Tamiya TG-10 MK.2
Item #84423 TG10-Mk.2 FZ
https://www.tamiyausa.com/shop/110-n...g-chassis-kit/
Tamiya USA Page
1/10 Scale Glow-Engine R/C 4wd Racing Car
This shaft-driven 4WD chassis kit turns the TG10-MK.2FZ into a tuned racing machine! It offers increaded steering anfle, plus a superior drive thanks to a high-performance TRF big bore dampers and low-friction 8mm suspension balls. The carbon fiber upper deck enhances rigidity and allows easy access to receiver battery and propeller shafts. The TM-12 race-tuned muffler draws even greater performance from the impressive FS-12FZ engine.
Length: 377mm Width: 198-202mm (can be altered) Wheelbase: 257mm Tread 172-176mm (can be altered) Gear Ratio= 7.02:1 (1st gear) 5.42:1 (2nd Gear) Tire Width/Diameter: 24/65mm (tires sold separatly) Double deck frame uses 3mm thick aluminium lower and 2mm thick carbon fiber upper decks 75cc fuel tank
Required Items:
Wheels
Medium-narrow wheels (24mm width / +2) such as 51299 Medium-Narrow 12-Spoke Wheels(4pcs.).
Tires
54293 Medium-Narrow Reinforced Tires GP-A(24mm width, 1 pair).
53433 Type A and 53705 Type B3 tires also recommended.
Inner Foam
Medium-narrow(24mm width) tire inserts such as 53434, 53435, 53582
Body
51450 Raybrig HSV-010
51195 Raybrig NSX 2004
51578 Raikiri GT
Tamiya USA Page
Required Items:
Wheels
Tires
Inner Foam
Body
51578 Raikiri GT
And???????
