Old 04-21-2006, 04:50 PM   #31
litespeed-dom's Avatar
Here is what Kyosho consider as Optional parts, of course certain ones come with the WC kit already. I'm not posting this because I feel all these parts are mandatory, but just an FYI for those want to know what is being offered by Kyosho. And I can't guarrantee availability of these items either.
Dom
92702B SC SPRING
APP02-2 APP BRAKE PAD (FOR V-ONE)
BRG022 SHIELD BEARING (6X10X3)2PCS
FM337 9MM BALL SCREW
FMW11 CLUTCH SHOE (RED)
FMW16 CLUTCH SPRING (H)
SPW5 ADJUST ROD SET L=15,20
VSW003 ALUMINIUM ENGINE MOUNT
VSW007 UNIVERSAL SWING SHAFT (SHORT)
VZ113-59 1ST SPUR GEAR (0.8M/59T)
VZ113-60 1ST SPUR GEAR (0.8M/60T)
VZ114-55 2ND SPUR GEAR (0.8M/55T)
VZ115-20 1ST GEAR (0.8M/20T)
VZ115-22 1ST GEAR (0.8M/22T)
VZ115-23 1ST GEAR (0.8M/23T)
VZ201-1 FRONT KNUCKLE ARM (KINGPIN ANGLE 1DEG)
VZ201-2 FRONT KNUCKLE ARM (KINGPIN ANGLE 2DEG)
VZ237 DRIVE BELT 387 (RRR/FOR 24T PULLEY)
VZW009 TCD GEAR SET
VZW010 DRIVE WASHER
VZW010-1 O RING SHAFT SET
VZW024V 64 TI/9MM BALL SCREW
VZW024V-8 64 TI/9MM BALL SCREW 8PCS
VZW052 CARBON FRONT SHOCK STAY
VZW054 UNIVERSAL SWING SHAFT
VZW054-01 SWING SHAFT(FOR UNIVERSAL/45MM)
VZW054-02 WHEEL SHAFT
VZW054-03 JOINT BLOCK SET
VZW063 ALUMINUM BRAKE LEVER(RRR/BLUE)
VZW064 LIGHTWEIGHT 1ST GEAR HOUSING
VZW065 ONE PIECE ENGINE MOUNT
VZW201 SP DRIVE BELT 189 (RRR) FRONT
VZW202 SP DRIVE BELT 384 (RRR) MIDDLE
VZW203 SP DRIVE BELT 180 (RRR) REAR
VZW205 ALUMINUM BRALE HUB (FOR RRR)
VZW206-18 ALUMINUM PULLEY (RRR/18T/1PC)
VZW206-21 ALUMINUM PULLEY (RRR/21T/1PC)
VZW206-23 ALUMINIUM PULLEY (RRR/23T/1PC)
VZW206-24 ALUMINUM PULLEY (RRR/24T/1PC)
VZW206-27 ALUMINUM PULLEY (RRR/27T/1PC)
VZW208 FRP BATTERY PLATE (V-ONE RRR)
VZW209 64 TITANIUM SPUR GEAR SHAFT (RRR)
VZW211 64 TITANIUM BEVEL SHAFT (RRR/FW)
VZW212 FRP MIDDLE PLATE (V-ONE RRR)
VZW213 LIGHTWEIGHT CLUTCH BELL (RRR)
VZW214 SP MAIN CHASSIS (RRR/7075/3T/GUNMETAL)
VZW215-15 1ST STEEL GEAR (0.8M/15T) (FOR RRR)
VZW215-16 1ST STEEL GEAR (0.8M/16T) (FOR RRR)
VZW215-17 1ST STEEL GEAR (0.8M/17T) (FOR RRR)
VZW216 ALUMINUM MIDDLE SHAFT MOUNT
W5105BK SHOCK CAP SET (BLACK)
W5105G SHOCK CAP (GOLD)
W6001 TITANIUM COATING SHOCK SHAFT
W6002 TI COATING SHOCK SHAFT (30)NUT
W6007 HC DIAPHRAGM (WHITE)8PCS
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 04-21-2006, 04:57 PM   #32
itchy b's Avatar
Originally Posted by Cash-Money
hey guys i just bought this car for $75 bucks??? all i know is its a kyosho? and ?what model is it? and can i still get parts for it? what kind of engine is it?
