Old 04-23-2007, 05:03 PM   #1636
gtrmx's Avatar
Well,
I think the only complaint regarding diffs is the o-ring they seal with. It gradually leaks the diff grease.
I have used other seals, like the TM G4S diff seal, re-shimmed the gears to compensate for the extra space and from then on had no leaking.
gtrmx is offline   Reply With Quote
Old 04-23-2007, 06:09 PM   #1637
GMartinez's Avatar
Trader Rating: 85 (100%+)
Originally Posted by gtrmx
Well,
Then you might be overfilling the diff. I never had a diff leak & never had a problem with the O ring seal shimmed or not shimmed but when I ran the old GE E Class I did have an issue with it but not with the old RRR & EVO Diff's
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 04-23-2007, 07:59 PM   #1638
Dynamite's Avatar
Send a message via MSN to Dynamite
if you do slightly over fill the diff's you will get some leakage.
if you only fill them to bevel shaft level and you shouldnt have any problems.
www.racingfactory.org
Kyosho RRR Evo | Sirio Evo III STI | Ko Radio
Dynamite is offline   Reply With Quote
Old 04-24-2007, 07:48 AM   #1639
fritzD's Avatar
Send a message via Yahoo to fritzD
fritzD is offline   Reply With Quote
Old 04-24-2007, 06:40 PM   #1640
Which is easier to work on? V One RRR or FW05 RR?
Dbackmasta is offline   Reply With Quote
Old 04-24-2007, 06:44 PM   #1641
i have both and i feel they are pretty equal, both radio trays come off without too much work so in that aspect they are the same! The VoneRRR has a bigger tray so once you get it off its an easier clean up but thats it.
Trilordy.com is offline   Reply With Quote
Old 04-24-2007, 06:55 PM   #1642
I have limited arm strength so it's a major consideration. Thanks and keep the feedback coming please!
Old 04-24-2007, 08:00 PM   #1643
Get something similar to this and you won't have to use as much arm strength anywhere, they make every type of bit you can think of in a hex shank
brianhatesnitro is offline   Reply With Quote
Old 04-24-2007, 08:15 PM   #1644
OK, drove the car this past wknd and the car is a dream. Didn't get a chance to drive it much though, had some serious problems stripping the 2nd gear spur. Didn't last more than 3 laps w/o stripping the sprur. Now there are several RRR racers over hear and all were in awe of what was happening. We re-set the motor for proper mesh, checked the clutch, verified the one way, even changed the shift point to shift earlier( 3 1/4 turn out on the 2nd gear clutch) but couldn't find the freaking problem. I went through 4 2nd gear spurs each with less than 5 laps on them.
Has anyone else had this problem, what could it be? I loved the car, just wish I could have run it a little longer to get a feal for the car. I need to resolve this problem, any help is appreciated.
Thanks,
Havy
havy is offline   Reply With Quote
Old 04-24-2007, 08:26 PM   #1645
huskerfreak's Avatar
I would check all your bearings along the pully shaft that the gears ride on. I had a smilliar problem on an MTX3 and it was that I had a bad bearing on that shaft. This would cause that shaft to spin out of round.
huskerfreak is offline   Reply With Quote
Old 04-24-2007, 08:35 PM   #1646
rmdhawaii's Avatar
Thanks,
Havy
I don't think I've ever come across someone stripping that many gears on a RRR in one day. And to strip a gear on a new car? I might be mistaken, but that doesn't happen much either. Since you got help from other RRR racers at the track, it's even more puzzling. Not quite sure what to tell you. Maybe someone else has an idea.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 04-24-2007, 08:38 PM   #1647
rmdhawaii's Avatar
Maybe you'll see something in this post. I wrote it back in April: http://www.nitrokb.com/phpBB2/viewtopic.php?t=55
Old 04-24-2007, 08:40 PM   #1648
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
Exclamation Front Diff Parts List
Can anyone list the part #s needed to make a complete diff for the front & also where I can get them in the event my LHS doesn't have all the parts needed in stock.
Thanks for the help.
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 04-24-2007, 08:40 PM   #1649
wow, I just built this thing, these are new kit bearings. I'll give it a look, shoot I'll try anything to fix this problem.
Old 04-24-2007, 08:43 PM   #1650
"Maybe you'll see something in this post. I wrote it back in April: http://www.nitrokb.com/phpBB2/viewtopic.php?t=55"
Yeah, I'll take a look
thanks for the quick replies.
havy
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
