Old 04-20-2007, 12:45 AM   #1621
Trader Rating: 13 (93%+)
mad price
i also noticed they sell the v-one rrr wce for 309!! us
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 04-20-2007, 03:21 PM   #1622
robert maestrey's Avatar
Originally Posted by Ice_nl
What parts would be a good idea to change if you want to get some weight of the car, mine weights now at around 1800gr and i would like to come closer to the minimum weight of 1725gr. I am running an EVO WCE.
I would recommend lightening your rotating mass as much as possible. This will allow the car to spool up faster allowing to accelerate better. Also, try and remove as much as weight as possible, pivot balls, tie rods, screws, etc. When the weight of the car is below the legal limit then you can focus on adding weight back to the car. Try to centralize this added weight under your battery. You can also, try to have a battery tray made out of a heavy material putting this weight in this location will help CG of the car. Be creative!
Hope this helps
Sippin Coladas and Chillin
robert maestrey is offline   Reply With Quote
Old 04-20-2007, 11:04 PM   #1623
[QUOTE=robert maestrey]I would recommend lightening your rotating mass as much as possible. This will allow the car to spool up faster allowing to accelerate better. Also, try and remove as much as weight as possible, pivot balls, tie rods, screws, etc. When the weight of the car is below the legal limit then you can focus on adding weight back to the car. Try to centralize this added weight under your battery. You can also, try to have a battery tray made out of a heavy material putting this weight in this location will help CG of the car. Be creative!
Hope this helps [/QUOTE
Whats up Robert how is things with you.See you are doing well man keep up the good driving man.Btw say hello to Peter and Chris for me when u talk to them or see them
bullie1 is offline   Reply With Quote
Old 04-22-2007, 02:21 AM   #1624
A
A's Avatar
Send a message via MSN to A
can someone gimmie a heads up... ive installed a spool, 24 tooth front pully and the 387 tooth side belt. should i be using equal tyre diameters front and rear for the 1:1 drive ratio now? is there anything else i should be doing to finish spool setup..??
A is offline   Reply With Quote
Old 04-22-2007, 05:37 AM   #1625
twiggy's Avatar
Hope this helps
what does your car weigh including body, transponder, no fuel and no added extra weight?
www.Moorebankraceway.com
Hamilton 2008 F1 champion!
twiggy is offline   Reply With Quote
Old 04-22-2007, 08:22 AM   #1626
ATOMIC's Avatar
Robert , you will get a kit out of this , I just TQed the Mugen Grand Prix in Vegas and my car is 1815 , LOL . Obserd HUH. I know a lighter car is better for acceleration but it was handling so good I did not want to touch it. The Novarossi 353 was pulling it just fine.
ATOMIC is offline   Reply With Quote
Old 04-22-2007, 08:27 AM   #1627
my car weighs 1745g
thats no fuel, 55/55 tires (the smallest i run), mazda 6 and personal
thats the way atomic TQ the mugen race with a RRR hehe
Old 04-22-2007, 10:30 AM   #1628
jeff1's Avatar
anybody here use Acre Brake Pads? Part number IFW324
I've been using APP and very happy with it, but soon i would replace them
any comment? How is brake power, durability and consistency? Hold brake under racing conditions?
later
jeff1 is offline   Reply With Quote
Old 04-22-2007, 10:59 AM   #1629
Eric Gebhard's Avatar
I have been using those brake pads for the past 4 months. They work great. Tons of braking power, no fade and very little wear. Overall I have been very happy with them.
Eric Gebhard is offline   Reply With Quote
Old 04-22-2007, 08:38 PM   #1630
jeff1's Avatar
that's helpful. Will try together with VZW015 Special Rotor
I have started to rebuild the clutch
I was reading Josh Cyrul tips for Clutch tuning and I decided to try it on my car.
First I set the clutch gap in 0.5mm without inner bearing, I could accurately measure with Kyosho Remover Pinion tool. Then I shimmed end-play with 0.11mm of shims to avoid bell to get on the clutch shoes. Did I make it correct? What's my endplay now, 0.11mm? I fired the car and everthing seemed to work normal
Old 04-22-2007, 10:08 PM   #1631
kyosho 444's Avatar
kyosho gooooooood
kyosho 444 is offline   Reply With Quote
Old 04-23-2007, 11:37 AM   #1632
Why doesnt kyosho make new diffs?
Xtreme2008 is offline   Reply With Quote
Old 04-23-2007, 01:50 PM   #1633
GMartinez's Avatar
Trader Rating: 85 (100%+)
What's wrong with the current diff's
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 04-23-2007, 03:52 PM   #1634
fritzD's Avatar
Send a message via Yahoo to fritzD
fritzD is offline   Reply With Quote
Old 04-23-2007, 04:53 PM   #1635
does anyone use the Kawahara Negative Diff?
Trilordy.com is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