//i41.photobucket.com/albums/e284/jdmsocalcivic/DSC00106.jpg[/IMG]
[//i41.photobucket.com/albums/e284/jdmsocalcivic/DSC00109.jpg[/IMG]
http://i41.photobucket.com/albums/e284/jdmsocalcivic/DSC00110.jpg[/IMG]
http://i41.photobucket.com/albums/e284/jdmsocalcivic/DSC00105.jpg[/IMG]
http://i41.photobucket.com/albums/e284/jdmsocalcivic/DSC00103.jpg[/IMG]
[http://i41.photobucket.com/albums/e284/jdmsocalcivic/DSC00107.jpg[/IMG]
looks like a vone'r with an evo kitupgrade kit, should be able to still get parts
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 04-21-2006, 06:57 PM   #33
fritzD's Avatar
Send a message via Yahoo to fritzD
Cash-Money,
do a search. there's a v-one R thread here.
now, back to RRR ultimate edition...
great input guys...
fritzD is offline   Reply With Quote
Old 04-21-2006, 08:22 PM   #34
robert maestrey's Avatar
http://www.kfactoryracing.com/produc...1901&pageNum=3
http://www.kfactoryracing.com/produc...1498&pageNum=4
These Products will give you Awesome Breaking power.....
Break fade is a thing of the past...Trust me get them
robert maestrey is offline   Reply With Quote
Old 04-21-2006, 08:33 PM   #35
rmdhawaii's Avatar
Thanks!
Brand: K Factory Racing
Part number: K1498
Description: G4 Real Racing Brake Pads (glued with plate, for most Kyosho cars) (pair)
Type of upgrade: Performance
Reason: Awesome braking power. No brake fade.
Setting: N/A
Part number: K1901
Description: V1RRR/MP777/7.5 Balanced Ventilation Brake Disc
Setting: N/A
rmdhawaii is offline   Reply With Quote
Old 04-21-2006, 08:35 PM   #36
Originally Posted by rmdhawaii
Thanks!
Part number: K1498
Setting: N/A
Part number: K1901
Setting: N/A
oops..sorry about the way I posted
Old 04-21-2006, 08:37 PM   #37
rmdhawaii's Avatar
No problem bro! I got it covered.
Old 04-21-2006, 09:29 PM   #38
BundyMan's Avatar
Me thinks the Kawahara K-496 brake disc is even more impressive than the KFactory ones. It also helps to minimize wear on the aluminium brake holder.
Another essential upgrade is the aluminium brake pulley.
BundyMan is offline   Reply With Quote
Old 04-21-2006, 11:07 PM   #39
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default sway
Originally Posted by jag
Where did you get the sway bar from originally? I have been looking all over the world for one.
i got it from my buddy out here i dont know where he got it
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 04-21-2006, 11:28 PM   #40
rmdhawaii's Avatar
Hi BundyMan. Have you tried the K Factory ones? What would you say is the primary difference between the two?
Thanks!
Old 04-22-2006, 07:44 AM   #41
jag
jag's Avatar
Do you mean the actual belt pulley or the hub that the brake disk rides on?
I am using the SP pads with the vented disk and brake fade is not existant. You do have to be careful to get them setup right. This combination is pretty aggressive.
jag is offline   Reply With Quote
Old 04-22-2006, 07:48 AM   #42
jag
jag's Avatar
Thanks!
Just for the record, Kawahara parts are very difficult to get in the US as they do not have a distributor here (that I can find). I think their products are first class but I just can't get them.
Old 04-22-2006, 08:26 AM   #43
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
Talking
I know a way to make your project a whole lot easier, just throw an MTX-4 in the box!
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 04-22-2006, 09:25 AM   #44
its a V one R, from what I see.
cooldude is offline   Reply With Quote
Old 04-22-2006, 10:07 AM   #45
Nice comment........We all know that the Mtx4 is a very good car ......the only problem is this is a RRR thread to help people.....So your comment is a little out of place ......Take care have a nice day
FS: ULTIMATE KYOSHO MINI-INFERNO - MUST SEE - MAKE OFFER! Chris Furman R/C Items: For Sale/Trade 11 07-28-2007 08:40 PM
Kyosho V-One RRR WC Team Edition Roller(laydown servos edition) - $245 Shipped! AZrcDude R/C Items: For Sale/Trade 40 07-04-2007 12:15 AM
Kyosho V-One RRR WC Team Edition Roller(laydown servos edition) - $300 Shipped AZrcDude R/C Items: For Sale/Trade 39 06-20-2007 04:55 PM
FS: ULTIMATE KYOSHO MINI INFERNO - HOP-UPS.. MUST SEE! Chris Furman R/C Items: For Sale/Trade 20 06-12-2007 08:25 PM
ULTIMATE KYOSHO EVOLVA PARTS LOT sikgraffx R/C Items: For Sale/Trade 1 10-09-2005 01:59 PM
