rating: 85 (100%+)
They are both the same with a rear offset if you are having issues finding the red box tires from kyosho you can check into the twister brand the rim is identical to the kyosho & they carry a 2mm offset for the kyosho the rims are very sturdy
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 10-15-2007, 04:59 PM   #2304
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
Arrow
Hey G,
Where can you get the 2mm offset Twister tires for the rear? I currently purchased some off from eBay but the rear was 0 offset.
Thanks.
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 10-15-2007, 09:14 PM   #2305
Just got a RRR WC Evo. Any recommendations on freeing up the drivetrain while new? ie. cleaning out bearings, what glue to use for the break pads? And are the regular RRR part compadable with the wc evo? If anyone has suggestions id appreciate! Thanks John g
Old 10-15-2007, 09:29 PM   #2306
Team Kamikaze's Avatar
RRR Evo and RRR WCE have the exact same new plastics, mostly with a B after the part number, the only difference is the 2 speed shaft, brake pulley hub, longer front CVD shafts and radio tray.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 10-15-2007, 10:20 PM   #2307
dj apolaro's Avatar
Originally Posted by JRRobiso View Post
Hey G,
Thanks.
twistertiresusa.com
dj apolaro is offline   Reply With Quote
Old 10-15-2007, 10:22 PM   #2308
robert maestrey's Avatar
Alot of the parts are comparable....first off all I recommend using softest settings on your belts this helps alot....definitely clean out your bearings preferably with brake cleaner then see if you can find REM OIL you can usually find this at walmart in the gun area because it is gun oil..it is very light and great for the bearings...
Some things that the previous poster failed to mention was the Evo comes with new upgraded shocks that are much better than the standard RRR shocks, new springs...more adjustments on the upper rear bulkheads for camber gain and roll center and much more..Oh yea hollow middle shaft, Titanuim nitrade shock shafts and theres more.....if I am missing something which I probably am anyone else that follows this thread can add please do
Sippin Coladas and Chillin
robert maestrey is offline   Reply With Quote
Old 10-15-2007, 10:27 PM   #2309
JRRobiso's Avatar
Arrow
Originally Posted by dj apolaro View Post
twistertiresusa.com
Thanks for the web address. It looks like their website is still under construction (temporary homepage). I guess the only way I could order from them is by email at the moment.
Old 10-15-2007, 10:31 PM   #2310
JRRobiso's Avatar
Exclamation Twister Tires Seller
Does anyone know who else sells the Twister tires?
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
