Old 04-12-2007, 06:30 PM   #1501
GMartinez's Avatar
Trader Rating: 85 (100%+)
Originally Posted by jeff1
Does anybody glue diff o-rings to the diff case? The manual asks for, but I can't see benefit doing that :confused
I'm rebuilding my RRR shocks, and I noticed the right shock has more travel on the shaft when I pull against the shock body, its stop in the end of the stroke and the left shock shaft stop in the middle. What am I suppose to do? And what's "rule" to build the shocks properly
thanks
I don't glue the diff rings
check your shock shafts to ensure they are not bent or if you are using pliers to hold the shaft it could be scratched & that will cause the problem
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 04-12-2007, 07:15 PM   #1502
jeff1's Avatar
Yes I use pliers to hold the shaft, but I cover with a old t-shirt to avoid damage
after remove bubbles do you insert diaphragm and press it down? Or you just let it seat in shock body and then tighten the cap? Maybe leaked more excess oil of left shock
How is the correct "configuration" for this travel? Do they have to return fully after push or stop on the middle or even don't move? The manual don't explain that
PS. I checked the shafts and they aren't bent
jeff1 is offline   Reply With Quote
Old 04-12-2007, 07:42 PM   #1503
Eric Gebhard's Avatar
When I fill the shocks I fill them to the top then pump the piston a couple of time then and let the air bubbles rise to the top. Next I top off the shock with oil, place the bladder on the shock but I don't press it down. Then I screw the cap on. The excess oil should leak out the cap. After I build the shocks and I compress the piston it slowly returns most of the way out. To take the shock ends off this is the tool that I use.
Team Shock Shaft Maintenance Plier
It works really well and does not damage the shafts at all.
Eric Gebhard is offline   Reply With Quote
Old 04-12-2007, 07:57 PM   #1504
Chemical X's Avatar
Trader Rating: 16 (100%+)
Attached is an image from an older XRAY manual I have which demonstrates a good shock assembly procedure. It explains how to use side cutters to hold the shock shaft without damaging it. It also explains how to properly install the top seal before screwing on the top cap. Hope it helps...
Chemical X is offline   Reply With Quote
Old 04-12-2007, 08:51 PM   #1505
GMartinez's Avatar
I would invest in the integy shock tool
Old 04-12-2007, 08:55 PM   #1506
GMartinez's Avatar
Jeff the shocks you are rebuilding are they the evo shocks or are they the older version from the RRR WCE
Old 04-12-2007, 09:01 PM   #1507
Dynamite's Avatar
Send a message via MSN to Dynamite
works very well using side cutters to hold the very top thread to screw the end on, no need for an integy shock tool here just a cheap set of $5 side cutters that are in your tool box. this way nothing will scratch or damage your shock shafts in anyway
the new shocks are ace so far, big improvment over my rrr wce shocks.
www.racingfactory.org
Kyosho RRR Evo | Sirio Evo III STI | Ko Radio
Dynamite is offline   Reply With Quote
Old 04-12-2007, 09:02 PM   #1508
Grassy's Avatar
Originally Posted by H4gI
I`m using the CRF clutch and I love it.
Nice performance and the spring is very good to adjust -->you can feel the diference very well.
do you have a link or some pictures of it.
cheers
Chris
-ACE HOBBY DISTRIBUTORS AUSTRALIA-
Grassy is offline   Reply With Quote
Old 04-13-2007, 10:40 AM   #1509
RC MARKET's Avatar
best for Orion Engine
RC MARKET is offline   Reply With Quote
Old 04-13-2007, 03:17 PM   #1510
jag
jag's Avatar
Originally Posted by rmdhawaii
I think I'll just get the KM version and be done with it!
jag is offline   Reply With Quote
Old 04-13-2007, 04:32 PM   #1511
jeff1's Avatar
Awesome information.. thank you
Old 04-13-2007, 04:35 PM   #1512
jeff1's Avatar
they're the older version of RRR
Old 04-13-2007, 08:50 PM   #1513
GMartinez's Avatar
becareful when tighting down the shock cap overtightening will pinch the bladder & will cause your shocks to get air & that's where you might have a problem in rebounding
Old 04-14-2007, 01:16 AM   #1514
Trader Rating: 13 (93%+)
Default 2006 worlds setup
does anyone have the rrr setup sheets from the 2006 worlds at brendale??
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 04-14-2007, 04:48 PM   #1515
Send a message via MSN to wiggindude
Default front spool for RRR V one WC
I cant find a spool for my new kit. Does anyone know who has them in stock?
I dont care if its 3 racing, kyosho or K factory.. anything will do at this point.
thanks
wiggindude is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
