Old 05-29-2006, 07:03 PM   #376
rmdhawaii's Avatar
Originally Posted by SOLOARTIST 702
those are mugen springs right
While the car pictured on the right is Adrien's RRR EVO, the car in the photo on the left is not a RRR.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 05-29-2006, 11:20 PM   #377
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default hmm
the left car may be a snake
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 05-29-2006, 11:24 PM   #378
Default hqa
whos got the GOBBA GOULD scene from sopranos never saw it but i did stay at a holiday inn xpress last night
WILLIAM PENDERGRASS
Old 05-30-2006, 02:28 AM   #379
maskedrider's Avatar
will ask my friends if he know since he race with Adrien on that Event ..... He got 6th position driving a G4S
Kyosho- Sirio/ OS engine- AVID bearing- Blue thunder fuel- Proline- RC dynamite- Sanwa- RC Art
maskedrider is offline   Reply With Quote
Old 05-30-2006, 03:03 AM   #380
carkillaii's Avatar
funny
carkillaii is offline   Reply With Quote
Old 05-30-2006, 03:04 AM   #381
carkillaii's Avatar
Will It is
Old 05-30-2006, 01:04 PM   #382
drfritz's Avatar
Originally Posted by robert maestrey
No problems whatsoever...I did change all my screws over to 2.0 metric
I was having problems with the battery tray mounting screws, drilled them out and tapped for 3mm screws with lock nuts for back up. no more problems so far.
drfritz is offline   Reply With Quote
Old 05-30-2006, 09:15 PM   #383
ttr_racer's Avatar
Trader Rating: 23 (100%+)
Here is a good one to start the UE build with
http://www.rctech.net/forum/showthread.php?t=116009
ttr_racer is offline   Reply With Quote
Old 05-31-2006, 01:36 PM   #384
kewdawg's Avatar
Hi, guys.
Not sure, if, it's been mentioned here but I've been using ATOMIC's Multi Drive For V-One RRR (Front Solid Axle/One Way/Solid One Way) #KR001 for the last few weeks. It's worked great and has no signs of wear, as of yet. I really like the ability it gives the driver to change the front diff set-up easily and quickly. If, you're on a track with fast / sweeping turns where a lot of breaking isn't used - you use it as One Way. If, you're on a track with slower, tight corners - you use it as a Front Solid Axle (spool), which will allow you to use heavy braking. Using it as a Solid One Way gives you an in-between mode of the One Way and Front Solid Axle. I've run it in all modes but primarily in Spool mode (Front Solid Axle). I'm going to do more testing in the Solid One Way mode to find the benefits of running it that way. I will give more feedback at that time.
I've also installed the ACER Racing Ceramic Nitride Pro Series V One RRR bearing set. The bearings are lighter and stronger than the stock bearing and will "free" up the drivetrain even more. They have polymer seals on them to keep contaminates out and require a great deal less maintenance than the stock metal sheilded steel bearings. The bearing have held up very well. as expected. They generally, last a very long time and can withstand a lot of abuse.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 05-31-2006, 01:49 PM   #385
rmdhawaii's Avatar
Originally Posted by kewdawg
Hi, guys.
It's good to hear some positive feedback on the Multi-drive. Up until now, I think the one other person that I know of that tried it didn't like it.
As far as the ceramic bearings go, have you noticed a difference when you drive the car? Have you improved your lap times at all?
Old 05-31-2006, 02:03 PM   #386
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Also, have you tried a Front Differential??
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 05-31-2006, 02:17 PM   #387
kewdawg's Avatar
Maybe, they weren't ready for the diffference in handling or weren't able to change their driving style and set-up to work with the spool.
Yes my lap times have dropped. After installing the bearings, the car's drivetrain felt like it did when my stock bearing were new and had a handful of runs on them. After the ceramic bearing broke themselves in - they've "freed" up the drivetrain even more. The engine is not working as hard either. I'm able to make more power at a lower temperature. The car's corner speed is a lot higher, also.
Quinn Moon
Old 05-31-2006, 02:25 PM   #388
kewdawg's Avatar
I've run a front diff a various tracks and found the diff to give you the most control. It's the safetest way to go when it comes to your front drivetrain set-up. It's not overly aggressive like a One-Way or extreme like Spool / Front Solid Axle. Both of those require very good throttle control. A front diff will be a lot more forgiving and give comfort in knowing the car isn't getting away from you because its too much to handle. It's definitely a good starting point or a good tuning option to have in your arsenal.
Quinn Moon
Old 05-31-2006, 06:48 PM   #389
drfritz's Avatar
Hi, guys.
I had just the reverse results with mine. i found that the out drives DID NOT wear well, had big groves after only one day of racing, liked the way the car felt with it in when it was new, but after the out drives grooved like they did the handling suffered.
Old 05-31-2006, 10:56 PM   #390
kewdawg's Avatar
Were you using the stock universals?
Quinn Moon
FS: ULTIMATE KYOSHO MINI-INFERNO - MUST SEE - MAKE OFFER! Chris Furman R/C Items: For Sale/Trade 11 07-28-2007 08:40 PM
Kyosho V-One RRR WC Team Edition Roller(laydown servos edition) - $245 Shipped! AZrcDude R/C Items: For Sale/Trade 40 07-04-2007 12:15 AM
Kyosho V-One RRR WC Team Edition Roller(laydown servos edition) - $300 Shipped AZrcDude R/C Items: For Sale/Trade 39 06-20-2007 04:55 PM
FS: ULTIMATE KYOSHO MINI INFERNO - HOP-UPS.. MUST SEE! Chris Furman R/C Items: For Sale/Trade 20 06-12-2007 08:25 PM
ULTIMATE KYOSHO EVOLVA PARTS LOT sikgraffx R/C Items: For Sale/Trade 1 10-09-2005 01:59 PM
