Old 12-28-2002, 02:00 AM   #1
Default serious swap
i was thinking it would be fun to put a .21 engine in a sedan. im sure people have done it, but is that common just for bashing? i know you couldnt race with that, but has anyone ever heard of or done this? i think it would be a fun project. how much more power do those motors generally make compared to .12 or .15?
wahturi is offline   Reply With Quote
Old 12-28-2002, 07:24 AM   #2
Send a message via ICQ to Cartman
Go buy a Schumacher Fusion 21. they have done it for you inc a 3 speed gear box
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 12-28-2002, 09:55 AM   #3
actually, seeing that car in a magazine last night is what got me thinking about it. i just thought it would be fun to do some custom fabrication. id rather figure it out instead of buy a new car though. do the mounting holes in .21 motors work with an rs4 chassie?
Old 01-01-2003, 12:45 PM   #4
Send a message via AIM to falcon68
No, A big block will not just drop in to a RS4, or any touring car for that matter. with the exception of that new Fusion. In order to put a big block in a HPI car, you will need a conversion kit. Wolfpack radicals makes a conversion kit that includes everything you will need to do this. All it is, is a flywheel, and motor mounts. I have done a big block conversion on a HPI NMT and I'm here to tell you, that a big block is really cool. I'm now toying with the notion of making one of my NRS4's a big block car. The biggest advantag of a big block is the torque and mid-range. The small blocks can't begin to compare. Speed all depends on how deep your pockets are.
One thing to keep in mind though. Before you do this conversion, you need to beef up your drivetrain to handle a big block's power. The stock plastic pulley's on the NRS4-2 is a big no-no. A few upgrades to the chassis are in order if you plan to have a reliable ride that doesn't break something when you nail it.
On my NMT big block, I had to get HD differential gears. I tried the stock parts for about a month, but I couldn't nail it from a stop, or get the truck in a bind. If I did, the engine's power would literally shatter the diff gears. Even with the HD differential gears, I've stripped a pinion gear by not being careful with throttle input.
falcon68 is offline   Reply With Quote
Old 01-01-2003, 03:11 PM   #5
sounds fun. i have a nrs4 3 so i dont have to worry about a belt pulley. why do you need a new flywheel? is the one on the big block to big to fit without touching the chassis?
Old 01-01-2003, 04:03 PM   #6
Most big block engines have a SG shaft. That means that the pilot shaft is part of the crank. The mounting hole in the middle of the flywheel needs to be bigger than the one for the standerd cranks. As far as your NRS4-3, you will need to upgrade to the heavy duty differential gears for the NMT. You also need to upgrade your brakes.....
Old 01-01-2003, 05:49 PM   #7
you think it will just rip the teeth off my diff gears?? that sounds like a lot of power.
Old 01-01-2003, 06:07 PM   #8
The last stock diff. set I broke, The bigger differential gear came out in 4 pieces. It's the torque that kills those gears. The H.D.set isn't that suseptibal to breaking.
Old 01-01-2003, 07:19 PM   #9
popsracer's Avatar
Default .21 engine in a sedan.
wahturi;
ALL of the parts to do the transplant are availible from Wolfpack Radicals. It will easily cost more than what you paid for your entire car to do the conversion. $$$$$$$$$$$$$$$$!!!!!
popsracer is offline   Reply With Quote
Old 01-01-2003, 10:25 PM   #10
I believe that you spent more than $60 on your car, right?
The wolfpack conversion kit is $59.99 at bruckner hobbies. The differential mods will cost another $60.00. So it's definantly worth the investment.
Old 01-02-2003, 06:58 AM   #11
plus a .21 engine.. 200? that equals 320 right there, the price of my car. but what i wanted to do was machine all the parts myself so all i have to buy is the engine. could i get a .21 for around $100?
Old 01-02-2003, 03:59 PM   #12
Yes you can, Ofna makes a .21 that is about $110 brand new. They will have plenty of power for that RS4. If you just want to spend $200 dollars for the .21, be my guest, however, a $200 dollar engine will probably have far more power than the car can handle.
Old 01-02-2003, 04:03 PM   #13
Here's an example
There are a few engine's in that price range. You can also get the ofna hyper for about $135.
Hope that helps
Old 01-03-2003, 08:43 AM   #14
thanks. seeing that is tempting. i bet it would be so fast. 1.9 bhp!! compared to 3\4 bhp of my fe.
Old 01-03-2003, 04:47 PM   #15
AHH yes, decisions decisions!!!
Swap... Gav_XXXS Australia For Sale/Trade 0 06-25-2006 05:32 AM
SWAP!! Gav_XXXS Australia For Sale/Trade 5 06-07-2006 03:07 AM
tc3/swap .MAtt. Australia For Sale/Trade 1 03-21-2006 05:15 PM
for swap downunder23 R/C Items: For Sale/Trade 14 03-15-2006 06:46 PM
FS/SWAP AD2 runnin rc10 R/C Items: For Sale/Trade 13 08-10-2005 02:59 PM
