Old 04-25-2006, 05:48 AM   #1
Trader Rating: 13 (93%+)
Default when not using a switch how do run your battery wire setup ?
hello
i just wanted some information on how you guys plug and unplug your receiver wire when not using a switch.
i just plug and unplug the battery in and out of the reciver but this after a wire makes the wires come lose from the end plug.
is their a plug we can put in line or how how servo extension wires ?
thank you
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 04-25-2006, 06:12 AM   #2
without a switch there isn't much other you can do except get an extension wire and disconnect at that connection. i would imagine that you will eventually have the same problem after awhile but they are pretty cheap and can be easily replaced.
sedanaddict is offline   Reply With Quote
Old 04-25-2006, 06:39 AM   #3
itchy b's Avatar
Originally Posted by mrgsr
hello
thank you
you can also use an extention but change the plugs on the battery lead and the end of the extention lead that connects to the battery to the small deans plugs. i have seen a number of guys using this setup and it works good, and i'll changing to them on my own car very soon too
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 04-25-2006, 06:43 AM   #4
i use exactly the same setup for atleast a year now and it has not worn out yet.
ae_ntc3 is offline   Reply With Quote
Old 04-25-2006, 06:43 AM   #5
deans plugs are just so tight for the small wires
Old 04-25-2006, 08:52 AM   #6
tomkelley's Avatar
I use a small deans connector. One side wired to the battery, one side wired to the reciever. The wire coming off the reciever is zip tied down at the deans plug to the radio plate. The key is to get the wire coming off the battery at a nice lenghth and I use heavier 14 or 16 gauge wire. This way the wire is firm in place so you can use one hand to plug and unplug the battery.
Detroit Radio Control Car Club
www.drccc.org
tomkelley is offline   Reply With Quote
Old 04-25-2006, 09:11 AM   #7
richey's Avatar
Send a message via MSN to richey
Default Try this.
Special 12cm Receiver Battery Pack Wire Set (w/mount)
Silver Bowl Raceway Operator
www.TeamTaylorRacing.net
Byron's Fuel, Airtronics
JoshStevensFoundation.org
richey is offline   Reply With Quote
Old 04-25-2006, 10:38 AM   #8
Those reciever wire sets from Team magic/Kfactory are the only way to go. The bracket mounts the connector in the location for a stock switch. then all you need to do is plug your battery into it. We have sold a pile of those things since they introduced those with the g4s car. They fit any type of car with a standard battery switch hole. The battery wire is sandwiched in the second slot in the bracket so its close to the connector and you just roll it up and plug it in.
Motorman2 is offline   Reply With Quote
Old 04-25-2006, 10:43 AM   #9
itchy b's Avatar
hmmm looks like i might be adding a new item onto my shopping list
EX1.5-SC10 4x4
Old 04-25-2006, 10:49 AM   #10
Car Breaker's Avatar
I use that too because I have a G4S
Before that when I drove a 710, I make my own battery packs, I use longer wire, cut in half and solder to Dean's Micro Plug instead of using extension or switch, that thing last forever
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Lipo Battery Balancer wire Question ckaspar Radio and Electronics 2 06-13-2008 10:53 AM
how to wire a switch...? XingXing Electric On-Road 19 09-11-2006 04:50 PM
Which guage wire for battery? RoostAZ Electric Off-Road 3 09-04-2006 04:05 AM
Battery Wire Clangeddin Electric On-Road 5 10-13-2005 05:34 AM
Battery Bars vs Braided Wire 403forbidden Electric On-Road 68 04-28-2005 08:46 AM
