Old 06-21-2007, 09:35 PM   #1906
kaotickc's Avatar
Trader Rating: 43 (100%+)
Originally Posted by rmdhawaii View Post
Ah, I see. Still could use the photo though. I'm trying to visualize where the problem is. On my CRF header, I ended up filing down the parts that were touching the belt. A photo can be found here: http://www.nitrokb.com/phpBB2/viewtopic.php?p=97#97
kaotickc is offline   Reply With Quote
Old 06-21-2007, 09:36 PM   #1907
kaotickc's Avatar
Thats with the tensione completely loose....and the belt is still tight as can be
Old 06-21-2007, 10:00 PM   #1908
rmdhawaii's Avatar
Tight is not good.
You have several options, all of which we can continue to discuss before you take any action.
- Raise the engine. Not your best option, but I had to do this in the past.
- You can probably file down the header tab that is touching the tensioner and drill a new hole for the header spring.
Is the belt touching the bottom of the pipe at this point?
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 06-21-2007, 10:06 PM   #1909
kaotickc's Avatar
Yes, the belt is touching the header.
Old 06-21-2007, 10:16 PM   #1910
rmdhawaii's Avatar
Also not so good.
What you might want to try and do, is use some 1-2mm shims to raise the engine and see if it's still touching. I'm not saying to run the car like that, just see what type of clearance you'll need to clear the tensioner and/or the belt and get some proper tension.
Have you got any other pipes or headers lying around? Like perhaps a Skyline VR12 Plus? Have you got any other engines?
Old 06-21-2007, 10:20 PM   #1911
kaotickc's Avatar
Also not so good.
Ya, I have an O.s. Tz with an ofna pipe I will try tomorrow.
How much play should be in the side belt. I know the mtx4, it was waay loose. The Ky manual doesnt really tell how loose or tight to have it.
Old 06-21-2007, 10:32 PM   #1912
rmdhawaii's Avatar
Yeah, the Mugen belt is way too loose. RRR belts never get that loose. Tension wise, I usually move the tensioner down so that it just holds the belt down. If you push the belt down with your finger, there should be some give, but not a whole lot. It should feel a bit loose.
Old 06-21-2007, 11:23 PM   #1913
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
The belt (I use the SP belt) will loosen up pretty quickly. I had the same concern when I built my car. It will stretch a little bit.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 06-22-2007, 02:23 AM   #1914
Chemical X's Avatar
Trader Rating: 16 (100%+)
I'm not familiar with the Ninja engines but comparing one of your pictures to my OS, it seems like the exhaust port is quite a bit lower on the Ninja. But that sounds like problem # 2.
The part I'm more concerned with is that you mention the tensioner is completely loose and the belt is still very tight. What pulleys are you using on the main shaft and middle shaft? Are you sure they are the correct size per the instruction manual?
Chemical X is offline   Reply With Quote
Old 06-22-2007, 06:29 AM   #1915
kaotickc's Avatar
23 on the front, and 18 on the rear. Ones that came with the kit. Like I said, this is my first ky kit...so I am in a little bit of unfamiliar territory. The belt is the 384...if that helps any.
Old 06-22-2007, 07:35 AM   #1916
stevenc's Avatar
gday fellas, in the process of buying an evo, usually buy my gear from rcchamp but they said he cant get his hands on the new wce team evo for quite a while. So looking at seeing if they can get me the vone rrr evo instead. Questions are I also seen rcmarket online here and they seem to have a good price on the RRR evo , has anybody dealt with rcmarket before and any feedback from using them.
I am bit confused with the Vone market, Kyosho has so many bloody models of this car. I have owned a modded FW 05t for about 2 years now so looking to make the step up, my question is should I try and get my hands on the wce team evo or will the RRR evo be more then enough for me. Looks like easy to upgrade parts if I needed to and the price looks good imo compared to the wce team evo.
stevenc is offline   Reply With Quote
Old 06-22-2007, 09:55 AM   #1917
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
Hi there...How's the CRF engine holding up?
doki_doki is offline   Reply With Quote
Old 06-22-2007, 10:42 AM   #1918
rmdhawaii's Avatar
Actually, it's doing surprisingly well. Very fast. Since I upgraded a bunch of parts on it (too many to list at the moment ), it runs much, much better than version 1.0.
Old 06-22-2007, 04:05 PM   #1919
GMartinez's Avatar
Trader Rating: 85 (100%+)
the ninja engine sit's slighly lower than some other engines i had to take it out for now since it caused 2 belts to stretch since it was rubbing against the pipe
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 06-22-2007, 09:09 PM   #1920
kaotickc's Avatar
Really..so there was no way around it? Would shimming the engine so it sat higher be a good option, or what about turning the belt tensioner so it faced the other way?
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
