Kyosho V-ONE RRR Evo >
Old 07-18-2007, 01:39 PM
  #2041
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
Originally Posted by Ice_nl View Post
The bodies are protoform stratus 3.1.
I made a flat spot an a titanium rear axle from my rrr wce so i could use it in the evo because of the different brake pulley. And besides removing all the useless parts and some titanium screws the weight came down quite easily. I also used an receiver battery with 1050mah instead of the 1400mah i used to run as the 1050mah pack was 25! grams lighter.
Tnx, The paint job was done by solid grafics. The blue one is mine and the red white blue one is from a friend.
Nice... It's such a waste to bash those beautifully painted bodies during the race...
doki_doki is offline
Old 07-18-2007, 01:43 PM
  #2042
doki_doki's Avatar
Originally Posted by kewdawg View Post
Yeah, the key is to stay on top of the pulleys. We all tend to overlook them. Worn pulleys will shorten the life of any belt.
I agree with you. What I do is that I take apart the pulleys after 2 to 3 run sessions at our tracks. Some small particles may be lodge between the teeths of the pulleys. With those small suckers stuck in betweem, your SP belts or even the regular belts get worn out easily... Also, if I'm get lazy, I just replace the pulleys with brand new ones. Getting a new set of pulleys are cheaper compared to getting a whole set of SP belts... Just my 2 cents...
Old 07-18-2007, 05:57 PM
  #2043
carkillaii's Avatar
So True
carkillaii is offline
Old 07-19-2007, 08:07 AM
  #2044
Hi guys,
Can you tell if this part the k factory brake disc (K1901) fits the Evo? Cuz it seems that the Evo has a different brake stopper
http://www.kfactoryracing.com/produc...1901&pageNum=3
Ramiel is offline
Old 07-19-2007, 08:22 AM
  #2045
Team Kamikaze's Avatar
Originally Posted by Ramiel View Post
Hi guys,
This disc won't work with the RRR EVO, the EVO have a different brake hub that uses pins.
Team Kamikaze is offline
Old 07-19-2007, 08:24 AM
  #2046
jeff1's Avatar
It won't fit because the Evo brake disk is hold by pins.. this disk is for RRR In my experience if you want a better disk than stock you should look for APP02-1
jeff1 is offline
Old 07-19-2007, 09:43 AM
  #2047
Thanks for the quick reply.
One last question about this: can I change the brake hub for the old RRR in the Evo?
Ramiel is offline
Old 07-19-2007, 10:47 AM
  #2048
jeff1's Avatar
Yes, you can. But you have to change the gearbox shaft VZ227, brake pulley VZW205 and 18T pulley VZ203 also you need two 2x11mm pins 92051
jeff1 is offline
Old 07-19-2007, 11:08 AM
  #2049
Thanks Jeff
The only problem is that I already bought this disk. I'll see if I can get those parts to put it in the car.
Cheers
Ramiel is offline
Old 07-19-2007, 11:10 AM
  #2050
gansei's Avatar
Hi guys,
maybe... this product(K1349,MTX-4 Hardened Vent Brake Disc)
will fit on RRR-evo
gansei is offline
Old 07-19-2007, 04:31 PM
  #2051
will fit on RRR-evo
Have anyone ever tried this?
Thanks for the tip gansei
Ramiel is offline
Old 07-19-2007, 04:33 PM
  #2052
Riketsu's Avatar
Trader Rating: 33 (100%+)
I had this on my MTX-4... It works great... But reduces the lifespan of the Brake pads alot...
Riketsu is offline
Old 07-20-2007, 05:06 AM
  #2053
Did you use with the k factory pads or the stock ones?
Ramiel is offline
Old 07-20-2007, 10:36 AM
  #2054
I've found this one fits the Evo:
G4 Lightweight Vent Brake Disc
Item No : K1443
http://www.kfactoryracing.com/produc...1443&pageNum=1
Thanks for all your help
Ramiel is offline
Old 07-21-2007, 10:24 AM
  #2055
nitrodude's Avatar
I have the car setup with all the rollcenter spacers at the highest setting, the hole in the top, what would be the effect of setting them to the bottom?
nitrodude is offline
