Kyosho kf01 formula 1 nitro comeback! >
Like Tree10Likes
  • 6 Post By Coderc
  • 1 Post By wely324
  • 1 Post By wely324
  • 1 Post By Coderc
  • 1 Post By Coderc
Old 11-30-2023, 10:19 PM
Default 1/10 formula 1 nitro comeback!
I have been months in the works on working on this class class here are photos of its currently state
Coderc is offline
Old 12-03-2023, 10:41 PM
Default Video footage
https://youtu.be/Ql8HIrEY-Q4?si=hQ7_s64vH-OHWGON
Coderc is offline
Old 12-04-2023, 05:55 AM
so awesome! I would love to build up a nitro F1 kit.
Coderc likes this.
wely324 is offline
Old 12-04-2023, 05:56 AM
Did you have a new kit? or did you build from sourcing parts? And what engine are you using?
Coderc likes this.
wely324 is offline
Old 12-04-2023, 07:18 AM
purchased as an assembled kit. Iíve since swapped the engine with w ofna P-zero I feel the ofna motor could be a lot better that the sirio engine also a way way better carb for tune ability. Iíve done a lot to this thing. I also plan to convert the front suspension im debating between the exotek, Schumacher and X-ray front end. Iíve also made a carbon chassis dropping the weight by 70grams and finding other sources to drop more weight.
Coderc is offline
Old 03-29-2024, 10:33 PM
Default More updates on progression!
Iíve since went from the ofna p zero motor back to the sirio 09 engine with a new blue head sink and have since swapped the front end suspension to independent suspension made by Exotek.
Alain Patry likes this.
Coderc is offline
Old 03-29-2024, 10:37 PM
Next objective is to create upper deck and a reposition the throttle servo.
Coderc is offline
Old 04-02-2024, 12:11 PM
Default independent suspension made by Exotek.
Hi.
you mind sharing the parts numbers needed to switch the suspension to the independent suspension made by Exotek, please?
Thanks again for all the help.
Do you know where I can find a two -speed transmission?
dynam is offline
Old 04-05-2024, 09:36 AM
Originally Posted by dynam
Hi.
two speeds are impossible to find super rare ive seen one pop up once in the last couple years and missed my chance to bid.
the front end isnt a straight swap over. you need to be precise on measuring or have a solid template requiring to drill and taper the holes.
the exotek fronts are also impossible to find as no one wants to let them go i was lucky enough to just crossed paths with the right person.
heres a link to a write up on it
https://www.rccaraction.com/exotek-v...4-exotek-f1r3/
best of luck
Coderc is offline
Old Yesterday, 04:05 PM
Coderc is offline
Old Yesterday, 10:22 PM
fyrstormer's Avatar
Cool!
fyrstormer is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
