Old 05-10-2006, 07:11 PM   #196
i just put the kyosho 21T alloy brake pulley on my car and it is slightly heavier. I don't like using alloy pulleys but i don't want to keep buying the whole pulley set (vz203) when im only going to be replacing the 21T brake pulley after the pin wears it out.
the alloy pulley is a bit pricey but it will last a long time so you will actually end up saving money. the part number for the pulley is vzw206-21
ae_ntc3 is offline   Reply With Quote
Old 05-10-2006, 07:14 PM   #197
does anyone know what the part number is for the alloy hub that the brake disc rides on??
i tried to look it up in the book but its not listed in the back.
Old 05-10-2006, 08:22 PM   #198
Team Kamikaze's Avatar
VZW205 Aluminum brake hub
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 05-10-2006, 09:19 PM   #199
esham's Avatar
I did slowly upgrade my V1RRR since i got it early last year. the first upgrade that i bought together with the kits was.
1. Kyosho- TSW15- Light weight first gear housing
2. Kawahara K-496 ventilated brake disks
3. Kawahara K-473 rear damper stay
4. Kyosho - Aluminium Brake Adaptor
And now it was upgrade even more and i need to take another snap to share with you when i back home.. Attached end last year photo.
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 05-10-2006, 09:51 PM   #200
esham's Avatar
i read about Dom opinion in V1RRR thread. I could agree some of his point on the hopup but my case towards option parts was because experience problem with the stock parts, durability, smoothness issues.
Old 05-10-2006, 10:36 PM   #201
fritzD's Avatar
Send a message via Yahoo to fritzD
indeed... like the pinions... hehe
fritzD is offline   Reply With Quote
Old 05-11-2006, 12:03 AM   #202
esham's Avatar
exspecially like me, if i run it on permanent track the worn out is reasonable but i i run it on parking lot that just 60-70% clean it worst.
But one thing about the pinions, i'm using steel kawahara 1st gear Z-1816 pinion ( This is ok ) but combine with kfactory K1918 - 21T Hard Coated Aluminium (This was bad decision ) I don't like the kfactory because the gear edge is so must taper ( The gear edge is chamfered ). But thank god now kyosho produce steel pinions VZW066 series and VZW215 series.
Old 05-11-2006, 12:14 AM   #203
esham's Avatar
rmdhawaii, may i suggest
Option Parts
K-497 Kawahara Rear Adjustable Stabilizer Set ( Rear antiroll blade )
Advantage
Easy fine tunning the stiffness of rear antiroll bar ( By just turn the blade )
Disadvantage
Expensive
Old 05-11-2006, 12:27 AM   #204
esham's Avatar
2 more items in my "magic box" are:
1. K1902 KFactory Steel Hinged Pin Set
2. VZW211 Kyosho 64 Titanium Bevel Shaft
Need to use them..
Old 05-11-2006, 12:34 AM   #205
esham's Avatar
The front shot with graphite body mount stay holder and WCE graphite front shock stay.
Old 05-11-2006, 12:36 AM   #206
maskedrider's Avatar
what advantage will be the different of using this ??
Kyosho- Sirio/ OS engine- AVID bearing- Blue thunder fuel- Proline- RC dynamite- Sanwa- RC Art
maskedrider is offline   Reply With Quote
Old 05-11-2006, 12:44 AM   #207
esham's Avatar
I don't know about this yet but a local good driver did told me about the smoothness and lighten. Currently i'm using LSD Kyosho diff gear, and i'm happy with that package ( smooth rotation and realible )
Old 05-11-2006, 12:48 AM   #208
esham's Avatar
And all the 177 bush at steering holder, i change it to bearing. Reason- smoother.
Old 05-11-2006, 12:56 AM   #209
esham's Avatar
And i still use the customize aluminium pipe holder mount at upperdeck. Probably this is not good idea. I'm thinking to change it to Kawahara K-475 Mid bearing block as to mount it back to chasis as suggested by Bundyman before.
Old 05-11-2006, 12:56 AM   #210
hey esam...does ur side easy to get parts in malaysia?
FS: ULTIMATE KYOSHO MINI-INFERNO - MUST SEE - MAKE OFFER! Chris Furman R/C Items: For Sale/Trade 11 07-28-2007 08:40 PM
Kyosho V-One RRR WC Team Edition Roller(laydown servos edition) - $245 Shipped! AZrcDude R/C Items: For Sale/Trade 40 07-04-2007 12:15 AM
Kyosho V-One RRR WC Team Edition Roller(laydown servos edition) - $300 Shipped AZrcDude R/C Items: For Sale/Trade 39 06-20-2007 04:55 PM
FS: ULTIMATE KYOSHO MINI INFERNO - HOP-UPS.. MUST SEE! Chris Furman R/C Items: For Sale/Trade 20 06-12-2007 08:25 PM
ULTIMATE KYOSHO EVOLVA PARTS LOT sikgraffx R/C Items: For Sale/Trade 1 10-09-2005 01:59 PM
