Old 04-24-2007, 08:43 PM   #1651
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
As dumb as this sounds, I stripped 3 2nd gear spurs in just a few laps. The reason(s) were as follows.. Mostly because I am a bonehead. This happened after I rebuilt the car for the main event this past weekend. The first one went because I didn't tighten down the screws that hold the engine to the engine mount. I checked to see if the mount was tight to the chassis and it was, so I put another gear on. That one stripped almost immediately. I then found the loose engine and tightened the screws. I took off that dead gear and removed the bearings and put them into another spur. At that point I decided I wanted to try a different ratio so I grabbed a different 2nd gear and put it on the car without the two bearings. Believe it or not it lasted an entire tank, but I noticed it was pretty well chewed up when I brought it back to the pits. I figured out what I did that time and put a third spur gear on with the bearings and all was back to how it was supposed to be. I have had no mystery gear stripping with this car. This car is good.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 04-24-2007, 08:48 PM   #1652
I was talking to a friend today about the problem and he said to check the shaft, also the only other thing is that I wasn't using the one piece mount, and kept thinking that that ay have been the prob. I got the one piece mount on now, but haven't had a chance to test.
I'll be taking the shaft off and I'll check the bearings while I'm at it.
Thanks again,
havy
havy is offline   Reply With Quote
Old 04-24-2007, 08:51 PM   #1653
rmdhawaii's Avatar
Originally Posted by JRRobiso
Can anyone list the part #s needed to make a complete diff for the front & also where I can get them in the event my LHS doesn't have all the parts needed in stock.
Thanks for the help.
Check the back of your manual, in the section with the list of parts. Should be similar to what is in the standard RRR WCE manual as shown here:
http://www.nitrokb.com/phpBB2/viewtopic.php?t=17
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 04-24-2007, 08:53 PM   #1654
Yeah, I'm not perfect either, I just didn't get a chance to test further. I'm going to recheck everything and test sometime this nextt weekend.
havy
Old 04-24-2007, 08:55 PM   #1655
rmdhawaii's Avatar
One last thing... Make sure that the tuned pipe is not connected to the engine when you adjust the gear mesh.
Old 04-24-2007, 09:17 PM   #1656
Send a message via MSN to wiggindude
Default motor
one more thing to check is the length of the screws. if they are too long the will bottom out into each other and not tighten down.
Been there done that. Spur gears get costly. I check every race. Just in case I bump anything...
That winding noise is hard to forget once you strip 2nd gear and only have 1st...
wiggindude is offline   Reply With Quote
Old 04-25-2007, 01:21 PM   #1657
RC MARKET's Avatar
Do you is more gap ?
or use 3 Racing gear .
RC MARKET is offline   Reply With Quote
Old 04-25-2007, 03:34 PM   #1658
im currently building the kit, but what servo setup do i use for Hitec?
Trilordy.com is offline   Reply With Quote
Old 04-25-2007, 03:37 PM   #1659
scott coming from you this is amazing! just goes to show you even the veterans have bad days!
Ahhh the smell of nitro in the morning!
Brooklyn Hobbies Team Driver
[url]www.brooklynhobbies.com[/url]
Team Trinity
[url]www.teamtrinity.com[/url]
Gary Figueroa
GFIGUEROA is offline   Reply With Quote
Old 04-25-2007, 04:10 PM   #1660
Old 04-25-2007, 11:36 PM   #1661
I don't understand your question. I use only the Kyosho gears..
Old 04-25-2007, 11:38 PM   #1662
Every once in a while I am a bonehead. Everytime I rebuild my car before a main, I always try to run at least 2 mins if not an entire tank well before my main just to make sure I put it back together correctly. I am glad I did it this time or my main would have been very short.
Old 04-25-2007, 11:49 PM   #1663
Derby Bros Racing's Avatar
Originally Posted by Dbackmasta
I have limited arm strength so it's a major consideration. Thanks and keep the feedback coming please!
Wrenching on your car would be no issue when you race with us... we will help you bro
I'm very excited to see you thinking about getting an onroad car again
Derby Bros Racing is offline   Reply With Quote
Old 04-26-2007, 01:19 AM   #1664
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
havy
Making sure there is play between 1st and 2nd gear on the shaft, gear box shoe is turning round not oval in 2nd gear with little gap. hope this help
*Tourer**Futaba***SpeedPassion
*F1**4PX***TORO
*12th**4PX***TORO
*8th**4PX***OS Speed XZ-R
*10th**4PX***OS Speed XZ
tl2111 is offline   Reply With Quote
Old 04-26-2007, 02:22 PM   #1665
I know you guys will hook me up!
Dbackmasta is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
