Old 04-26-2006, 07:51 AM   #76
jag
jag's Avatar
Originally Posted by BundyMan
Yep, belt pulley 21T. The aluminium brake holder is also essential. Now using the kawahara disc actually helps to reduce wear on it since its double layered and hence minimal lateral movement on the holder
Is that the pulley with the pins that hold the brake disk?
The WCE comes with the aluminum brake holder... at least mine did.
jag is offline   Reply With Quote
Old 04-26-2006, 01:55 PM   #77
rmdhawaii's Avatar
THe Kawahara disc is slotted, ventilated, cross-drilled and etc. Will post picture later
Kawahara: http://www.hikarisystem.net/kawahara...goods_ID=K-496 - Are you using the K-496?
K Factory: http://www.kfactoryracing.com/produc...1901&pageNum=3
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 04-26-2006, 07:58 PM   #78
BundyMan's Avatar
Yep, using K-496. As for the pads, I am using the pads taken from the 1:1 scale car. Basically get the machine shop to cut a couple of small pieces out and then stick it to the metal disc brake pad and voila. Cheaper than APP and it has lasted me from my FW05R days
BundyMan is offline   Reply With Quote
Old 04-26-2006, 11:06 PM   #79
performula's Avatar
Originally Posted by rmdhawaii
One thing that jeffreylin mentioned, is that he can't remove the gears from the lightweight clutch bell without bending the clutch bell. Has anyone else had similar problems? Is there a certain technique to use so that the clutch bell won't get bent?
Mugen makes a clutchbell pinion remover that is supposed to work great.
performula is offline   Reply With Quote
Old 04-26-2006, 11:17 PM   #80
performula's Avatar
Who has that in stock? Looks nice.
How about doubling up on the rear tower???
Old 04-27-2006, 01:00 AM   #81
carkillaii's Avatar
how many mm is the new rear tower?
carkillaii is offline   Reply With Quote
Old 04-27-2006, 01:13 AM   #82
rmdhawaii's Avatar
According to this document (http://www.kyosho.co.jp/web/products...r_060322-e.pdf, it's looks like it's only 3mm.
Old 04-27-2006, 01:26 AM   #83
carkillaii's Avatar
Ill just retap my skyline tower to fit the mounts
Old 04-27-2006, 01:30 AM   #84
carkillaii's Avatar
Has anyone tried the KFactory 1way\Spool?
give me the Pros & Cons
Old 04-27-2006, 03:42 AM   #85
maskedrider's Avatar
Thanks guys!
How come i cannot access ?? Or are you doing upgrading now at this time ??
Kyosho- Sirio/ OS engine- AVID bearing- Blue thunder fuel- Proline- RC dynamite- Sanwa- RC Art
maskedrider is offline   Reply With Quote
Old 04-27-2006, 04:06 AM   #86
rmdhawaii's Avatar
I don't know. Just tried and it was up. Let me know...
Old 04-27-2006, 05:00 AM   #87
finally can log in your site....
btw, how to send my pix to you ?
Old 04-27-2006, 05:00 AM   #88
rmdhawaii's Avatar
Originally Posted by performula
rmdhawaii, you might as well add the MTX-3 style battery pack to the list. It's lighter, if you are running very long mains I'd stick to the larger packs though.
Got a part number?
Old 04-27-2006, 06:24 AM   #89
thats exactly what i am using and it weighs 70 grams and is 800mah i think from memory........
ae_ntc3 is offline   Reply With Quote
Old 04-27-2006, 06:27 AM   #90
and the lightend hub on the 1st speed spur weighs 2 grams less than stock
FS: ULTIMATE KYOSHO MINI-INFERNO - MUST SEE - MAKE OFFER! Chris Furman R/C Items: For Sale/Trade 11 07-28-2007 08:40 PM
Kyosho V-One RRR WC Team Edition Roller(laydown servos edition) - $245 Shipped! AZrcDude R/C Items: For Sale/Trade 40 07-04-2007 12:15 AM
Kyosho V-One RRR WC Team Edition Roller(laydown servos edition) - $300 Shipped AZrcDude R/C Items: For Sale/Trade 39 06-20-2007 04:55 PM
FS: ULTIMATE KYOSHO MINI INFERNO - HOP-UPS.. MUST SEE! Chris Furman R/C Items: For Sale/Trade 20 06-12-2007 08:25 PM
ULTIMATE KYOSHO EVOLVA PARTS LOT sikgraffx R/C Items: For Sale/Trade 1 10-09-2005 01:59 PM
