Old 05-11-2006, 01:04 AM   #211
esham's Avatar
Originally Posted by maskedrider
hey esam...does ur side easy to get parts in malaysia?
Not bad i could say but i still get my option from Hong Kong and Japan.
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 05-11-2006, 04:40 AM   #212
rmdhawaii's Avatar
Originally Posted by ae_ntc3
ohh rmd add this to the database:
kawahara front layshaft mount (k-475)
the quality is superb and its not as flimsy as the stocker so there is less lateral movement on the shaft and better drivetrain efficiency.
Yup! Will be added. But it's going to be the the Kyosho version (VZW216) instead of the Kawahara version.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 05-11-2006, 04:46 AM   #213
rmdhawaii's Avatar
Originally Posted by esham
rmdhawaii, may i suggest
Option Parts
K-497 Kawahara Rear Adjustable Stabilizer Set ( Rear antiroll blade )
Advantage
Easy fine tunning the stiffness of rear antiroll bar ( By just turn the blade )
Disadvantage
Expensive
Expensive?!
You just need to know who to buy it from.
I'm in the process of trying to obtain it. No sense putting something in the spec that no one can buy. Soloartist broke his, so it has to go through some additional testing before it can be added to the X list. I'll be sure to make it a canidate. If it breaks on me as well, it's a no go.
Old 05-11-2006, 04:51 AM   #214
rmdhawaii's Avatar
And all the 177 bush at steering holder, i change it to bearing. Reason- smoother.
This was replaced with bearings on the WCE.
Old 05-11-2006, 04:57 AM   #215
rmdhawaii's Avatar
The front shot with graphite body mount stay holder and WCE graphite front shock stay.
You and maskedrider are probably the only two using the body mount stays that I'm aware of. I would really like to nail down the performance benefit from using these. I have some ideas, but I'll have to do some testing. I'm trying to get the Kawahara ones. 3Racing is going to be my second choice.
Anyone know if Kyosho makes a set for the RRR?
Old 05-11-2006, 05:00 AM   #216
rmdhawaii's Avatar
Originally Posted by dodo
Not sure if anyone pointed this out, but it helps to change the screw that links the rear upper camber link to the rear hub to a longer one. I broke a lot of rear hubs during my first few runs with RRR, improper settings etc might result in spin and if the rear hub hit something it may easily be broken along the area where the screw is.
But it doesn't happen anymore since i change it to longer screw, can't remember whether it's 3x20 or 3x25mm screw.
hope this helps and can be included as one of the 'minor but helpful' tips for new RRR owners
Will be added. I have that in my notes and maybe the FAQ, but it's not in the build tips. Thanks!
Old 05-11-2006, 11:48 AM   #217
litespeed-dom's Avatar
what advantage will be the different of using this ??
I have the Ti bevel shaft in my car. Lighter, yes and any rotating mass that is lighter is an advantage. I actually got that part by accident.
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 05-11-2006, 11:49 AM   #218
And i still use the customize aluminium pipe holder mount at upperdeck. Probably this is not good idea. I'm thinking to change it to Kawahara K-475 Mid bearing block as to mount it back to chasis as suggested by Bundyman before.
I don't know if you guys have seen the Kyosho alu mid bearing block, it has a mount for your pipe as well. If you guys need, I can snap a pic during lunch when I go home.
Dom
Old 05-11-2006, 11:51 AM   #219
Originally Posted by rmdhawaii
The "best pricing" cost estimate for the current Ultimate Edition spec is approximately $162.45 USD, +/- $5.00 USD.
Kyosho VSW043 : 3D Lightweight Flywheel
Kyosho VZW215-15 : 1st Gear, 15T, 16T or 17T steel
Kyosho VZW215-16 : 2nd Gear, 20T, 21T, 22T or 23T, steel
Kyosho VZW213 : Lightweight Clutch Bell
Kyosho VZW063 : Aluminum Brake Lever
Kyosho VZW209 : Titanium 2-Speed Shaft
Kyosho VZW211 : Titanium Bevel Shafts for the Rear Diff
Kyosho VZW214 : Special Main Chassis 3T/7075 for V-ONE RRR
Kyosho APP02 : APP Brake Rotor & Pad Set
Kyosho VZW207 : Rear Shock Stay for V1RRR
Note: This includes only one set of 1st and 2nd pinion gears - not all seven gears.
RMD, that is a very good list to start with. Personally I would love to have that VZW214 chassis, but it's not cheap at all!
Dom
Old 05-11-2006, 12:10 PM   #220
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Dom
I want to check it out!!
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 05-11-2006, 12:13 PM   #221
I'll snap a pic and post.
Dom
Old 05-11-2006, 01:40 PM   #222
Default Mid Bearing Block
Here it is. Sorry couple of them are out of focus, but you get the idea.
Dom
Kyosho V-ONE RRR Ultimate Edition (UE)-dscn5173.jpg   Kyosho V-ONE RRR Ultimate Edition (UE)-dscn5174.jpg   Kyosho V-ONE RRR Ultimate Edition (UE)-dscn5175.jpg   Kyosho V-ONE RRR Ultimate Edition (UE)-dscn5176.jpg   Kyosho V-ONE RRR Ultimate Edition (UE)-dscn5177.jpg
Old 05-11-2006, 01:40 PM   #223
In this pic, you can see it compared to the stock block.
Dom
Old 05-11-2006, 01:49 PM   #224
rmdhawaii's Avatar
Here is a picture of the Kyosho VZW216 - Aluminum Middle Shaft Mount(for RRR).
http://item.rakuten.co.jp/rc-rainbow/4955439863848/
The Rainbow R/C Car Pro Shop has pictures of some of the option parts for the car. If you can navigate the Japanese links, you can also check out some of the option parts for other cars as well.
V-ONE RRR:
http://item.rakuten.co.jp/rc-rainbow/c/0000001065/
Other cars:
http://item.rakuten.co.jp/rc-rainbow/c/0000000328/?p=1
Old 05-11-2006, 01:55 PM   #225
robert maestrey's Avatar
Dom
surprised you dont have the hollow middle shaft
robert maestrey is offline   Reply With Quote
FS: ULTIMATE KYOSHO MINI-INFERNO - MUST SEE - MAKE OFFER! Chris Furman R/C Items: For Sale/Trade 11 07-28-2007 08:40 PM
Kyosho V-One RRR WC Team Edition Roller(laydown servos edition) - $245 Shipped! AZrcDude R/C Items: For Sale/Trade 40 07-04-2007 12:15 AM
Kyosho V-One RRR WC Team Edition Roller(laydown servos edition) - $300 Shipped AZrcDude R/C Items: For Sale/Trade 39 06-20-2007 04:55 PM
FS: ULTIMATE KYOSHO MINI INFERNO - HOP-UPS.. MUST SEE! Chris Furman R/C Items: For Sale/Trade 20 06-12-2007 08:25 PM
ULTIMATE KYOSHO EVOLVA PARTS LOT sikgraffx R/C Items: For Sale/Trade 1 10-09-2005 01:59 PM
