Old 04-11-2007, 09:35 PM   #1486
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
Arrow
Originally Posted by GMartinez
VZW219 they are the silver that comes with the evo a couple of guys had the same problem & it was due to them using the older version which were 45mm
So does the EVO WC (plan to build next month ) that I have, have the longer unis?
I too plan to buy a front spool for mine when built.
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 04-11-2007, 09:38 PM   #1487
GMartinez's Avatar
Trader Rating: 85 (100%+)
Yes the spool was made for the evo & you should have no problem just make sure you set your track width correct.
As for the spool I have mine on backorder from kyosho america can't wait to get it to replace the kfactory unit im using it adds to much weight
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 04-11-2007, 09:40 PM   #1488
boy2rc's Avatar
Originally Posted by rmdhawaii
No wonder I couldn't find it - it's a G4 part.
Does anything special need to be done to fit this in the RRR????
BTW.. Thanks George.
K1477 G4 Alum. Front Solid Axle Set
http://www.kfactoryracing.com/produc...1477&pageNum=1
I using this K Factory K1477 G4 Alum. Front Solid Axle Set in my car almost two years, must using an lathe machine to modify, the both of out driving cup is right its way using in RRR or EVO, but the two bearing need mod inner offset about 2mm, the pulley offset about 1mm, also the 4 fixing screw of the pulley offset about .2mm, using plastic pulley no problem, if using metal pulley must mod a little bit.
I using this for that time no such alum solid product in market, and it is beautiful.
boy2rc is offline   Reply With Quote
Old 04-11-2007, 09:46 PM   #1489
carkillaii's Avatar
I have one on the way what mods are needed to fit my 3r?
carkillaii is offline   Reply With Quote
Old 04-11-2007, 09:49 PM   #1490
JRRobiso's Avatar
Arrow
Are you currently running the KFactory 1-way/solid spool unit on your V1RRR?
Old 04-11-2007, 09:51 PM   #1491
GMartinez's Avatar
I will be milling mine out the version I have is K1477T
Thanks for the lathe tip I never thought of trying it out now I got to be careful & not ruin the diamond bit.
Old 04-11-2007, 10:00 PM   #1492
carkillaii's Avatar
what part of thr spool needs to be milled out and how much?
Old 04-11-2007, 10:00 PM   #1493
rmdhawaii's Avatar
I think I'll just get the KM version and be done with it!
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 04-11-2007, 10:01 PM   #1494
GMartinez's Avatar
Yes & it's good but once the rubber O rings get's weak the pins fly right out
gave me issues in a couple of mains just think about this one was in first had it locked & then all of a sudden every right turn was perfect but every left turn the car had a nasty push after the main I noticed I lost a pin so basically left side was a one way right side was a spool I showed a couple of my friends what happened they were like man you car still looked good & I walked away saying that's why i love my Kyosho your car can be off a tad bit & still performs
Old 04-11-2007, 10:02 PM   #1495
GMartinez's Avatar
wish that was the case but I have 2 of them wich gives me a chance to get 1 right
Old 04-11-2007, 10:04 PM   #1496
GMartinez's Avatar
pulley side 1 mm opposite side 2 mm
Old 04-11-2007, 10:08 PM   #1497
Eric Gebhard's Avatar
Yea that's the problem with the o-ring retainer system. The up side is you can always go to a hydraulics shop and get about 50 of the o-rings for about $2 so you can replace them regularly.
Eric Gebhard is offline   Reply With Quote
Old 04-12-2007, 02:49 AM   #1498
Grassy's Avatar
Has anyone tryed the 2D clutch is it any better than the 3D if so whats the difference in acceleration?
-ACE HOBBY DISTRIBUTORS AUSTRALIA-
Grassy is offline   Reply With Quote
Old 04-12-2007, 05:44 AM   #1499
H4gI's Avatar
I`m using the CRF clutch and I love it.
Nice performance and the spring is very good to adjust -->you can feel the diference very well.
Team NFC
LRP
CAP
Nitro-mechanic-bitch of E.D. and R.V.
H4gI is offline   Reply With Quote
Old 04-12-2007, 05:19 PM   #1500
jeff1's Avatar
Does anybody glue diff o-rings to the diff case? The manual asks for, but I can't see benefit doing that :confused
I'm rebuilding my RRR shocks, and I noticed the right shock has more travel on the shaft when I pull against the shock body, its stop in the end of the stroke and the left shock shaft stop in the middle. What am I suppose to do? And what's "rule" to build the shocks properly
thanks
jeff1 is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
