Old 06-04-2007, 07:09 PM   #1846
rmdhawaii's Avatar
Are you guys greasing up your outdrives at the start of each race day? Mine seem to last a very long time with very little sign of wear.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 06-04-2007, 07:13 PM   #1847
rmdhawaii's Avatar
You could also try these and let us know if they are any better.
http://www.kfactoryracing.com/produc...1923&pageNum=1
Old 06-04-2007, 08:11 PM   #1848
Trader Rating: 244 (99%+)
Does any one know the spring rates of the stock black and gold springs in LBS? Thanks
Fred Perkins is offline   Reply With Quote
Old 06-05-2007, 12:51 AM   #1849
Dynamite's Avatar
Send a message via MSN to Dynamite
i know people that do and some that dont. i personally dont, but this is because our truck can be quite dusty between the fortnights we have our club days and i found by adding a little grease to the outdrive joints that it turned more into a grinding paste with the dust present.
i dont know if it is just me, but i have found the std outdrives and bones that come with the std evo kit to be of much better quality to the ones that came with my origional RRR wce kit, where i would of been thinking about swapping my outdrives on my old kit, the evo's haven't even appear to have any wear at all and still look brand new.
www.racingfactory.org
Kyosho RRR Evo | Sirio Evo III STI | Ko Radio
Dynamite is offline   Reply With Quote
Old 06-05-2007, 09:01 AM   #1850
Ice_nl's Avatar
Send a message via MSN to Ice_nl
Originally Posted by tl2111 View Post
you should use less droop and more caster for more on power steering
So you're saying i screwed up the balance in the car by using the droop settings wrong. and my problem is that i need more steering? Would explain a lot off things, will try it with the stock setup and more caster next race.
RC-Models.nl | Shepherd Velox V8 EC OM-Edition | Shepherd Velox F1 | Buri Racer E1.2 | Tamiya 419x
Ice_nl is offline   Reply With Quote
Old 06-06-2007, 03:54 PM   #1851
Originally Posted by Chemical X View Post
I haven't tried these outdrives as I've only used the stock ones and I agree that stock ones are weak.
Question for everyone... Without flipping the outdrives to use the other side, how long are the outdrives lasting on your cars? Since it's difficult to measure this by distance or even time, I'm gauging it by the amount of fuel used.
In my situation, I just finished a gallon of fuel on a new V-One-RRR Evo WCE chassis and the outdrives are so worn that it was causing handling issues. What was occurring was the CVDs would stick in the worn out section and bind up the suspension. This caused a "chatter" or "hopping" effect on acceleration and induced a push to the car in high-speed turns.
Ive found that mine normally only last 2-3 meetings max before I have to swap them out -- even putting heat shrint around the cup to retain the grease is nut helping too much. I have ordered a set of these Factroy Pro jobbies and i'll let you know how I get on.
Tricknut is offline   Reply With Quote
Old 06-12-2007, 01:37 PM   #1852
RC MARKET's Avatar
lightweight only !
RC MARKET is offline   Reply With Quote
Old 06-13-2007, 09:18 AM   #1853
kaotickc's Avatar
Trader Rating: 43 (100%+)
What are you guys using to seal or cover the rx ?
Anyone got any pics of theirs with what you do to keep debris out?
"D"
kaotickc is offline   Reply With Quote
Old 06-13-2007, 03:52 PM   #1854
GMartinez's Avatar
Trader Rating: 85 (100%+)
"D"
some guys will use the ballon method & some others are using the mtx receiver cover
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 06-13-2007, 05:03 PM   #1855
kaotickc's Avatar
Ok, so the cover off the MTX4 will fit?
Old 06-13-2007, 05:11 PM   #1856
GMartinez's Avatar
It should since it really did not change at all from the mtx3
Old 06-13-2007, 05:12 PM   #1857
GMartinez's Avatar
Also the serpent receiver cover will work as well
Old 06-13-2007, 05:13 PM   #1858
GMartinez's Avatar
Ron see you peaking can you pm me the item # for the gurney strips you use on your body
Old 06-14-2007, 12:56 AM   #1859
Send a message via AIM to Berwick.G
Default NEED HELP BUILDING V-ONE RRR EVO WCE
I am currentlybuilding the kyosho v-one rrr evo wce. I am on page 9 of the manuel. Where I am constructing front upper suspension. I am having trouble understanding how I am suppose to align the suspension bush. my question is do I use the same suspension bushes for the left upper suspension as the right upper suspension and do I place them in any particular alignment. recall there to types of suspension bushes. bush A and bush B. I am going to post pictures. can some one please help. I basically need some one to tell me which suspension bush I have to you (A or B), which way I have to allign the bush right side up or upside down. I have attached a pisture as to which step it is in the manuel. it is step six. I basically need somone to walk me through this step.
Berwick.G is offline   Reply With Quote
Old 06-14-2007, 12:56 AM   #1860
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
