Old 04-21-2006, 08:05 AM   #16
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default sway
i am going to try finding a blade for it & run it again if anyone knows where to get a blade let me know please 3R its fantastic
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 04-21-2006, 08:40 AM   #17
jag
jag's Avatar
Originally Posted by mcsquish
Brand: K-Factory
Part number: K1910
Description: Front One Way / Solid Axle
Type of upgrade: car performance
Reason: The ability to go from a spool to a one-way fairly easy.
Setting: N/A
http://www.kfactoryracing.com/produc...1910&pageNum=1
Where did you find the K1910? All of the websites I have been to say "coming soon". I want to give it a try. Are you using it now?
jag is offline   Reply With Quote
Old 04-21-2006, 08:44 AM   #18
jag
jag's Avatar
Originally Posted by SOLOARTIST 702
i used the blade sway bar for the rear the kawahara thursday during open prac. b careful it broke a blade i didnt hit anything & it was set at the softest position just fyi
Where did you get the sway bar from originally? I have been looking all over the world for one.
Old 04-21-2006, 11:37 AM   #19
JCB
JCB's Avatar
Originally Posted by jag
I think I will start us off with an easy one.
Brand: Kyosho
Part number: VZW215-16
Description: 1st Steel Gear (16t)
Type of upgrade: Durability
Reason: The stock gear is aluminum and wears out quickly. This gear will last a long time.
Setting: N/A
Notes: They also make the other 1st gears in steel as well.
VZW215-15 = 15t
VZW215-17 = 17t
where can i find these steel gears at??
thanks,
JCB is offline   Reply With Quote
Old 04-21-2006, 11:47 AM   #20
jag
jag's Avatar
thanks,
You should be able to get them wherever you get your Kyosho parts. I get mine from the LHS.
Old 04-21-2006, 11:53 AM   #21
JCB
JCB's Avatar
no luck.. LHS doesn't carry kyosho.
Old 04-21-2006, 12:23 PM   #22
mcsquish's Avatar
jag, I had one of my lhs order it for me, Dirt Burners to be exact. I haven't tried it yet, my local track finally opens this weekend for the season.
You do not need a parachute to skydive. You only need a parachute to skydive twice.
Never argue with an idiot, they'll just drag you down to their level and beat you with experience.
Dirt Burners Racing - R.I.P. BB / Kolors by Kropy / CEFX / One Eighth Racers
mcsquish is offline   Reply With Quote
Old 04-21-2006, 01:56 PM   #23
GMartinez's Avatar
Trader Rating: 85 (100%+)
Totally agree I tried the front one way/spool & Kfactory delivered on Quality not like the issues I had with the serpent version when I drove a 710 I snapped 3 complete pairs of dogbones in one day & did everything to correct it but other drivers still had the same issue as i when the car was released.
Mcsquish did you notice any side to side play when you removed the pins. when
Brand: K-Factory
Part number: K1910
Setting: N/A
Brand: K-Factory
Part number: K1907
Description: 4mm Rear Carbon Shock Tower (w/alum. stiffener)
Type of upgrade: durability
Reason: Helps stripping out rear bulkheads where tower mounts during traction rolls / helps prevent rear tower breakage
Setting: N/A
http://www.kfactoryracing.com/produc...1907&pageNum=3
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 04-21-2006, 01:57 PM   #24
GMartinez's Avatar
got mine from brooklyn hobbies give em a call
Old 04-21-2006, 02:00 PM   #25
jag
jag's Avatar
I will check it out.
Old 04-21-2006, 02:12 PM   #26
jag
jag's Avatar
Brand: Kyosho
Part number: VZW209
Description: Titanium 2-Speed Shaft
Type of upgrade: Performance
Reason: It is substantially lighter than the stock shaft and as a part of the rotating mass lighter is better.
Setting: N/A
Brand: Kyosho
Part number: VZW211
Description: Titanium Bevel Shafts for the Rear Diff
Reason: They are lighter than the stock shafts and as a part of the rotating mass lighter is better.
Setting: N/A
Brand: Kyosho
Part number: VZW213
Description: Lightweight Clutch Bell
Reason: It is lighter than the stock clutch bell and as a part of the rotating mass lighter is better.
Setting: N/A
Brand: Kyosho
Part number: VZW063
Description: Aluminum Brake Lever
Type of upgrade: Performance/Looks
Reason: The aluminum lever eliminates flex in the brake assembly to ensure cosistant brake action, not necessarily stopping power (we will cover that later) and it looks very good.
Setting: N/A
Old 04-21-2006, 03:48 PM   #27
rmdhawaii's Avatar
Brand: Kyosho
Part number: VZW213
Setting: N/A
One thing that jeffreylin mentioned, is that he can't remove the gears from the lightweight clutch bell without bending the clutch bell. Has anyone else had similar problems? Is there a certain technique to use so that the clutch bell won't get bent?
rmdhawaii is offline   Reply With Quote
Old 04-21-2006, 04:20 PM   #28
jag
jag's Avatar
I have not bent mine yet but I do see that as a potential problem. I am trying to find a way to modify my Serpent clutch bell tool to work but I have to find a thinner pin that will not bend. For now I have been using channel-lock pliers with rubber jaws.
Old 04-21-2006, 04:39 PM   #29
litespeed-dom's Avatar
Brand: Kyosho
Part number: VZW063
Setting: N/A
Another reason for this item is the stock brake lever is aweful close to the 1st spur gear where your linkage is, I have experienced the lever bend down enough (whether it's flex or being hit) that it'll strip the teeth on the spur. The aluminum option is a good answer to this problem.
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 04-21-2006, 04:42 PM   #30
Cash-Money's Avatar
Send a message via AIM to Cash-Money
Cash-Money is offline   Reply With Quote
FS: ULTIMATE KYOSHO MINI-INFERNO - MUST SEE - MAKE OFFER! Chris Furman R/C Items: For Sale/Trade 11 07-28-2007 08:40 PM
Kyosho V-One RRR WC Team Edition Roller(laydown servos edition) - $245 Shipped! AZrcDude R/C Items: For Sale/Trade 40 07-04-2007 12:15 AM
Kyosho V-One RRR WC Team Edition Roller(laydown servos edition) - $300 Shipped AZrcDude R/C Items: For Sale/Trade 39 06-20-2007 04:55 PM
FS: ULTIMATE KYOSHO MINI INFERNO - HOP-UPS.. MUST SEE! Chris Furman R/C Items: For Sale/Trade 20 06-12-2007 08:25 PM
ULTIMATE KYOSHO EVOLVA PARTS LOT sikgraffx R/C Items: For Sale/Trade 1 10-09-2005 01:59 PM
