Old 07-09-2007, 03:53 PM   #1996
Ice_nl's Avatar
Send a message via MSN to Ice_nl
i used robbe special oil for bearings.
RC-Models.nl | Shepherd Velox V8 EC OM-Edition | Shepherd Velox F1 | Buri Racer E1.2 | Tamiya 419x
Ice_nl is offline   Reply With Quote
Old 07-09-2007, 04:06 PM   #1997
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
Ice_nl: Try checking you oneway bearing for the first gear. Also try to check if the tooths of the rear belt are still ok. I have had a similar problem before the I was able to run the car with no problems at slower speeds. And when the second gear kicks in, there is total loss of power since the rear belt is slipping already. Try also to check the set screw that holds the 21T pulley attached to the main shaft holding the 2 speed gears. It it's loose, this could also cause similar problems... Hope this helps
doki_doki is offline   Reply With Quote
Old 07-09-2007, 05:54 PM   #1998
robert maestrey's Avatar
Originally Posted by rmdhawaii View Post
Hey there Robert, hope all is well with you also.
I'm back to racing my RRRs after rebuilding them. I had a bit of problem obtaining the Acer Bearings I'm using now, so they were laid up for longer than I expected. Boca gave me a full refund on my ceramics BTW.
Since my CRF is laid up until I fix it, I've been racing the STI. I've had some challenges getting it to accelerate as fast as my CRF on our track, but I think I figured it out. Looks like my gearing needs to be 15/60, 20/55!
So what's new with you? What engine you planning on running for the first race?
Nice to hear your back....same old just getting ready for the 07-08 year hopefully I can attend some more events this year.. for motors Murnan power..so whatever he tells me to run ill take his word for it because he is the man..just finishished winning a little local race that is put on every year with one of his 12+ modded motors..the man does great work.
robert maestrey is offline   Reply With Quote
Old 07-09-2007, 06:22 PM   #1999
GMartinez's Avatar
Trader Rating: 85 (100%+)
Originally Posted by tony montana View Post
does anyone know if kyosho still makes the evo conversion kit? Or anyone that may have one?
It is still available just got off the phone with the team manager
Evo conversion kit #ENS1
spool has just arrived #VZW220
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 07-09-2007, 06:23 PM   #2000
GMartinez's Avatar
Available on there website shopatron or just have your LHS order it
Old 07-09-2007, 06:37 PM   #2001
rmdhawaii's Avatar
Yo G!
ENS1 is the V-ONE RRR EVO WC conversion kit:
http://www.shopkyosho.com/product/pa...ber=ENS1/410.0
36502 is the standard RRR or RRR WCE to Evo conversion kit:
http://www.the-border.com/product.ph...39&page=1&js=n
What is in the contents of ENS1?? Couldn't find anything online, but notice in the photo, it comes with a fuel tank!
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 07-09-2007, 07:18 PM   #2002
GMartinez's Avatar
Yo G!
Can't remember all the details so here is what i remember
new upper deck
brake pulley
main shaft
I will try to get more info the pic that is on the kyosho site looks to be incorrect
Old 07-10-2007, 05:09 PM   #2003
dougday's Avatar
Yo G!
ENS1 does not come with a fuel tank
dougday is offline   Reply With Quote
Old 07-10-2007, 05:11 PM   #2004
dougday's Avatar
new upper deck
brake pulley
main shaft
That picture is the 03 to 05 upgrade kit for the evolva
Old 07-10-2007, 06:36 PM   #2005
GMartinez's Avatar
What's up Doug
I saw that as well & Im still awaiting info from kyosho america
Old 07-10-2007, 07:29 PM   #2006
GMartinez's Avatar
Here is the info i got from my team manager @ kyosho america
ENS1 is designed to take the regular WC to the WC Evo edition. That is
the only conversion we currently have for the RRR.
Any ?? just call kyosho america
Old 07-10-2007, 07:57 PM   #2007
doki_doki's Avatar
Yo G!
From the looks of the picture on the ENS1, it looks like it is intended to convert the EVO to a Lola set-up... Just my 2 cents
Old 07-11-2007, 09:26 PM   #2008
stevenc's Avatar
gday fellas I just built my evo and I cant see what I have done wrong. Does anyone have problem with the front drive belt rubbing on the steering servo saver assy. Cant adjust the pulleys to give the belt clearance as they are fixed in position. Cant believe its designed like this , I ended up taking it out to run in etc and worn nice groove in the servo saver assy. Cant be right so any ideas. Thanks
stevenc is offline   Reply With Quote
Old 07-12-2007, 01:45 AM   #2009
Wild Tiger's Avatar
Mine don't, have never had a problem.
Only thing I can think of is, on the servo saver holder where the 'screws go in' that hold the arms that go to the wheel hubs -- Are the screws you used too long and when you turn right it rubs on the belt ??
Wild Tiger is offline   Reply With Quote
Old 07-12-2007, 02:46 AM   #2010
rmdhawaii's Avatar
You're not the first person to wear a groove in your servo saver assembly.
I can't explain why, but this does happen to some people. The clearance between the belt and the assembly is pretty tight to begin with, so there are a number of possibilities. My guess is, belt drift on the pulleys themselves. Things I would recommend checking are side-to-side play in the front axle and ensuring that the belt tensioner settings (L/R) are the same.
Look on the bright side. Now that you've got that nice groove there, you don't have to worry about it anymore.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
