Kyosho V-ONE RRR Ultimate Edition (UE) >
Old 04-28-2006, 07:02 AM
  #121
jag
jag's Avatar
Originally Posted by itchy b
hi , i,m trying to find out if there is a tool available for presice setting of the end play between thrust bearing\shims and retainer made by kyosho. it is a combination of a pinion remover at each end with a slot down the centre that increases in thickness in .1mm steps for exact setting of endplay any help would be appreciated cheers joe
I don't know if Kyosho makes one but Serpent makes a similar tool. The Serpent tool does not have a pinion wrench but it does have a flywheel holder.
jag is offline
Old 04-28-2006, 07:05 AM
  #122
jag
jag's Avatar
Originally Posted by BundyMan
Kawahara Brake Disc...
That is a nice looking piece. It's too bad Kawahara stuff is so hard to get in the US... heck, in the whole world! I have given up on the Kawahara rear blade type sway bar.
jag is offline
Old 04-28-2006, 07:18 AM
  #123
jag
jag's Avatar
Originally Posted by rmdhawaii
Any disagreements as far these Kyosho parts are concerned? Are there newer/better/alternate parts than these? If you have anything else to add, please do. Clock is ticking! Thanks!
Brakes:
APP Brake Rotor & Pad Set - APP02
Pivot Balls:
64 Titanium 9mm Ball Screw (8pcs) - VZW024V-8
Hinge Pins:
Rear Lower Suspension Shaft - VZW038
Front Upper Suspension Shaft - VZW037
Front Lower Suspension Shaft - VZW036
Chassis:
SP Main Chasis for V1RRR - VZW214
Rear Shock Stay
Rear Shock Stay for V1RRR - VZW207
What is the difference between the stock hinge pins and these? What about the pivot balls? I don't think the ones that came in my kit are steel.
As for things to add:
Aluminum Brake Lever - VZW063
64 Titanium Spur Gear Shaft - VZW209
64 Titanium Bevel Shafts - VZW211
Lightweight Clutch Bell - VZW213
Hollow Mid Shaft -
Aluminum Mid Shaft Mount -
Lightweight Flywheel -
BTW, I am using all of the parts I have listed and they are all excellent.
jag is offline
Old 04-28-2006, 07:55 AM
  #124
itchy b's Avatar
thanks heaps jag, looked it up on the serpent website and found it, just what i was looking for, maybe kyosho only makes the feeler guage set now and discontinued the other design
itchy b is offline
Old 04-28-2006, 09:35 AM
  #125
jag
jag's Avatar
No problem. If you get the one from Serpent let me know if you like it. I have one and I don't find it as easy to use with the Kyosho clutch. Maybe it's just me.
jag is offline
Old 04-28-2006, 04:09 PM
  #126
SOLOARTIST 702's Avatar
Default hmm
VAUGHN WHATS UP
SOLOARTIST 702 is offline
Old 04-28-2006, 04:12 PM
  #127
carkillaii's Avatar
Hawaii u have a pm
carkillaii is offline
Old 04-28-2006, 04:13 PM
  #128
carkillaii's Avatar
Originally Posted by SOLOARTIST 702
VAUGHN WHATS UP
chillin Will whats good
Old 04-28-2006, 04:28 PM
  #129
rmdhawaii's Avatar
My bad - I should have been clearer:
Hinge Pins:
64 Titanium / Rear Lower Suspension Shaft - VZW038
64 Titanium / Front Upper Suspension Shaft - VZW037
64 Titanium / Front Lower Suspension Shaft - VZW036
WCE Kit Hinge Pins:
Rear Lower Suspension Shaft - VZ224
Front Upper Suspension Shaft - VZ223
Front Lower Suspension Shaft - VZ222
WCE Kit Pivot Balls:
9mm Ball Screw - FM337
I have no idea what material the kit parts are made out of.
rmdhawaii is offline
Old 04-28-2006, 04:41 PM
  #130
Corse-R's Avatar
Pivot Balls:
Rather than burning big bucks on 8 pillow balls for all the car, may I suggest only putting Ti pillowballs on the front upper side?.
Is a matter of compromise, reduce unsprung weight vs. raising the CG of the car. No matter how light is your car, if you remove weight from the better place that could be (the lowest) the handling will be worse (and expensive). Don't forget too that Ti is lighter but more prone to breaking, with the lower pillow balls in steel, they bend, but not break.
BTW: The best ones (and confirmed by other people) are the Mugen ones, part no. T0187 (2pc pack).
The same applies for the Ti screw set and other Ti parts, the worst place you can remove weight is at chassis plate level (so, forget too about LiPo batteries and things that can remove weight were you would desire - weight freaks don't apply).
Corse-R is offline
Old 04-28-2006, 04:49 PM
  #131
litespeed-dom's Avatar
Absolutely! Well said.
Dom
litespeed-dom is offline
Old 04-28-2006, 05:04 PM
  #132
rmdhawaii's Avatar
Corse-R: Thanks for the info. All good things for everyone to know and keep in mind before just jumping to conclusions that the Ti part is the better choice.
I think we are very fortunate to have some very knowledgeable and experienced people help us with this project. It will really help us weed out what the "best choices" are for the car.
Thanks everyone! I really appreciate the input, participation and feedback. Keep up the good work!
Rainer
Old 04-28-2006, 09:16 PM
  #133
carkillaii's Avatar
Hawaii pics of my car for the site
Attached Thumbnails Kyosho V-ONE RRR Ultimate Edition (UE)-v1rrr1.jpg   Kyosho V-ONE RRR Ultimate Edition (UE)-v1rrr21.jpg   Kyosho V-ONE RRR Ultimate Edition (UE)-v1rrr31.jpg
Old 04-28-2006, 09:27 PM
  #134
rmdhawaii's Avatar
Old 04-28-2006, 11:54 PM
  #135
maskedrider's Avatar
wait a minute, wait a minute......right now there are 4 thread for RRR... i confused on which to go thru now.....
maybe we can stick to one of the thread, as it's easier for us to go thru ?
maskedrider is offline
