Old 12-26-2002, 06:51 PM   #1
Default rs4 3 - .12SS vs. .15FE
Can the .12SS in Type SS kit beat the .15FE in RTR version?
Thanks.
Also, I have 2 options: keep the brand new Type SS or trade it with the nitro 4-tec (2.5 engine)
What should I do? I don't care much for racing since I work weekend... just parking lot bashing... Thanks
CaptEvo is offline   Reply With Quote
Old 12-27-2002, 03:54 PM   #2
the 15fe is a base model engine form what i know. the .12 is better.
wahturi is offline   Reply With Quote
Old 12-27-2002, 09:06 PM   #3
popsracer's Avatar
The .15FE is around .85 hp. The FE has a ABN piston & sleeve.
The .12SS is over 1.0 hp. The SS has a ABC piston and sleeve.
I would not trade for the Traxxas. There are better cars than the HPI, but the 4-Tec is NOT one of them. If this is your first nitro car, I would stick with the HPI.
popsracer is offline   Reply With Quote
Old 12-28-2002, 12:33 AM   #4
I dont know why, but my friend's RTR3 beat me in drag......
[HPI]RS4SS is offline   Reply With Quote
Old 12-28-2002, 09:12 AM   #5
Thanks guys,
I'll keep the SS. Should be here anytime today. =)
Its not my 1st nitro. I have a Tmaxx and a RC10GT.
I guess I can always upgrade to OS or Star .15SS later on.
Old 12-28-2002, 04:44 PM   #6
nova racer's Avatar
the .15fe is like .55hp dont know about the ss but less than a horse i would say .85
nova racer is offline   Reply With Quote
Old 12-29-2002, 11:00 AM   #7
I just finished building my Type SS.. just one question though... the air filter doesn't fit on the carb very well... the idle needle is in the way... any of you noteiced that?
Old 12-29-2002, 01:02 PM   #8
popsracer's Avatar
CaptEvo;
This is a problem with ALL of the HPI .12-.15 engines (except Novarossi based). Carefully grind or trim a small amount of the filter base away so it will clear the idle stop screw better.
NEVER run your engine without an "Oiled" Air Filter or without being "Zip-tyed" to the Carb, NEVER.
[HPI]RS4SS;
Your friend probably has his engine tuned way too lean. Won't last long that way.
Old 12-29-2002, 01:46 PM   #9
Thanks popracer,
The air filter looks cheap, i think i'll put my spare OS filter in...
i still have to trim it, but seems like still not anough room for the zip tie...
Thnx
Old 12-29-2002, 06:37 PM   #10
There are many little things you can add to your engine to make it faster than your friends if you are drag racing and you won't need to change engines. If you don't have a tuned pipe get one. Read the article below to decide which pipe you would like. it also tells how you can super tune your tuned pipe.
http://www.rcnitro.com/rn/articles/tuned.asp
The next thing is a slide carburetor. If you want to get off the line fast this is the only way to go.
Here is an article about how to get the most from your carburetor.
http://www.rcnitro.com/rn/articles/carburetor.asp
For pure speed where handling is not an issue (on a track) this should be all you need to do. If you race on a track then there is a lot more to take into consideration. Type of track surface, type of track, high speed or technical which involves set up and tires.
If your just in the parking lot on a Sunday morning trying to beat out your friend on along straight this should do it.
When your engine gives up the ghost get yourself a Novarossi instead of the HPI. I did and I am verry happy with it.
speedoo is offline   Reply With Quote
Old 12-30-2002, 06:33 PM   #11
NitroJoe's Avatar
Popracer
My TypeSS engine went out last weekend. I am going to get an OS Max .12CV-RX. Anyway, when I looked at the Crank Shaft. It doesnít look like the TypeSS. Iím wondering , Can I use the same Light Weight Fly Wheel on the OS or do I have to modify something in order to use the OS. Thanks POP
NitroJoe is offline   Reply With Quote
Old 12-30-2002, 07:24 PM   #12
popsracer's Avatar
Default NitroJoe;
You might have to cut some of the threads off the crankshaft on the O.S. but other than that it should fit fine.
How much fuel did you get through your .12SS?
I have a .15FE that is 1-1/2 years old that still runs strong and gets RACED almost every weekend by my Son.
Old 12-30-2002, 07:32 PM   #13
popsracer's Avatar
Default speedoo;
If you don't have a tuned pipe get one, The next thing is a slide carburetor.
Both of these items will cost almost as much as a new engine. I can see the need for a pipe but not for a slide carb at $50+.
[HPI]RS4SS;
Try removing the restricter that goes into the muffler/pipe, then re-adjust your fuel mixture if nesessary.
Old 12-30-2002, 09:11 PM   #14
NitroJoe's Avatar
Default Re: NitroJoe;
I just fixed it. It was the carburetor. It came lose and fuel all over the car. I didn't know but right after I took the SS out of the car. I knowege the carbure kinda loose. Anyway, I am think put the SS on my new V-1S and take the stock Kyosho put it on the Type SS. Any suggestion? POP. thanks,
Old 12-30-2002, 09:43 PM   #15
[QUOTE]Originally posted by popsracer
[B]CaptEvo;
popsracer,
I was able to get the OS air filter to fit in the 12SS, but there's no way I can zip tie it... the zip tie itself wouldn't fit in between the carb and the idle needle... Is it Safe to zip tie it around the idle needle? I mean is it going to ruin the idle needle?
Thnx
[I think my next engine is the OS 15 CV-R]
My .15fe won't run ShgnWgn008 Nitro On-Road 0 07-09-2005 09:08 PM
how fast is the Tamiya FS-12SS engine? PeR4MaNz Onroad Nitro Engine Zone 1 02-09-2005 09:52 PM
FS:HPI .12ss.(Novarossi) TexRacer R/C Items: For Sale/Trade 1 01-15-2003 06:25 PM
hpi .15fe help mavrickhunter Nitro On-Road 1 11-28-2002 04:22 PM
ported 15fe gjkwb Nitro On-Road 4 11-15-2002 06:30 PM
