Here is what Kyosho consider as Optional parts, of course certain ones come with the WC kit already. I'm not posting this because I feel all these parts are mandatory, but just an FYI for those want to know what is being offered by Kyosho. And I can't guarrantee availability of these items either. ;)
Dom 92702B SC SPRING APP02-2 APP BRAKE PAD (FOR V-ONE) BRG022 SHIELD BEARING (6X10X3)2PCS FM337 9MM BALL SCREW FMW11 CLUTCH SHOE (RED) FMW16 CLUTCH SPRING (H) SPW5 ADJUST ROD SET L=15,20 VSW003 ALUMINIUM ENGINE MOUNT VSW007 UNIVERSAL SWING SHAFT (SHORT) VZ113-59 1ST SPUR GEAR (0.8M/59T) VZ113-60 1ST SPUR GEAR (0.8M/60T) VZ114-55 2ND SPUR GEAR (0.8M/55T) VZ115-20 1ST GEAR (0.8M/20T) VZ115-22 1ST GEAR (0.8M/22T) VZ115-23 1ST GEAR (0.8M/23T) VZ201-1 FRONT KNUCKLE ARM (KINGPIN ANGLE 1DEG) VZ201-2 FRONT KNUCKLE ARM (KINGPIN ANGLE 2DEG) VZ237 DRIVE BELT 387 (RRR/FOR 24T PULLEY) VZW009 TCD GEAR SET VZW010 DRIVE WASHER VZW010-1 O RING SHAFT SET VZW024V 64 TI/9MM BALL SCREW VZW024V-8 64 TI/9MM BALL SCREW 8PCS VZW052 CARBON FRONT SHOCK STAY VZW054 UNIVERSAL SWING SHAFT VZW054-01 SWING SHAFT(FOR UNIVERSAL/45MM) VZW054-02 WHEEL SHAFT VZW054-03 JOINT BLOCK SET VZW063 ALUMINUM BRAKE LEVER(RRR/BLUE) VZW064 LIGHTWEIGHT 1ST GEAR HOUSING VZW065 ONE PIECE ENGINE MOUNT VZW201 SP DRIVE BELT 189 (RRR) FRONT VZW202 SP DRIVE BELT 384 (RRR) MIDDLE VZW203 SP DRIVE BELT 180 (RRR) REAR VZW205 ALUMINUM BRALE HUB (FOR RRR) VZW206-18 ALUMINUM PULLEY (RRR/18T/1PC) VZW206-21 ALUMINUM PULLEY (RRR/21T/1PC) VZW206-23 ALUMINIUM PULLEY (RRR/23T/1PC) VZW206-24 ALUMINUM PULLEY (RRR/24T/1PC) VZW206-27 ALUMINUM PULLEY (RRR/27T/1PC) VZW208 FRP BATTERY PLATE (V-ONE RRR) VZW209 64 TITANIUM SPUR GEAR SHAFT (RRR) VZW211 64 TITANIUM BEVEL SHAFT (RRR/FW) VZW212 FRP MIDDLE PLATE (V-ONE RRR) VZW213 LIGHTWEIGHT CLUTCH BELL (RRR) VZW214 SP MAIN CHASSIS (RRR/7075/3T/GUNMETAL) VZW215-15 1ST STEEL GEAR (0.8M/15T) (FOR RRR) VZW215-16 1ST STEEL GEAR (0.8M/16T) (FOR RRR) VZW215-17 1ST STEEL GEAR (0.8M/17T) (FOR RRR) VZW216 ALUMINUM MIDDLE SHAFT MOUNT W5105BK SHOCK CAP SET (BLACK) W5105G SHOCK CAP (GOLD) W6001 TITANIUM COATING SHOCK SHAFT W6002 TI COATING SHOCK SHAFT (30)NUT W6007 HC DIAPHRAGM (WHITE)8PCS |
Originally Posted by Cash-Money
hey guys i just bought this car for $75 bucks??? all i know is its a kyosho? and ?what model is it? and can i still get parts for it? what kind of engine is it?
//i41.photobucket.com/albums/e284/jdmsocalcivic/DSC00106.jpg[/IMG] [//i41.photobucket.com/albums/e284/jdmsocalcivic/DSC00109.jpg[/IMG] http://i41.photobucket.com/albums/e284/jdmsocalcivic/DSC00110.jpg[/IMG] http://i41.photobucket.com/albums/e284/jdmsocalcivic/DSC00105.jpg[/IMG] http://i41.photobucket.com/albums/e284/jdmsocalcivic/DSC00103.jpg[/IMG] [http://i41.photobucket.com/albums/e284/jdmsocalcivic/DSC00107.jpg[/IMG] |
Cash-Money,
do a search. there's a v-one R thread here. now, back to RRR ultimate edition... great input guys... :D |
http://www.kfactoryracing.com/produc...1901&pageNum=3
http://www.kfactoryracing.com/produc...1498&pageNum=4 These Products will give you Awesome Breaking power..... Break fade is a thing of the past...Trust me get them :nod: :nod: |
http://www.kfactoryracing.com/produc...1498&pageNum=4 These Products will give you Awesome Breaking power..... Break fade is a thing of the past...Trust me get them :nod: :nod: Brand: K Factory Racing Part number: K1498 Description: G4 Real Racing Brake Pads (glued with plate, for most Kyosho cars) (pair) Type of upgrade: Performance Reason: Awesome braking power. No brake fade. Setting: N/A Brand: K Factory Racing Part number: K1901 Description: V1RRR/MP777/7.5 Balanced Ventilation Brake Disc Type of upgrade: Performance Reason: Awesome braking power. No brake fade. Setting: N/A |
Originally Posted by rmdhawaii
Thanks! :)
Brand: K Factory Racing Part number: K1498 Description: G4 Real Racing Brake Pads (glued with plate, for most Kyosho cars) (pair) Type of upgrade: Performance Reason: Awesome braking power. No brake fade. Setting: N/A Brand: K Factory Racing Part number: K1901 Description: V1RRR/MP777/7.5 Balanced Ventilation Brake Disc Type of upgrade: Performance Reason: Awesome braking power. No brake fade. Setting: N/A oops..sorry about the way I posted :eek: :eek: |
Me thinks the Kawahara K-496 brake disc is even more impressive than the KFactory ones. It also helps to minimize wear on the aluminium brake holder.
Another essential upgrade is the aluminium brake pulley. :) |
sway
Originally Posted by jag
Where did you get the sway bar from originally? I have been looking all over the world for one.
Another essential upgrade is the aluminium brake pulley. :) Thanks! :) |
I am using the SP pads with the vented disk and brake fade is not existant. You do have to be careful to get them setup right. This combination is pretty aggressive. |
Hi BundyMan. Have you tried the K Factory ones? What would you say is the primary difference between the two?
Thanks! :) |
I know a way to make your project a whole lot easier, just throw an MTX-4 in the box!
http://i41.photobucket.com/albums/e2...c/DSC00106.jpg http://i41.photobucket.com/albums/e2...c/DSC00109.jpg http://i41.photobucket.com/albums/e2...c/DSC00110.jpg http://i41.photobucket.com/albums/e2...c/DSC00105.jpg http://i41.photobucket.com/albums/e2...c/DSC00103.jpg http://i41.photobucket.com/albums/e2...c/DSC00107.jpg |
Nice comment........We all know that the Mtx4 is a very good car :) :) ......the only problem is this is a RRR thread to help people.....So your comment is a little out of place :weird: :weird: ......Take care have a nice day |
