Old 07-12-2007, 03:21 AM   #2011
Dynamite's Avatar
Send a message via MSN to Dynamite
not much room between my belt and s/saver either. i can see where the belt rubs on the s/saver - there is no goove or anything sinistar developing on my car, i guess if you do alot of driving it might wear very bad. i pull my car down after each race meet to check and swap out evil looking parts and so far it doesnt look like to much of an evil problem
www.racingfactory.org
Kyosho RRR Evo | Sirio Evo III STI | Ko Radio
Dynamite is offline   Reply With Quote
Old 07-12-2007, 05:24 AM   #2012
carkillaii's Avatar
Had the same problem and im still running the same belt
carkillaii is online now   Reply With Quote
Old 07-12-2007, 06:14 AM   #2013
H4gI's Avatar
Do you know the Mr.Dremel? (Manufacturer of hand held rotary tools )
It fix everything!!
H4gI is offline   Reply With Quote
Old 07-12-2007, 07:24 AM   #2014
Ice_nl's Avatar
Send a message via MSN to Ice_nl
Did some changes to my car and brought the weight down to 1730 Gr (inc tyres, body and receiver battery).
I also removed the roll bar as i don't see any use for it when running an touring car body?
I also removed the transponder mount and modified the servo mount so i could put the transponder in there for a cleaner look. I haven't tested it yet so i don't know if the servo affects the transponder range.
RC-Models.nl | Shepherd Velox V8 EC OM-Edition | Shepherd Velox F1 | Buri Racer E1.2 | Tamiya 419x
Ice_nl is offline   Reply With Quote
Old 07-12-2007, 12:09 PM   #2015
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
Ice_nl: Nice paint job you got there. What bodies are you running?
doki_doki is offline   Reply With Quote
Old 07-12-2007, 10:26 PM   #2016
Trader Rating: 13 (93%+)
Good work Ice
What other mods/ hops have you used to get the weight down?
mrgsr is offline   Reply With Quote
Old 07-13-2007, 08:43 AM   #2017
stevenc's Avatar
well guys raced my new evo for the first time tonight. Been driving a shaft car for the last 2 years nearly and what can I say. what a fantastic car the evo is. The car made me look good tonight I wasnt all over the place like I was before with my previous car, cant get over how smooth they are to drive. Just got to sort out my clutch engagement so I can kick some arse at the next meeting.
stevenc is offline   Reply With Quote
Old 07-13-2007, 10:50 AM   #2018
rcabj's Avatar
Originally Posted by Ice_nl View Post
love your paint job....kewl
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 07-14-2007, 02:37 AM   #2019
Default Stripping Belts
Hi Everyone
I have put hop-up aluminium pulleys on my RRR but I am still running platic on the front and rear drive shaft, therefore it is a plastic and aluminium combination for the front and rear belts. I managed 23 laps last week when the front and rear belts stripped.
I would appreciate some advice on the following:
1. Must I remove the aluminium pulleys and retain the standard plastic
2. Are there stronger belts that I can use?
3. What can I do about belt tension to avoid stipping belts again?
Stu
StuartBloys is offline   Reply With Quote
Old 07-14-2007, 02:52 AM   #2020
Grassy's Avatar
Originally Posted by stevenc View Post
gday fellas I just built my evo and I cant see what I have done wrong. Does anyone have problem with the front drive belt rubbing on the steering servo saver assy. Cant adjust the pulleys to give the belt clearance as they are fixed in position. Cant believe its designed like this , I ended up taking it out to run in etc and worn nice groove in the servo saver assy. Cant be right so any ideas. Thanks
Also make sure you have the plastic spacer tube between the outer pulley and the outer bearing on the bearing carrier
cheers
Chris
-ACE HOBBY DISTRIBUTORS AUSTRALIA-
Grassy is offline   Reply With Quote
Old 07-14-2007, 05:33 AM   #2021
nellguess's Avatar
Send a message via Yahoo to nellguess
Where to buy cheapest kyosho v-one rrr Evo World Edition and novarossi engine via online preferably US site? Thanks for your reply.
cheers,
nellguess
nellguess is offline   Reply With Quote
Old 07-14-2007, 07:02 AM   #2022
Send a message via Yahoo to Nutso94
Post Kyosho RRR World Class Edition For SALE
I have a Kyosho RRR World Class Edition for SALE. I am located in Maryland. I am always at C Whit's Hobby Shop, which is located in Clinton, Maryland. I can also be reach at [email protected]
Nutso94 is offline   Reply With Quote
Old 07-14-2007, 09:29 AM   #2023
GMartinez's Avatar
Trader Rating: 85 (100%+)
cheers,
nellguess
You can check out www.pnphobbies.net
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 07-14-2007, 09:48 AM   #2024
litespeed-dom's Avatar
Originally Posted by StuartBloys View Post
Hi Everyone
Stu
Stu, hopefully I can give you some help. I've had problems with stripping belt last year, and after consulting with the team about it, they'd recommend me for the following. But, before I tell you, I need to ask if you are using Kyosho own optional aluminum pulleys? I remember before Kyosho, I ran Team Magic aluminum pulleys in my Mugen MRX-3, and they were stripping belts left and right. Reason being is the quality of the parts, after running for certain period of time, the teeth of the pulleys were sharpened into a triangle and essentially cutting the belt in 1/2. So if they aren't Kyosho pulleys, I would say take them off. And I have ran Kyosho pulleys last year and the teeth remain rounded and it doesn't cut the belts.
Ok, so here are remedies for stripping belt or what not.... I ended up using non-SP belt. Yes, it is harder and makes your drivetrain less free, but I'd rather finish a race then not, the non-SP belt is also a stronger belt. Also check and change your pulleys often, make sure they are in good shape. Another recommendation is change your belt! Eventhough cosmetically they look fine, change it after so many runnings with it, especially the front and rear belts. I would recommend changing front belts every 2 or 3 club race days and rear belts every 3 or 4 club race days. On bigger races, I put brand new belts in before the A-Main regardless whether I have already put new belts in earlier that day. Trust me, I was having problem with stripping belts, twice I was in the lead and popped a rear belt last year. Also remember, changing belt is part of good maintanence to your car anyway to ensure it runs in tip top shape.
BTW, in my RRR last year, I'd ran 2 Kyosho aluminum pulleys, 1 is the brake pulley, the other one is the pulley from the middle bearing block, all others are stock plastic pulleys. And after I'd switched to non-SP belts, I'd never stripped a belt again. My regional was a 45 min Main and I'd finished.
Hope this helps.
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 07-14-2007, 12:34 PM   #2025
Goingfast's Avatar
Trader Rating: 29 (100%+)
Hope this helps.
Dom
Hi Dom
How are you today??
Well some how I'm still running the same kit belt since last year
I know as soon later I need change as welll..... You Gone thur two belts Hmmmmmmm Maybe your driving or going toooooo fast buddy.....lol
Goingfast is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
